Old 02-07-2006, 12:42 AM   #2881
Hello
somebody can tell me where can i buy some parts for T2.
I asked in France but no body have parts !
Thank you very much
stefb is offline   Reply With Quote
Old 02-07-2006, 03:42 AM   #2882
Stusdal's Avatar
my bad
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 02-07-2006, 03:51 AM   #2883
Chris08527's Avatar
Trader Rating: 16 (100%+)
Originally Posted by lbckevin
Chris08527,
Team drivers and any driver entering a big sanctioned race must be at min. weight. Drivers add the weight to be legal and place the weight to balance the car.
ibckevin
yes i understand that about a min. weight, i am wondering if maybe the car is a little naturally unbalanced and people are not adding weight to one side and maybe they are actually tweaking the car on a hudy/mip/scales so it is "not tweaked" and then after a run one small hit or something and the car goes back and now it is "tweaked"
sounds funny i know but i think you understand what i am trying to say
my original question
"how many of the people that had these "tweak" issues were adding weight to the car???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 02-07-2006, 07:04 AM   #2884
Send a message via Yahoo to CoryCraig
Originally Posted by Chris08527
ibckevin
I have added no weight ( 1500grams spot on with IB 3800's and a 19t ) and i have no tweak issues.
CoryCraig is offline   Reply With Quote
Old 02-07-2006, 09:58 AM   #2885
imr
imr's Avatar
Originally Posted by stefb
Hello
Thank you very much
Did you check wartelle modelisme?
I'm from Belgium and sometimes buy stuff there and he has lots of T2 in stock.
He also sells by website.
imr is offline   Reply With Quote
Old 02-07-2006, 10:02 AM   #2886
Hello
Thank you very much
Today we arrive car kit & spare parts ,
if nostock we can open car kit inside parts sale to you !
Thankyou !
Leo
HKRCMODEL is offline   Reply With Quote
Old 02-07-2006, 04:44 PM   #2887
raptor 700's Avatar
What parts are interchangeable with the 05? I did try to search and nothing came up. Thanks
raptor 700 is offline   Reply With Quote
Old 02-07-2006, 04:47 PM   #2888
Hebiki's Avatar
Trader Rating: 26 (100%+)
from what i remember, the multi diff, the diff, and belts. i dont remember the rest. sorry.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-07-2006, 05:21 PM   #2889
HarshGuy's Avatar
This is from Xray's forum:
Originally Posted by xrays forum
People were asking for a list of parts which can be used on the '05 and T2:
