NEW XRAY T2
Old 02-16-2006, 06:55 AM
  #3166
Joep's Avatar
Originally Posted by NOOB-SMOKE
i am after some alloy rear hubs where do i get.
They are not yet delevered to the distributors by Xray. But will be within a few weeks.
Joep is offline
Old 02-16-2006, 06:57 AM
  #3167
Joep's Avatar
Originally Posted by mi2dude
for all you guys who space the servo out so the servo arms isnt touching the top deck....
I just did NO spacers and cut a litlle of the topdeck away. No stiffness loss
Joep is offline
Old 02-16-2006, 09:33 AM
  #3168
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Originally Posted by harris
Anthony.L what kind of cerabic bearings you have put on the car??
APS Bearings from Magma in Canada.
Anthony.L is offline
Old 02-16-2006, 11:36 AM
  #3169
EricF's Avatar
How much are they?
Thanks,
E
EricF is offline
Old 02-16-2006, 11:51 AM
  #3170
Safer SX's Avatar
Has any one noticed on the 06 how much driveline vibration is in it when the car is on half the steering lock the car shakes uncontrollably is this another poor design fault for xray
Safer SX is offline
Old 02-16-2006, 11:56 AM
  #3171
Check if the tires rubbing the shocks...
The other thing I check frequently is the pins in the CVD's. when they got loose in the front they don't fall off but rub the knuckle from the inside causing vibration...
cvt01 is offline
Old 02-16-2006, 12:03 PM
  #3172
litespeed-dom's Avatar
Another??? What do you mean?
I don't have problem with vibration at all.
Dom
litespeed-dom is offline
Old 02-16-2006, 12:05 PM
  #3173
Anthony.L's Avatar
Originally Posted by EricF
How much are they?
Thanks,
E
Don't remember what I paid, probably around $90-100. Here is the site.
http://www.magmarc.com/
Old 02-16-2006, 12:30 PM
  #3174
Check your front driveshafts and make sure they arnt coming loose, and make sure they dont bind when they are at an angle.
CoryCraig is offline
Old 02-16-2006, 01:17 PM
  #3175
Ill Factor's Avatar
Dom
Yeah my drive train and steering are like butta as well
Are you running the multidiff in spool mode. Spools will often cause vibrations called chatter.
Ill Factor is offline
Old 02-16-2006, 01:22 PM
  #3176
Joep's Avatar
You're the first with this problem. Check the total setup.
And btw "... another poor design ...." is in my opinion very exaggerated! I like more balance in messages
And why why does the T2 (with off course good drivers) win so many races and international events!
Joep is offline
Old 02-16-2006, 01:57 PM
  #3177
When I first setup my car, I purposly made the belt extra loose and I experience d the same problem. I tightened up the belt to stock setting and made sure the steering throw wasn't too drastic and the vibration went away.
EVILGRAFX is offline
Old 02-16-2006, 01:59 PM
  #3178
DRKWNG's Avatar
I had one of the drive shaft pins come loose and didn't realize it. It bent the drive shaft and when I turned it would lock up. Very important to check those before every run!!!
DRKWNG is offline
Old 02-16-2006, 06:25 PM
  #3179
awtwac's Avatar
Default TAP
Hi, I'm about to build my T2 and was hoping that one of you guys can tell me which pitch of 3mm tap to use for prethreading holes? Thanks!
awtwac is offline
Old 02-16-2006, 07:57 PM
  #3180
I'm having trouble building the shocks on my T2.I've been racing for years and these have given me the most trouble.Any tips? Thanks
outlandr91 is offline
