Old 03-07-2006, 03:24 PM   #3766
DennisNyholm's Avatar
Originally Posted by Anthony.L
Well did you post up before buying it.
Of course!!! Most of the people agreed the 9550 was a good deal. SOme people stated how they wouldn't get anything other than a JR servo, but no one had anything bad to say about the futaba. I don't think i'll be able to tell a difference though (beginner). Maybe if and when I get better, i'll just upgrade it at that point...
DennisNyholm is offline   Reply With Quote
Old 03-07-2006, 03:30 PM   #3767
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Originally Posted by ChadCapece
I was going to get him some rcprofessor 19t and stock motors. Does the battery strap tweak the chassis at all? I use a 9000s in my mod truck and love it. Unless somone knows of a better servo, that's what I was probably going to order.
His skill is about medium range right now. I can keep it off the pipes, but doesn't run smooth and clean lines.
The only way the battery strap can tweak the car is if the cells don't sit level or sit too high (from not filing the slots). The easy way to cure this is to put a washer under the posts for the strap so the strap doesn't "bow" itself due to the outer cells being taller than the post. I have a washer under mine so there is just a small bit of "play" between the cells and strap. With the cell supporters on the chassis and the strap, they won't go anywhere, and you don't notice the small play on the track.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 03-07-2006, 03:33 PM   #3768
If it makes you feel any better about the 9550, it's the same servo Lemieux used during his string of winning races. Doesn't seem the servo hurts anything at any level, and the size fits nice without over hanging off the chassis. I have the same one.
I think the only class that you will notice over 100oz of torque making a difference will be offroad trucks and 1/8.
Old 03-07-2006, 03:38 PM   #3769
EricF's Avatar
you can notice a difference in mod with low turn motors. the pwr. form the motor will want to pull the wheels straight. kind of like in front whell drive cars. torque steer.
E
EricF is offline   Reply With Quote
Old 03-07-2006, 03:47 PM   #3770
Good to know. I'll be driving stock for a while (can't afford the parts for Mod, nor amI good enough), so the Futaba will be more than enough fomr me....
Old 03-07-2006, 04:20 PM   #3771
wildman's Avatar
Send a message via AIM to wildman
Parma makes a great bumper for the T2 as well as others. Very Very stiff.
Later
BB
TEAM ASSOCIATED / REEDY / KO PROPO / FLY RACING
wildman is offline   Reply With Quote
Old 03-07-2006, 04:42 PM   #3772
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Yeah I was going to buy the 9550 but Larrys was out of it and only reason I wanted it because it was Low Profile, but the JR is alright, and don't stand out too much, plus its faster but nothing you will really notice.
Michael Barch is offline   Reply With Quote
Old 03-07-2006, 07:17 PM   #3773
C_O_jones's Avatar
The T2 battery strap is slotted in the front hole at the thumb screw. with the screw tightened down the strap still moves,this allows the chassis to flex without the strap binding. I dont see how it could induce tweak. Even with my 3800's the batts still have a little play.
Pretty ingenius design to let you set the chassis for max flex and not have the batt strap bind up.
Fred
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 03-07-2006, 07:27 PM   #3774
Send a message via AIM to R/C Anonymous
Originally Posted by PitCrew
I think they are common around $115.
It has the highest speed and torque combo of any servo on the market right now.
.06/128 oz-in.
Recently put one in my T2 and I love it. I though the car was going to overly agresive with the steering with the upgrade, but it wasn't. The car is much smoother, and feels more nimble, and didn't have ANY negative affects.
My recomendation.
how about the KoPropo 2113 and 2123 @ .06 and 131 oz ?
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 03-08-2006, 05:14 AM   #3775
NOOB-SMOKE's Avatar
Default T2
Gday
I was looking at a few xray setups and a few guys are
putting a spacer in the front to toe out the front hinge pins.
.5 to 1.0mm in behind the front roll centre block at the front.
what does this do give more steering or less.
CHEERS
NOOB-SMOKE is offline   Reply With Quote
Old 03-08-2006, 07:10 AM   #3776
teamgp's Avatar
Originally Posted by NOOB-SMOKE
Gday
CHEERS
This is referred to as 'in-board toe-out'. It generally gives smoother steering transitions from corner entry to exit. However, it is not necessary for all setups. Take a look at the XRAY forum In-board Toe Out thread for more details.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 03-08-2006, 07:23 AM   #3777
Gael L's Avatar
So is this shim in addition to the standard shims that are installed when building?
Gael L is offline   Reply With Quote
Old 03-08-2006, 08:30 AM   #3778
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Yes,that is correct.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 03-08-2006, 08:51 AM   #3779
Interesting I will try this inboard toe-out... lets see how it works for me
hugovdb is offline   Reply With Quote
Old 03-08-2006, 09:13 AM   #3780
Gael L's Avatar
cool. So just the front 2 roll center hubs get shims to add toe out similar to how it is in the rear right?
