Old 03-31-2006, 04:20 AM   #4231
check the Xray site. In the set-up sheets section you will find some from the DHI cup in Denmark. I think that would be a good starting point.
Frans H is offline   Reply With Quote
Old 03-31-2006, 04:59 AM   #4232
Send a message via AIM to R/C Anonymous
I didn't keep up with that race good. Were they using the Fasttrack carpet at the DHI Cup?
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-31-2006, 08:33 AM   #4233
ICEMAN's Avatar
there's a lot of set ups fo sho
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 04-01-2006, 01:26 AM   #4234
Victor A's Avatar
Here is the link a for some pics of jilles' t2
http://www.rctouring.nl/X-Ray%20T2%2...20Groskamp.htm
www.RcTouring.EU
Victor A is offline   Reply With Quote
Old 04-01-2006, 04:11 PM   #4235
Nexus Racing's Avatar
Anyone know where can I get a set of snap-ring pliers small enough for the T2 diff? I tried two local tool stores before work today with no luck.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 04-01-2006, 05:01 PM   #4236
Superfly1967's Avatar
Is there a mod that needs to be done to run LiPoly batteries in the T2?
Superfly1967 is offline   Reply With Quote
Old 04-01-2006, 05:27 PM   #4237
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Nexus.. I got a nice pair at my Local sears Hardware store..
Superfly.. You have to file down that one part on the rear aluminum bulkhead that hangs down. It has been done successfully.
I have a question. Last night I was at the track and borrowed those chassis balancing things. My friend with the same car had to add 10 grams of weight on the battery side for it to be balanced.
When we did mine I needed like 30 grams of weight on the other side where the motor is. Its just weird to see that big of a diffrence. I mean I do have smaller electronics than him but that is a big diffrence. And when I look at all the pro drivers set-ups they add weight on the battery side to. Anyone have any idea's?Where have you guys put your weights?
HRCRACER123 is offline   Reply With Quote
Old 04-01-2006, 05:29 PM   #4238
Pics of my ride..http://www.rctech.net/forum/showthre...72#post2114572
Old 04-01-2006, 06:38 PM   #4239
RCknight's Avatar
Default My car is so hooked up right now....
and I'm even running purple and plaid tires. It's great! I'm lovin this car.
RCknight is offline   Reply With Quote
Old 04-01-2006, 07:54 PM   #4240
Hobby Boy's Avatar
go to sears store Red Handle snap-ring pliers for under $15.00
Hobby Boy is offline   Reply With Quote
Old 04-02-2006, 06:40 PM   #4241
Get 'N' Faster!'s Avatar
hey guys does anybody know where you can find the solid top deck for the t2. if so let me know thanx.
Get 'N' Faster! is offline   Reply With Quote
Old 04-02-2006, 06:42 PM   #4242
Default Squaring Fixture
Here is a little something I have been working on for awhile. Iíve had the idea for a few years and I think the T2 can really benefit from it. Itís a squaring fixture designed to perfectly square the T2 front to rear, side to side, and corner to corner. I designed it to accommodate screws going all the way through the bottom. The battery taping area, the lower bell crank area,and the servo mounting screw sections are pocketed so the chassis can rest perfectly flat with no obstruction. Just take a completely assembled T2 ready to go on the track and bolt it to the fixture using the 4 weight screw holes on the chassis corners. Then loosen all the top plate, bulkhead, diff cover, etc, etc, screws and re-tighten them. It works very well. It has a 3mm ledge around the outside so you can use it as a car stand. The unit shown is just the prototype. The production version will have 3-inch long thumbscrews to fasten the car to the plate. Let me know what you guys think.
NEW XRAY T2-tourque-plate-001.jpg   NEW XRAY T2-tourque-plate-002.jpg   NEW XRAY T2-tourque-plate-003.jpg   NEW XRAY T2-tourque-plate-004.jpg   NEW XRAY T2-tourque-plate-005.jpg
Art Jensen is offline   Reply With Quote
Old 04-02-2006, 06:43 PM   #4243
one more pic
Old 04-02-2006, 06:44 PM   #4244
Default Top deck
CRC has the solid decks. They work great!
coltsfan is offline   Reply With Quote
Old 04-02-2006, 06:53 PM   #4245
Jimmy Morris's Avatar
I think its an awsome idea. No more hurting fingers from pressing down on shock towers. lol.
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
