Old 03-14-2006, 10:40 PM   #3946
RCknight's Avatar
Default Anyone know when...
we will see some shims? Seems they have been back ordered for awhile.
RCknight is offline   Reply With Quote
Old 03-14-2006, 11:09 PM   #3947
kidDynomite's Avatar
Originally Posted by andrewdoherty
The stock brushed is a temporary deal. My "mate" plans on running a 4300 brushless as our track allows them in stock racing. I agree about moving the connectors inboard. I also plan it rewire the pos motor connector so it comes in perpendicular rather than parallel. I bought the connectors at my LHS. I am sure they could get you some .the link is in my sig. POke around and I am sure you will find the ph #.
Thanks for the info, I've been wanting to try and find those perpendicular connectors to cut down on motor swapping/testing between heats. Are those made by Corally? Didn't see them on their site.
kidDynomite is offline   Reply With Quote
Old 03-15-2006, 12:19 AM   #3948
Hebiki's Avatar
Trader Rating: 26 (100%+)
not sure who makes them. but integy has them on their site
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 03-15-2006, 01:05 AM   #3949
RCknight's Avatar
Default .
deleted.
Old 03-15-2006, 03:36 AM   #3950
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by Joep
No it doesn't fit.
bummer!!!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 03-15-2006, 05:55 AM   #3951
Originally Posted by BritRacer
"Not to mention that this tweaked, fragile, difficult and expensive to repair car has TQ'd and won the last 3 major races in the US."
Ok, so you are trying to tell us that Lemieux and Dumas were running a multiflex lower chassis and a multiflex top deck at Snowbirds????
I never said this car was a POS, you did.
I said the attitude of a lot of people and the practices of the company annoy me, thats all.
I suggest you put your toys back in the pram.
you said you were going to corally and we would hear from you anymore. the car is a good car it is too bad that you are not happy .the rest of us are really happy with the [email protected]
ptjonesus is offline   Reply With Quote
Old 03-15-2006, 06:13 AM   #3952
Superfly1967's Avatar
Originally Posted by Din Viesel
Hey Superfly, what did Mike do to correct this?? I have recently gone to the washers under the screws and found this to be an improvement, and have had little to no tweak issues. But if there is something that one of the Pros showed you and you are willing to share, Iam willing to listen
Din Viesel
He didn't do anything to correct it as a permanent fix. Just took the tweek out in under 10 seconds. My fix was to quit hitting things at high speeds. He sat the car on the Hudy blocks, wheel and all. checked both sides. Sure enough, rear was tweaked. He loosened the 4 screws toward the rear of the upper multiflex, held down there and tightened in criss cross pattern, tweak fixed.
I will also tell you he has no washers or counter sinking done on his chassis. He started putting together a brand new car, and used chassis that came with car.
Hope this helps.
Superfly1967 is offline   Reply With Quote
Old 03-15-2006, 06:29 AM   #3953
DaveW's Avatar
AE part #6936 is an aluminum #4 washer, 10 come in a pack for 1$. Four of these washers equal 3mm (actually, just a tick more), which are commonly used on the inboard hingepin mounts to widen the car. I dont know which shims on the T2 you are referring too, but these are common and easy to find for this use. Four packages gives you enough to do the whole car, and you can add and remove shims in increments to find the right amount of spacing F/R. They arent shiny and purty like the Xray stuff... but oh well... theyre cheap and they work! For hub spacing under the camber link mounts i have been using motor shims that come in a Trinity shim kit... they are almost identical to the Xray shims, but are "in stock", versus the Xray goodies. If you guys are looking for "in the LHS" replacement screws that arent an arm and a leg to buy, AE also sells screws that are 3mm X whatever size you need that are for the MGT... there are two types, phillips head and socket head, so be sure and look before you buy.
DaveW is offline   Reply With Quote
Old 03-15-2006, 06:43 AM   #3954
Joep's Avatar
They are available in Holland. Got them in a few weeks ago.
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
Old 03-15-2006, 09:42 AM   #3955
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by dodgeguy
Andrew, do those motor females screw on to the end bell? Or do you have them soldered in? Very clean man.
I have the GTB with a 4300 right now. I am looking to run stock with it also.
Thefemale connectors replace the small phillips head screw that secures the endbell to the can. The female connectors thread in nicely with a larger phillips screwdriver. I have been using them for about 4 months and haven't had one ever come out. In fact they are still tight every time I use them. I think Hebiki is right that integy makes them. My LHS stocks the small connectors that are meant for general use and not the motor (like the three in the picture)under another brand. I can find them with the plane connectors as well as on the car side of my lhs. I will check on the name next time I am at the track (maybe today). Glad you guys like it.
Old 03-15-2006, 12:12 PM   #3956
Send a message via ICQ to GrfxGuru Send a message via MSN to GrfxGuru
Hey Andrew I know that car
Andrew did a great job on the wiring, the switch between brush and brushless should be real simple and quick.
GrfxGuru is offline   Reply With Quote
Old 03-15-2006, 05:13 PM   #3957
gonzo416's Avatar
Trader Rating: 39 (98%+)
andrewdoherty please post the brand of those motor bullet connectors and where to get them. looks like it would only take a minute to replace the motor.
gonzo416 is offline   Reply With Quote
Old 03-15-2006, 09:14 PM   #3958
BritRacer's Avatar
you can get them here, individually so you dont pay more for a wierd number..lol
http://www.brahmaracingproducts.com/...d&productId=65
BritRacer is offline   Reply With Quote
Old 03-16-2006, 05:57 AM   #3959
gonzo416's Avatar
what about the female connector that is on the motor?
Old 03-16-2006, 07:24 AM   #3960
Jack Smash's Avatar
Trader Rating: 29 (100%+)
10 seconds of browsing and i found this:
http://www.brahmaracingproducts.com/...d&productId=63
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