Item Description
302551 SERVO SAVER PLASTIC COVER - ECCENTRIC (2)
302580 COMPOSITE SERVO HORN - KO, JR, AIRTRONICS, MULTIPLEX
302582 COMPOSITE SERVO HORN - FUTABA, ROBE
303060 GRAPHITE MOTOR GUARD
305002 BALL DIFF. WITH LABYRINTH COVERS™ - (FACTORY KIT)
305040 SCREW FOR EXTERNAL DIFF ADJUSTMENT - SPRING STEEL
305050 DIFF PULLEY 34T WITH LABYRINTH DUST COVERS
305082 DIFF WASHER 17 X 23 X 1 (2)
305102 XRAY MULTI-DIFF
305131 INNER DRIVESHAFT ADAPTER - SPRING STEEL (2)
305150 TIMING BELT PULLEY 34T FOR FRONT ONE-WAY DIFF.
305240 DRIVE SHAFT REPLACEMENT PLASTIC CAP 3 MM (4)
305431 HIGH-PERFORMANCE KEVLAR DRIVE BELT FRONT 3 X 507 MM
305442 HIGH-PERFORMANCE KEVLAR DRIVE BELT REAR 3 X 180 MM
305575 FIXED PULLEY 20T (2)
305784 SPUR GEAR 84T / 48
306131 SET OF BATTERY BACKSTOPS T1FK'05
306200 ALU SERVO MOUNT (2)
306300 ANTENNA MOUNT
306310 ANTENNA TUBE (2)
308035 COMPOSITE PISTONS - ADJUSTABLE + NON-ADJUSTABLE (SET 2+6)
308040 SHOCK ADJ. NUT ALU + O-RING (4)
308080 SHOCKABSORBER MEMBRANES (4)
308090 SHOCK FOAM INSERTS (4)
308380 ADDITIONAL XRAY ULTIMATE RACING SPRINGS (20)
308390 XRAY SELECTED ULTIMATE RACING SPRINGS (24)
309319 UNIVERSAL SET OF PLASTIC SHIMS
309500 SILICONE GREASE 00
309530 SILICONE OIL 30W
901304 HEX SCREW SB M 3 X 4 (10)
901308 HEX SCREW SB M 3 X 8 (10)
901408 HEX SCREW SB M 4 X 8 (10)
902305 HEX SCREW SH M 3 X 5 (10)
902306 HEX SCREW SH M 3 X 6 (10)
902308 HEX SCREW SH M 3 X 8 (10)
902310 HEX SCREW SH M 3 X 10 (10)
902312 HEX SCREW SH M 3 X 12 (10)
930120 CARBIDE BALL 2.4MM (12)
930138 CARBIDE BALL-BEARING AXIAL F3-8 3X8X3.5
930407 BALL-BEARING MR74ZZ 4X7X2.5 (2)
930508 BALL-BEARING MR85ZZ 5X8X2.5 (2)
941015 HIGH-SPEED BALL-BEARING 10X15X4 RUBBER SEALED (2)
960030 NUT M3 (10)
961032 WASHER S 3.2 (10)
963030 CONE WASHER ST 3X8X0.5 (10)
963041 CONE WASHER ST 4X12 (10)
965019 E-CLIP 1.9 (10)
965023 E-CLIP 2.3 (10)
965040 E-CLIP 4 (10)
965050 E-CLIP 5 (10)
966080 CH-CLIP 8 (10)
970050 O-RING 5X1 (10)
970100 O-RING 10 X 1.5 (10)
970121 O-RING 12.1X1.6 (10)
971031 SILICONE O-RING 3.1X1.6 (10)
981210 PIN 2X10 (10)
981212 PIN 2X12 (10)
And off course the pinions.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 02-07-2006, 06:10 PM   #2890
jbenthobbies's Avatar
Default new xray t2
To answer everybodies question on the added weight. The min weigtht for touring foam is 1418 grams for rubber 1525 for rubber the added weight that you see with the factory drivers is to make the min weight. The reason why it is put were it is all Roar tracks go clockwise with means having the weight on the right side helps the when most of the turns are right handers. Which balances the car out on wear. I have a 800.000 longacre digital scale setup that I have checked this weight distribution and it works perfect.
AKA, KO, EAMotorsports, Redsrc. Capricorn
jbenthobbies is offline   Reply With Quote
Old 02-07-2006, 08:25 PM   #2891
Cefx raceway in Michigan has T2 parts.
Biff Malibu is offline   Reply With Quote
Old 02-07-2006, 09:27 PM   #2892
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by protc3
3/8 diameter is all you will need.the countersink is going to be 1/4" diameter when you are done.
protc3: some people say countersinking will help with the tweak issue, some say it wont .... what is bmi's take on this given the bmi chassis that have been put out all have countersunk top decks? how does countersinking help? is it just to ensure there is less movement of the upperdeck?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 02-07-2006, 10:15 PM   #2893
Hello
Thank you very much
If you live in Europe you can also check this guy out. T2 parts (and others of course) at very very good prices.
http://eshop.rcring.com/index.asp?pa...14097&manuf=90
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
Old 02-08-2006, 03:46 PM   #2894
ChrisP's Avatar
Now that parts have shipped to the shops, it's amazing how quiet things have gotten in here
Is everyone at the tracks?
ChrisP is offline   Reply With Quote
Old 02-08-2006, 04:09 PM   #2895
litespeed-dom's Avatar
Parts? What parts? East Coast maybe.... we on the West Coast got nothing!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
