Old 02-21-2006, 06:48 PM   #3286
Mike the best thing to do is go check out some team driver setup sheets on www.teamxray.com but real quick you want to run the car wide meaning 3mm shims at all 8 corners of the car and that will give you 1 dergee of toe in because the rear hubs have 1 dergee in them... The Novak race would be a good starting point for setup since that was are first race with the car...Hope that helps....Later Drew
Andrew Ellis is offline   Reply With Quote
Old 02-21-2006, 06:49 PM   #3287
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
hey drew...hows it going....its been a while, when will you be up in the area again????
Matt
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 02-21-2006, 07:05 PM   #3288
Yes the diffs are pre lubed but I always put a little more in them the stuff in the kit will be find just a little and I will try to get Alan to come racing more out of town...... Mr. losi I plan to come to the last race of the hurricane allstar at Trackside......Later Drew
Old 02-21-2006, 07:09 PM   #3289
Michael Barch's Avatar
Send a message via AIM to Michael Barch
I don't have enough shims to run 3 at all 8 corners. The most I can do right now is 2 all around and 3 in rear. Besides the screws they gave me I don't think could handle 3 all around...the others besides far rear could barley fit 2 shims with still being tight with the threads.
2 Shims at all 8 corners (Equal) and the 1 degree rear hubs would be 1* or 0*? 1 Shims all around, 2 in far rear + 1* Hubs = 2*?
Sorry Im trying to picture this all in my head without using the board. Im new to all of this, sorry if the questions are dumb.
-Mike.
Michael Barch is offline   Reply With Quote
Old 02-21-2006, 07:16 PM   #3290
Regional Moderator
Racer_Chick's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Racer_Chick Send a message via MSN to Racer_Chick
Hey Nick, thanks for all of the help that you gave my mom and I at the 'birds! The motors were wicked fast every run
Toni Green|Munno Graffix|CFX Racing
Кто глупее? Дурак или дурак, который следует за ним?
Racer_Chick is offline   Reply With Quote
Old 02-21-2006, 07:42 PM   #3291
Mike no problem at all.. The stock shims are 1.5 mm you have 8 total mounting spots for the arms four up front and four in the rear meaning where they mount to the bulk head stock they want you to put 1 shim which is 1.5mm at 6 of the spots and in the rear rear sorry they want you to put two that would have you running 2 dergee of rear toe in because there is 1 dergee of toe in the rear hubs and then there is the 2nd shim in the rear rear that is 1.5mm so tatal 3mm that is another dergee and that is stock ....so what I am saying run 3mm shims at all 8 spots and that will have you running 1 dergee of outboard toe in so this means that you need 6 1.5 mm shims to do that with what is in the kit the screws should work .. Hope this helps if not I will pm my phone number to you and we can talk on the phone and this goes for anybody that needs help.....Later Drew
Old 02-21-2006, 07:44 PM   #3292
Send a message via AIM to R/C Anonymous
ok let me get this through my thick skull....
3 mm shims on all 8 roll centers which would leave the rear at 1 degree outboard toe
so the front will be 2 mm wider because you need to space the foams out on the hexes further to clear the spindles
R/C Anonymous is offline   Reply With Quote
Old 02-21-2006, 07:48 PM   #3293
Chris Adams's Avatar
You dont have to put the 1mm spacer outside of the hub to clear the steering knuckles. You can trim up the rim on the lathe. Gives more steering.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 02-21-2006, 07:49 PM   #3294
BritRacer's Avatar
yup.
For those of you rapidly running out of shims, tamiya do a reasonably priced set
http://cgi.ebay.com/Tamiya-Diameter-...QQcmdZViewItem
or these yeah racing ones...
http://cgi.ebay.com/Yeah-Racing-Allo...QQcmdZViewItem
BritRacer is offline   Reply With Quote
Old 02-21-2006, 08:09 PM   #3295
Kyle Wilson's Avatar
Thanks Drew your the man!
Kyle Wilson is offline   Reply With Quote
Old 02-21-2006, 08:17 PM   #3296
protc3's Avatar
michael barch,
dude,i love the avitar.quagmeyer is the man!!!!!!
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-21-2006, 08:43 PM   #3297
Ok so 3mm total shims at all 8 spots would be Two 1.5 shims at each of the 8 spots correct? That is what I have now.
Heres my artwork.
Old 02-21-2006, 08:46 PM   #3298
P-DUB's Avatar
Hey Drew...I think your missing something in that sig of yours
Larry Pryor
P-DUB is offline   Reply With Quote
Old 02-21-2006, 08:51 PM   #3299
i think stock rear toe is 2 degrees inboard..
Old 02-21-2006, 08:53 PM   #3300
J@UNE's Avatar
Mike,
That would make sense since adding the black (.75 mm) shim add 1 deg... 1.5 will add 2 deg
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
