Old 02-22-2006, 09:58 PM   #3331
Trader Rating: 198 (100%+)
Originally Posted by Michael Barch
I want to try out Drews setup but I cannot get 4mm shims for on-top of the Hubs...
My shop is out of 4mm, 1mm, and 2mm...So theres no way I can do it. Im going to try and run the stock foam setup sheet the T2 came with, and then tune it myself from ther, I think its time I start trying to tune my own car instend of going to these setup sheets because it will always be different to the driver.
Anyone run the Basic Foam setup sheet? What adjustments did you see you had to make? Besides going 3mm all around and 3.75 in back rear?
I ran the stock Foam set up. The car felt good. But was a little tight in the turns. I did not use the stock springs. I used AE purple front and copper rear.
I do like Drews set up much better.
You do not need to use metric shims. .039 is 1mm
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-22-2006, 10:04 PM   #3332
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Tight in turns...what exactly do you mean by that? I was talking to my buddy Mike today and he runs a T2. He said the car without the 3mm all around, just 1mm, he said the car has sharp turns. Like you need to be on the gas all the way in and through the turn or it will slide out on you. I think I noticed that with my friends 04 I ran with, once I got used to the throtle though I won the main.
So do you mean it will slide out on the turns it is so tight? Or is it just like really sensitive to turns? Im running a really powerful servo too (JR Z9000S). Im going to try the stock setup.
Do you think me adding 3mm all around and the 3.75 far rear will help me control the car better (Carpet/Foam/Stock Class)?
Also what should I set my EPA at and all that good stuff, for a starting point at least, I know I will have to play with it out there on the track.
-Mike
PS- I was talking to Bobby and he said to use the Pink up front and Dark Blue in rear. That is what I seen alot of drivers run. Im going to try that. First Im going to try the stock springs though. On those stock springs, the Sliver seems stiffer than the Copper/Yellow...
Michael Barch is offline   Reply With Quote
Old 02-22-2006, 10:09 PM   #3333
Send a message via AIM to R/C Anonymous
pink and dark blue foam tires?
stock springs for foam?
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 02-22-2006, 10:10 PM   #3334
Well what do you recommend? I have every set of springs so...just let me know and I will try them out.
Old 02-22-2006, 10:13 PM   #3335
Chris Adams's Avatar
If you are running on carpet dont even try the stock springs. They are useless with that setup. Go Pink and white.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 02-22-2006, 10:14 PM   #3336
double pink, double pink/orange tires
and light purple on the front with one of the blue shades or white on the back(Xray springs) perhaps?
Geoff C.
Old 02-22-2006, 10:17 PM   #3337
whitelazer1's Avatar
pink and blue springs works good to.....
whitelazer1 is offline   Reply With Quote
Old 02-22-2006, 10:19 PM   #3338
Okay, so I got one vote for:
Pink and White (White being Back correct?).
One Vote for:
Pink and Blue (Blue Being Back I take it).
One Vote for:
Light Purple and White
Old 02-22-2006, 10:20 PM   #3339
this is with the kit supplied foams correct?
why not just start off with a setup from the XRay site?
Geoff C.
Old 02-22-2006, 10:21 PM   #3340
But for sure don't try the stock springs eh? Whats so bad about the Pink/Darkblue? What about Pink/Copper?
Old 02-23-2006, 12:15 AM   #3341
ottoman's Avatar
R/C Tech Charter Subscriber
Yea ... Geoff would know what springs to run
ottoman is offline   Reply With Quote
Old 02-23-2006, 12:43 AM   #3342
Does any one make a solid 2mm or 2.5mm top deck for the T2
ptjonesus is offline   Reply With Quote
Old 02-23-2006, 01:09 AM   #3343
Default Screw set
Has anyone found a good screw set for the t2, i would like to have a set just for replacements and am wondering if anyone has found a good one to buy. Also does xray make one cause i haven't found one...
links of where to go would be appriciated, thanks
6g72tt is offline   Reply With Quote
Old 02-23-2006, 01:59 AM   #3344
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Read the thread, both CRC and Pickles Performance both have decks.
Anthony.L is offline   Reply With Quote
Old 02-23-2006, 03:03 AM   #3345
both of those company has 3mm I would like one not as stiff
