Old 02-19-2006, 08:21 PM   #3226
HarshGuy's Avatar
I've got a brand new in box T2 for sale: http://www.rctech.net/forum/showthre...65#post2156565
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-19-2006, 08:48 PM   #3227
lbckevin's Avatar
Trader Rating: 91 (99%+)
why are you selling the T2 ?
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 02-19-2006, 10:09 PM   #3228
Trader Rating: 35 (97%+)
Send a message via AIM to King of B Main
I got to give props to Jason C at socal . Last night he drove his T2 to a second place finish in pro stock. He got beat by jason Ertracter a factory corally driver, but his car looked awesome.
King of B Main is offline   Reply With Quote
Old 02-19-2006, 10:20 PM   #3229
lbckevin's Avatar
I know JasonC has been looking good with the new T2...
Kevin Smith
Old 02-19-2006, 10:33 PM   #3230
Dam kevin you missed some good racing on saturday night. Everyone decided to run pro stock instead of 19 turn. Jason C was all over ertracter.
Old 02-19-2006, 10:40 PM   #3231
Michael Barch's Avatar
Send a message via AIM to Michael Barch
While I glued the sides of the carbon fiber chassis some got onto the bottom and looks bad, you think some motor spray/cleaner will get that stuff off there?
-Mike
Michael Barch is offline   Reply With Quote
Old 02-19-2006, 10:58 PM   #3232
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
hey mike want to run my spare car next sat.
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 02-19-2006, 11:01 PM   #3233
JasonC's Avatar
Michael Barch
motor spary will not get of the CA, Acatone ( sp) or finger nail polish remover may, but i would just runt it, it wont look too bad as long and ya dont crash
Old 02-20-2006, 01:40 AM   #3234
HarshGuy's Avatar
I was going to use this one for spare parts, but never needed it, all I ever used out of it was the foam tires that RC America added to the kits, everything else is unoppened.
Old 02-20-2006, 02:11 AM   #3235
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Just got my T2 together. Got shimms????
They should call this the shim car. The whole suspension had to be shimmed. I can understand the shimming for gaps on the suspension arm pin and how that can be manipulated to change wheelbase but what about the shims on the arm mounts? Was that a design flub? Also whats with the shim on the motor bulkhead?
Anyways I built the shocks with adjustable pistons. Tried the adjustable dampening and found the only setting I liked was full firm. So maybe that was a mistake. For now I'll leave the shocks that way but if I decide to rebuild it should I use the two hole or the three hole pistons with the 30wt oil?
YR4Dude is offline   Reply With Quote
Old 02-20-2006, 02:33 AM   #3236
mate you must be kidding your self, the idea of shim's at those locations is for a very good reason, to make easy & quik adjustments to the car. have a look at tamiya if you wanna start complaining about shims.
xray probally has the least amount of shim's out of any tc i have owned & the idea xray have in place in a very good one. you can fully adjust the car setup without having to purchase toe blocks etc.
flysti is offline   Reply With Quote
Old 02-20-2006, 06:53 AM   #3237
ChrisP's Avatar
The shims on the rear hinge pins allow the adjustment of the wheelbase.
The shims between the roll center holders and bulkhead allow for adjustment of inboard rear toe and trackwidth.
The shim under the motor bulkhead is removable to allow the car to flex evenly when used on one of the flexible settings for the chassis' multi-flex technology.
And the shims on the outer end of the camber links are for roll center adjustment...you forgot those
ChrisP is offline   Reply With Quote
Old 02-20-2006, 10:20 AM   #3238
Send a message via Yahoo to hicheef
Default Build Day
I've been surfing the thread for a bit now and I've probably missed it but I have a couple Q's.
1.I'm building my kit today and I'm wondering do I really have to CA all of the countersunk holes on the bottom.(never had to do that one before)
2. Are my 04's diff's gong to fit in my T2 cuz I've got a couple one-ways a spring steel with carbides and a spool I really don't want to part with.
Thanks Fellow Xray addicts
Kevin
hicheef is offline   Reply With Quote
Old 02-20-2006, 10:30 AM   #3239
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
ahhhh yes and yes
still fishing
ALBERTO is offline   Reply With Quote
Old 02-20-2006, 10:40 AM   #3240
ChrisP's Avatar
Kevin
Sealng the screw holes will help strengthen them as well as prevent the screws from biting in and becoming difficult to remove
Your 04 Diffs and spool will be usable in your T2, but you will need 34t pulleys due to the T2's internal ratio of 1.70 as opposed to the 04's ratio of 1.77.
Your one-way isn't usable as-is, as the diffs are flipped 180* from their installation direction for the 04. This doesn't effect a diff or a spool, but for a one-way the one way bearing will be installed backwards relative to how it needs to be in order to function properly on the FK05 or T2.
