NEW XRAY T2
Old 03-18-2006, 06:23 AM
  #4021
Chris08527's Avatar
Trader Rating: 16 (100%+)
anyone have a web site where to get the good counter sunk spur gears to fit the T2???
Chris08527 is offline
Old 03-18-2006, 07:01 AM
  #4022
Gael L's Avatar
http://www.precisionracingsystems.com/default2.aspx
Gael L is offline
Old 03-18-2006, 07:23 AM
  #4023
beerbarron's Avatar
Hey everyone, I have not seen any center one-ways for the T2. Being new to X-ray I am not sure if they are available or not. Can someone clue me in. I know they have the front multi-diff. I am just looking for more options come spring and running outdoors on rubber.
I should have my T2 next week sometime and my FTTC4 will be gone. Not a bad car, but time for a change.
beerbarron is offline
Old 03-18-2006, 08:41 AM
  #4024
hpipro321's Avatar
no center one way that i know of.... u really dont need it.
hpipro321 is offline
Old 03-18-2006, 10:06 AM
  #4025
PitCrew's Avatar
Originally Posted by Impulse_racer
Try .5 degree to 1 degree front toe out to increase your turn in. 6 degree caster blocks or adding some pro-dive will give you more on power steering.
I recently had to add weights to the car to make scales at a two day race, so I added one 7 gram weight on each side of the front near the standoffs, and one in the center of the chassis. I had been running kickup, and went back to a flat set up with the arm, and stayed with the 4 degree castor blocks. The car worked great.
It really helped give some steering I had been looking for.
So that is another option.
I run about 0 toe out.
PitCrew is offline
Old 03-18-2006, 03:58 PM
  #4026
Chris08527's Avatar
anyone have a good starting set up for asphalt with rubber tires???
Old 03-18-2006, 04:10 PM
  #4027
John-Tag's Avatar
Step #1 Install Rubber tires...
John-Tag is offline
Old 03-18-2006, 04:16 PM
  #4028
Chris08527's Avatar
thanks Tag . . .i will have to try it out!!!
Old 03-18-2006, 04:29 PM
  #4029
protc3's Avatar
Tag is a set up god!!!!!!!! i new i forgot something.
yo tag,i need some info on your races coming up.give me a buzz or shoot me an email with some info
protc3 is offline
Old 03-18-2006, 04:54 PM
  #4030
John-Tag's Avatar
Never say shoot to a Red Neck we carry shot guns...
Jason call me on cell # in sig....
John-Tag is offline
  #4031
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Check on the Xray site for setup I have a pretty good one with a diff in front and CoryCraig has one for spool.
Rod
RKeasler is offline
Old 03-18-2006, 05:50 PM
  #4032
gonzo416's Avatar
Trader Rating: 39 (98%+)
PitCrew what's the status on those aluminum adjustable parts for the T2?
gonzo416 is offline
Old 03-18-2006, 07:42 PM
  #4033
OVA
OVA's Avatar
Trader Rating: 80 (100%+)
aluminum Adj. part?????
OVA is offline
Old 03-18-2006, 09:26 PM
  #4034
highwayman's Avatar
Originally Posted by Maddafunker
Hi guys. Any gearing suggestions with a Novak 4.5 brushless on a 64 pitch spur and pinion? I'll be running on asphalt.
Thanks in advance.
i'm running my T2 with 112 spur (64pitch) with a 19T pinion. its bood for both capitol speedway and jpraceway
highwayman is offline
Old 03-19-2006, 04:19 AM
  #4035
gonzo416's Avatar
PitCrew is making aluminum adjustable castor blocks and rear c-hubs(toe).
like the schumacher ones, but he is going to use aluminum adjustable inserts instead of plastic. there supposed to run about $75. sounds awesome, just can't wait to see them.
gonzo416 is offline
