NEW XRAY T2
Old 03-16-2006, 08:49 PM
  #3991
Originally Posted by scottw
whooo hoo I finally have an answer and not a question .
I have one for my T2
http://coolcanfan.com/
scottw you are the man. Thank`s
srp67 is offline
Old 03-16-2006, 11:40 PM
  #3992
lbckevin's Avatar
Trader Rating: 96 (99%+)
3 racing makes the fan that is screwed to the heat sink.
lbckevin is offline
Old 03-17-2006, 08:07 AM
  #3993
Cgracing's Avatar
Default What body fits the T2?
sod the tc3s, bought a T2, I know mazada 6 will fit, wonder if the stratus3 fits also?
Cgracing is offline
Old 03-17-2006, 08:21 AM
  #3994
any 190mm body should fit for 1/10th scale
R/C Anonymous is offline
Old 03-17-2006, 08:28 AM
  #3995
Din Viesel's Avatar
I am currently running a stratus 3 and it fits just fine
Din Viesel is offline
Old 03-17-2006, 09:15 AM
  #3996
ICEMAN's Avatar
I have one of the 3 racing one's i got from www.precisionrc.com , is works very well,
ICEMAN is offline
Old 03-17-2006, 09:24 AM
  #3997
Derby Bros Racing's Avatar
i don't know if you've noticed it from the 3racing fan. but the direction of the air is away from the motor in stock form. i flipped my fan over to have the direction of the air to the motor. does anyone know which one works better, towards or away?.......
Derby Bros Racing is offline
Old 03-17-2006, 09:28 AM
  #3998
Michael Barch's Avatar
The 3a racing fan would just be blowing foam all on your motor...
When Im done running I get a bunch of foam built up on the end of my motor, and I would think, from the position where that fan is it would blow right into it.
Michael Barch is offline
Old 03-17-2006, 09:42 AM
  #3999
ICEMAN's Avatar
the FAN should always pull heat away , you should never direct the fan to blow into is, the natural air through the body will flow through there.
ICEMAN is offline
Old 03-17-2006, 10:52 AM
  #4000
Trader Rating: 40 (100%+)
Is that a 25 or 30mm fan on it?
brians11 is offline
Old 03-17-2006, 11:24 AM
  #4001
ICEMAN's Avatar
25mm, the same size most everyone uses
ICEMAN is offline
Old 03-17-2006, 01:46 PM
  #4002
Look for some thoughts what would be a good base line for rollout when running a 8 turn motor and also with a 12 turn, been running stock for the past couples months and want to try a couple mod motors I have.
Running right around 29.5 with a monstor stock motor.
27T 29.5
12T ____
8T ____
corwin is offline
Old 03-17-2006, 02:31 PM
  #4003
Well, hopefully my car does well tonight, I don't think Im going to pick up some new tires, even though it really needs some. I can wait.
My 19T seems slow, alot of people say its slow for the motor. Its a Element V2, Pinion- 84T/48P & Spur-25. My track is semi-techincal and its fast and all, but you guys think I should try uping it? My heat sensor broke awhile back so I don't have one, but when I pull it off and set my hand on the motor for a couple seconds it gets pretty hot.
BTW, its brand new motor. Only about 5, 5 min runs with it.
Old 03-17-2006, 02:34 PM
  #4004
C_O_jones's Avatar
gear you Element V2 at 5.2 to 5.4
C_O_jones is offline
Old 03-17-2006, 02:37 PM
  #4005
Superkarter's Avatar
The v2's need to be geared silly tall to be fast I know cause I have one.
Superkarter is offline
