Old 03-22-2006, 10:17 PM   #4096
Sushi Man's Avatar
Send a message via AIM to Sushi Man
can someone post pics of how they mount a novak GTX on this car? thanks
Sushi Man is offline   Reply With Quote
Old 03-22-2006, 10:23 PM   #4097
Twin 1 Kevin's Avatar
Originally Posted by benroc
you got the chassis and yop deck or just chasssis and how much , its not on there web site ?
You get chassis, BOTH top decks. and shock towers for $129.00. screw holes are countersunk. even on the shock towers.
This is the BMI website.
www.bmiracing.com
Call and order one. You'll be glad you did.
Twin 1 Kevin is offline   Reply With Quote
Old 03-22-2006, 10:28 PM   #4098
James's Avatar
I set mine up the same as this. GTX on it's side/back, batt wires soldered under pcb instead of ontop, so they come straight out under the top deck. works a TREAT.
only thing is, from a safety electronics point of view, you shouldnt really cover the top of the cap like this.. (pointing toward the chassis) incase it blows, etc..
anyway...
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 03-22-2006, 10:32 PM   #4099
James's Avatar
my T2 with GTB brushless and spektrum. re-doing the wiring at the mo..
Old 03-22-2006, 10:37 PM   #4100
Default T2 BMI and GTX
BMI chassis with GTX
BMI has a satin finish
Old 03-22-2006, 10:40 PM   #4101
does anyone have pics of the BMI shock towers, i want to see how it is stronger where the camber links attach.
thanks
6g72tt is offline   Reply With Quote
Old 03-22-2006, 10:42 PM   #4102
Take my word for it....The BMI towers are stronger around the RC holes.
Old 03-22-2006, 11:50 PM   #4103
Originally Posted by Novarossi
Hi Guys,
Another nitro--->electric convert here. I started reading the forum from the start but after 40 pages, my head started hurting lol.
I got a T2 which I plan to start off in stock for a while.
Now, some more silly newbie questions.
The T2 comes with a 87t, 48 Pitch spur right?
I plan to get an 86t and 88t spur also.
Also, from what some of the local guys have told me, the pinions I will need will be anywhere between 23t-28t
Now my questions:
1./ What brand pinions do most use with the T2, and will they fit ok with the spur range I mentioned?
2./ Where can I buy this brand of pinions online?
all wrong sorry to tell you. the car comes with a 84t spur & you will need pinions between 18-25t use the t2 rollout chart as a guide.
i am currently using a 87t spur with 21t pinion wich is a 28.10 rollout.
may i ask who told this info?
flysti is offline   Reply With Quote
Old 03-23-2006, 04:40 AM   #4104
VenomWorldOrder's Avatar
i told him it came with a 84 tooth spur, but i also told him heaps of other info (ie to get a 87 spur)...and he probably got confused
VenomWorldOrder is offline   Reply With Quote
Old 03-23-2006, 06:46 AM   #4105
ChrisP's Avatar
Xray has also made a running change to the front and rear shock towers, leaving more material around the roll center holes for additional strength.
The CF parts shipment RCAmerica received should be the updated towers. This was a change to the towers, not an option tower, so the part number listed onthe T2 parts list is still correct, the part itself has merely been updated.
ChrisP is online now   Reply With Quote
Old 03-23-2006, 06:48 AM   #4106
Send a message via AIM to benroc
i got an 84 and my pinion is 22 and my motor is getting hot so do i have to go up or down , and everybody tells you to check rollout , but in what range , sorry newbee ,
benroc is offline   Reply With Quote
Old 03-23-2006, 06:57 AM   #4107
stiltskin's Avatar
Trader Rating: 102 (100%+)
You need to base your roll-out on what works at your track. I'm rolling out just over 30 with the CO27. As far as the motor getting hot, it may be undergeared and working too hard, it could be overgeared and working too hard. If you have alot of drag brake dialed in, it will also heat up the motor. I don't think anyone here is trying to ignore you, just alot of variables involved in gearing. Check with the track locals and see what they're running. Even if they're not running the same car, the roll out should be close.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 03-23-2006, 07:20 AM   #4108
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Yeah I just got some in stock and they are beefier around roll center area.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 03-23-2006, 08:31 AM   #4109
teamgp's Avatar
Try a 20t pinion and take a temperature reading from the motor after a 5 minute run.
A good temperature for most stock motors would normally be between 170F (cold environment) and 195F (hot environment). If it is higher than 195F then go down another tooth on the pinion and do another 5min test run. If it is lower than 170F, then go up a tooth on the pinion and do another 5min test run. I always try to start out with smaller pinions and then keep increasing the pinion size until the motor comes off the track between 185-195F. However, some motors like to run cooler near 170F (co27) and others warmer near 195F (P2K2).
Rollout and gearing in general is explained on page 40 of the XRAY T2 Set-up Book.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 03-23-2006, 08:42 AM   #4110
Send a message via AIM to R/C Anonymous
Is that the temperautre of the can, endbell, or armature?
Geoff C.
R/C Anonymous is offline   Reply With Quote
