Old 03-01-2006, 08:16 PM   #3601
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by Michael Barch
I need it by friday. I will order one eventually. Anyone help me with the front diving?
does the diving happen off power while initiating a corner? try less droop in the rear so there is less weight transfer to the front of the car during deceleration .... hopefully that will help.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 03-01-2006, 08:20 PM   #3602
Trader Rating: 198 (100%+)
I am looking for 6 degree castor blocks. Anyone know of a online shop with them. Nothing on stormer or Speedtech.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 03-01-2006, 08:24 PM   #3603
stumper1's Avatar
R/C Tech Charter Subscriber
Raincityraceway.com
They were in stock a couple of days ago. If they aren't on the web-site yet give them a call.
Any word on when aluminum rear uprights will be available?
stumper1 is offline   Reply With Quote
Old 03-01-2006, 08:32 PM   #3604
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by stumper1
... Any word on when aluminum rear uprights will be available?
www.teamtamale.com
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 03-01-2006, 08:34 PM   #3605
Michael Barch's Avatar
Send a message via AIM to Michael Barch
What degree are the stock hubs?
Another thing, bunch of foam from the tires got into my motor and onto the side of it, my brushes then were touching the motor and it would not move/get power at all.
I moved the brushes and blew out the foam and sprayed it out with motor cleaner, it works now. Any ideas why it stoped? Any ideas how to prevent this from happening agian?
Michael Barch is offline   Reply With Quote
Old 03-01-2006, 09:00 PM   #3606
highwayman's Avatar
Originally Posted by ROBORAT
hwman: dont let the rear toe issue stop you .... this is how i look at it, the car is awesome as it is (and you know that already right?), so any fixes down the road will only make it better! the force is strong in the darkside! HAHAHA ....
... the darkside is indeed VERY VERY VERY strong...
highwayman is offline   Reply With Quote
Old 03-01-2006, 09:41 PM   #3607
lbckevin's Avatar
Trader Rating: 91 (99%+)
Mr. Barch,
You can glue the edges of the foams to stop the peeling or chunking of the foams. You can also put on the rim protector sticker, its the thick one.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 03-02-2006, 08:04 AM   #3608
Alright I will glue the edges of the foams, should I glue both the outside and inner edges?
I don't think I got rim stickers.
Old 03-02-2006, 08:24 AM   #3609
teamgp's Avatar
Here is my setup:
http://www.teamxray.com/xforum/xform...D=239&setup=t2
Michael,
The front diving in is probably caused by your rear arm mounting position with .75d of pro-squat, coupled with your front shocks being leaned in two holes. First I'd recommend either flattening the rear arms, or even flip flopping the suspension holders front to rear for .75d of anti-squat. If that doesn't fully cure it, you may need to stand up your front shocks one or two holes on the tower as well.
Any reason why you're using 0d front caster c-hubs or is this incorrect? It would also help if you filled in the inner (and outer for the rear) camber link mounting positions. What is 32 1/2 wt shock oil?
The grime might have burned onto the comm and prevented contact. I've had dirt/grime do that to my mod motors when running on asphalt at times.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 03-02-2006, 08:28 AM   #3610
teamgp's Avatar
The stock c-hubs have 4d caster. Is the tire chunking happening on the front, rear or both? The best way to prevent chunking is to make sure the tire is not riding on its outer edge at full lean in the corners. This effect isn't desired from a handling aspect either as it causes abrupt loss of traction. A slight setup change (probably increasing static camber by .5d on the tires where its happening) is probably in order.
Guy Hood
Old 03-02-2006, 08:31 AM   #3611
ChrisP's Avatar
I'm not sure who else has one (possibly Schumacher or Trinity?), but Losi has a 32.5wt shock oil....I'm guessing that he's using Losi oils...
The setups on the Xray site in general are based around the Xray oils (most using the 30wt that's included with the kit)...so that is what I personally use and they work perfect for me
ChrisP is offline   Reply With Quote
Old 03-02-2006, 08:36 AM   #3612
teamgp's Avatar
I had thought about that. But with their oil being thinner overall than XRAY's, 32.5wt would be way to thin for foam/carpet racing. I was thinking more along the lines that maybe he had mixed 30wt and 35wt.
Guy Hood
Old 03-02-2006, 09:27 AM   #3613
I use the Losi 32.5 oil, so far so good.
Old 03-02-2006, 09:33 AM   #3614
Trader Rating: 23 (100%+)
That will be a little too thin. For the TL stuff, look at the 45 to 60 range.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 03-02-2006, 09:38 AM   #3615
Well the T2 gives you 30WT oil...its thicker than the stuff XRAY gives you.
