Old 02-18-2006, 01:26 AM   #3211
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Originally Posted by x-ray=speed
I just build the shock by first using a air-remover like the one above that Hara is holding, then undo the bottom cap and push the shaft in about 2-3mm which releases a bit of oil and twist the cap back on. This gives me a full re-bound which i like, i do this with the piston holes all open, then a change the piston hole to one open on the front and 3 open on the back, this all takes about 15 minutes. I love the shocks.
That thing looks like a penis pump, and if you ask me why I know that, my answer is Austin Powers #1, lol.
Also check this, this is what ill be wearing to the ROAR Nats, lol
Team Slovakia Hockey Jersey
JohnMatrix is offline   Reply With Quote
Old 02-18-2006, 06:34 AM   #3212
HarshGuy's Avatar
OK Nick, now you've "crossed the line", you're talking about penis pumps and telling us what you're going to wear
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-18-2006, 07:19 PM   #3213
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
why does it matter what ur going to wear
xrayaustin is offline   Reply With Quote
Old 02-18-2006, 07:39 PM   #3214
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I guess its so they can coordinate outfits for their brokeback moment?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 02-18-2006, 07:44 PM   #3215
xrayaustin's Avatar
lol
Old 02-18-2006, 10:00 PM   #3216
Michael Barch's Avatar
Send a message via AIM to Michael Barch
Shes done! I finished up last night.
I added 2 shims all around for the suspension arms to make the car wider, everyone at the track was telling me to so I did. I also picked up a battery strap for it and a better servo than the one I had (Hitec HS625MG). Now I have THE BEST- JR Z9000S Super High Speed Digital.
I bleed the shocks and I think there pretty good now, I hear no air and they don't have too much rebound, maybe 25% which in the manual it says it should have about that.
I let my cousin paint my body and he paints the thing on the outside... so that body is ruined... Im just going to have to pick up a can of white and paint inside that way if the outside paint falls off it will still look white.
I do have a question though, I went to solder my red battery connector to my battery (Positive) and it sparked... I did have the Negitive already soldered on there. So I said enough, just put some Deans on there and its fine...any idea why it did that though? I did tin the tip too...
One more question, is there anyway to solder the wires from the speed control back onto the speed control if they come out...I have a GTS.
Sorry Im new to all the fancy stuff, I used to just own a TC4...now I keep running all these XRAY's and Im winning the mains
0 Camber or 1 Camber?
Here are a couple pictures of my finished car, SORRY THERE WEBCAM. My digital camera is out of batteries at the moment.
Michael Barch is offline   Reply With Quote
Old 02-18-2006, 10:13 PM   #3217
JohnMatrix's Avatar
Click here for the answer to that.
Old 02-19-2006, 06:05 AM   #3218
DaveW's Avatar
Barch: Novak speedo's have been doing that since the Cyclone speedo came out years ago. The pop is the "polar drive"/"power cap" capacitor pulling power from the battery and taking charge. It may or may not do it from pack to pack, but likely will from week to week when you install a pack after it has sat for that amount of time. Its as normal as Novak gets. Yes the wires can be resoldered to your speedo, but if it is something you have not done before or you have very little experience doing it... i suggest giving it to someone that has the experience so you dont cost yourself alot of $$$.
Camber should start around -1.5.
- DaveW
DaveW is offline   Reply With Quote
Old 02-19-2006, 08:28 AM   #3219
Rob Phillips's Avatar
Team Slovakia Jersey = Xray's motherland.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 02-19-2006, 11:18 AM   #3220
Thanks DaveW.
Old 02-19-2006, 02:20 PM   #3221
nmt6789's Avatar
Send a message via AIM to nmt6789
Does anyone have any ideas on how to make the shcok tower beefier where the roll center holes are? I cracked my shock tower today and I didnt hit too hard. I saw the team tamale braces, has anyone used them yet?
nmt6789 is offline   Reply With Quote
Old 02-19-2006, 02:23 PM   #3222
ottoman's Avatar
R/C Tech Charter Subscriber
I run them... after I broke a tower... and havent had any more problems. They are kinda ugly though
ottoman is offline   Reply With Quote
Old 02-19-2006, 06:31 PM   #3223
Some of you changed the uprights on the T2 to teamtamale alu ones. Is this change solves the toe in issue?
Mike Barch: Are you sure that the body is ruined? Most of the bodies come whit a protective film on the outside. If your cousin forgot to remove it before painting then you could do it now and get rid of the outside paint.
Painting a body from the outside shows that he knows very little about them maybe he didn't know about the protective film too. If thats the case (you can figure it out by scratchting the paint on the outside), then paint it from the inside THEN remove the protective film from the outside.
cvt01 is offline   Reply With Quote
Old 02-19-2006, 07:24 PM   #3224
JohnMatrix's Avatar
Team Teamale braces.
Old 02-19-2006, 07:39 PM   #3225
he had it right ,its tamale.
stumper is offline   Reply With Quote
