Old 02-24-2006, 05:50 AM   #3376
Has the pin started to creep out of the cvd joint on the shaft?
xraydad is offline   Reply With Quote
Old 02-24-2006, 07:52 AM   #3377
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Speaking of those damn Pins creeping out...mine are starting to. When I put locktite on the pin it got all into the cvd and locked it up, we had to brush and remove all the locktite and also sand the cvd a bit...
Any ideas on how to stop the pins from coming out easliy?
Michael Barch is offline   Reply With Quote
Old 02-24-2006, 07:59 AM   #3378
Kyle Wilson's Avatar
Grind a small flat on the pin where the set screw seats and lightly loctite (blue) the set screw, let dry and install. Hope this helps.
Kyle Wilson is offline   Reply With Quote
Old 02-24-2006, 08:32 AM   #3379
teamgp's Avatar
Originally Posted by Andrew Ellis
I played with caster at my regionals the track was big and fast meaning big sweeping turns I ran the 4's flat and the 6's flat the 4's felt like they did not hold the line in the middle of the turn the 6's held the line better meaning more on power steering I did not feel like I lost any turn in from the two..The 6's seem to run a tighter line all the way though the turn, to some or some tracks that my feel like a push if the rear of the car does not follow, and the 4's just flow better on some tracks so it feels like there is more steering it all comes down to the track....Later Drew
I've seen the same thing with 6d blocks in the past with running foams on both flowing and tight tracks. They usually cut a tighter line all the way through the corners.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 02-24-2006, 08:52 AM   #3380
Rob Phillips's Avatar
Originally Posted by Twin-Kyle
2 degree will give less on power steering,6 degree will give MORE on power steering.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 02-24-2006, 09:11 AM   #3381
take a bit of heat shrink and shrink it around the outer part of the drive shaft, that way the pin has no way to come out and it doesn;'t affect anything else. and when you need to rebuild you just cut the heat shrink and put a new one on when done. You never have to worry about your pin coming out again.
6g72tt is offline   Reply With Quote
Old 02-24-2006, 09:21 AM   #3382
....Later Drew
so tell me Drew... since im taking the heat for it any way how was that pizza?
AJ Goin is offline   Reply With Quote
Old 02-24-2006, 10:03 AM   #3383
TeamButter's Avatar
Send a message via AIM to TeamButter
He told me it was delicious... a little cold but......
How come I never get delivery???
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 02-24-2006, 11:12 AM   #3384
LOL.... I didnt know you liked pizza too . Ill keep it in mind though for next time.
Old 02-24-2006, 02:27 PM   #3385
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
ok ok, so i c that there is aftermarket chassis out there, but not alot of feed back , So here is the question that hopefully gets answered, how are they workin' and are they a much improvement over the stock chassis for a 19t motor? ie Team Pickles, BMI (new so i doubt any feed back is out there yet, CRC top deck (non countersunk), etc. Please, I see alot of pics, and here guys runnin (snowbirds), but no word yet on the performance.
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 02-24-2006, 03:42 PM   #3386
kidDynomite's Avatar
I've ran the BMI's on the previous T1s. There rock solid for foams. I even had great luck with them with rubber on carpet. No tweaking even after a hard it. The fiber patterns that Jason's CF uses a 0*-45*-90* vs. stock at 0*-90*. This means that it is capable of having a 99.5% return rate (if twisted, it will go back to it's original state). Stock chassic CF only has a 40%-50% return rate (may hold a tweak if twisted).
Jason also bevels his chassis's top and bottom edges at a 45* (not sure of the actual cut depth. Something like 0.1 I think). So you don't have to round the edges off. You can just CA and wrench. Battery slots are also perfectly cut to the latest battery size.
If he made the whole car, you can bet it would blow away any kit in quality and style.
kidDynomite is offline   Reply With Quote
Old 02-24-2006, 04:00 PM   #3387
beerbarron's Avatar
I have just about had it with my FT TC4's steering and vague feel. I drove a really poorly setup T2 yesterday and its steering was so much better than what I am used to. Can anyone who has switched to a T2 from a TC4 post on here and tell me if you are happy and feel the car was worth it. The reasons that I am un happy with the TC4 are its vague steering feel and inconsistent handling. I have wrenched on the acr since November and cannot seem to find a setup that I am comfortable with and that gives good lap times.
beerbarron is offline   Reply With Quote
Old 02-24-2006, 04:30 PM   #3388
The pizza was just the way I like it, just the toppings and easy to get to see ya in a week Later Drew
Andrew Ellis is offline   Reply With Quote
Old 02-24-2006, 04:30 PM   #3389
nmt6789's Avatar
Send a message via AIM to nmt6789
In my opinion the T2 and Tc4 are two totally diffrent animals. You cant even compare them. The T2 is actually quality.
nmt6789 is offline   Reply With Quote
Old 02-24-2006, 04:38 PM   #3390
I think Mike Blackstock can speak for that TC4 B main Xray A main top three ...Later Drew
