Old 03-27-2006, 08:35 PM   #4201
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Originally Posted by Mongo
Ok 2 questions for everyone......
I have a FK04 ( FT or FK not sure ). Is this better or worse then the New T2 for pavement racing... I know its sounds stupid to ask if old car is better.. just curious. I can buy a T2 tomorrow, just need some oppions before I do.
Then, if the T2 is a better car I will sell my 04, but I have tons of parts for the 04, what parts are interchangeable from the T2 to the 04?
Thanks!!!!!
Don't get rid of your 04 thinking the T2 is that much better. The T2 is a great car but if I had a 04 and parts instead of the car I had, I may not have switched. This car is my best car yet, whether or not it's best for you depends on personel choice. The T2 is easy to work on and more refined the 04 is still a good car.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 03-27-2006, 09:11 PM   #4202
Joe Os's Avatar
Originally Posted by gonzo416
I'd go with the T2 because it's durable very fast and smooth.
Where do i can fine the T2 parts?
Joe Os is offline   Reply With Quote
Old 03-27-2006, 09:34 PM   #4203
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by protc3
i have a real trick 2.25 mm chassis and top deck that i just finished the files on.it is going to start in production probavly this week.the spool is going to be tested this weekend with its worst enemy,ME!!!! and a 7x1. i will let you know how it holds up.right now the spool is a inbetween the weight of a standard aluminum spool and a oneway.i want to lighten it up a little on the production pieces.i was going to use titanium but the titanium prices are extremely high right now and i think it will drive the cost up too high.i will keep you posted
Im sure they will both be just as good as everything else you have made!! Got money in hand waiting on them both....Got a new 100x80 asphalt track right down the road to race on this summer!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 03-27-2006, 09:41 PM   #4204
RCknight's Avatar
Default Got a set of rear aluminum uprights and they are....
very nice. I keep chuckling to myself about how nice parts fit together on the T2. I also love the way the shocks mount. When I'm in a big hurry, I seem to drop and lose shims/nut.
This car's about spot on perfect, other than needing hard coated aluminum shock bodies and having a screw that holds down the shock piston. I don't think I could go back to anything else at this point.
I got the track width shims, 30 springs and changed my setup. I can't wait to see how she drives this Wed. I need lady luck on my side, since I've had no good runs the last few races.
RCknight is offline   Reply With Quote
Old 03-28-2006, 10:38 AM   #4205
chicmagnet's Avatar
hi guys! i just got my t2 assembled. i would just like to ask which spur gear is better?? ill be using 64pitch spur and 23turns motor. which is better if ill use a 100t or 78t?? what are the effects if i use 100t spur and 28t pinion. or a 78t spur and 23t pinion. need help guys...thanks!!
STRAIGHT LTD.
chicmagnet is offline   Reply With Quote
Old 03-28-2006, 10:47 AM   #4206
teamgp's Avatar
For 64p on a T2, the smallest spur I was able to fit was a 110t and the largest (slightly sticking out the bottom) was a 120t.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 03-28-2006, 10:52 AM   #4207
chicmagnet's Avatar
what is the effect if i use 120t?? suppose if i get the same ratio out of diff combination of spur and pinion?? if i use small spur, will my acceleration be faster than top speed or vice versa???
STRAIGHT LTD.
Old 03-28-2006, 10:55 AM   #4208
chicmagnet's Avatar
like 94t spur and 28 pinion, the ration is about 5.7 but if i use 78spur and 23pinion it get 5.76. whats the difference between the 2??
STRAIGHT LTD.
Old 03-28-2006, 01:52 PM   #4209
stiltskin's Avatar
Trader Rating: 102 (100%+)
First off, 64 pitch allows a finer adjustment between gears. One tooth doesn't make as large of a difference in your final ratio. When using a large spur (120), you have to use a larger pinion to get the same final ratio. (ie.. 100/25=4.0, 120/30=4.0) Since the larger pinion has more mass that the motor has to spin, you can lose a small amount of torque. However, it doesn't allow the motor to slow down as much either so you should never miss the torque. I think its called "cogging effect". The other issue with the larger spur is that it moves the motor forward more on the chassis. Not good, not bad, just different. Depends on what you want. Hope that helps.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-28-2006, 02:18 PM   #4210
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
If anybody had a FK'05 2.5mm chassis they want to get rid of. Please PM me. I will pay top dollar $$$. Thanks..
HRCRACER123 is offline   Reply With Quote
Old 03-28-2006, 02:38 PM   #4211
Hobby Boy's Avatar
[QUOTE=stiltskin]Does anyone know where I can get aftermarket aluminum shocks in Alien Green? [/QUOTE
Hobby Boy is offline   Reply With Quote
Old 03-28-2006, 04:20 PM   #4212
Send a message via AIM to R/C Anonymous
i had a 96 tooth on mine the first week i had it. gotta use huge pinions though. i think the smallest you could use was around a 33 tooth pinion.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-29-2006, 07:14 AM   #4213
DaveW's Avatar
WHAT?! This thread was on page 2?!
DaveW is offline   Reply With Quote
Old 03-29-2006, 07:18 AM   #4214
chicmagnet's Avatar
thanks guys! maybe ill try 94t 64pitch spur.
STRAIGHT LTD.
Old 03-29-2006, 07:50 AM   #4215
teamgp's Avatar
That is a very large gearing combo that should have burned up just about any motor. What motor, tires and track surface did you use that with?
Guy Hood
