Old 02-06-2006, 06:57 PM   #2866
protc3's Avatar
Originally Posted by Rob Phillips
I don't think there is enough meat there to counter sink the stock top plate, but I beleive metric screws are a 85* bit and they can be hard to find. I checked MacMaster-Carr and they didn't have what I needed. Maybe some else can chime in and help out.
metric screw heads are 90 degrees.they are available at mcmaster carr,MSC,or a local home depot.go with a good c'snk for the carbon fiber.you dont want to get a bad finish on it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-06-2006, 06:59 PM   #2867
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Thanks Jason!
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 02-06-2006, 07:02 PM   #2868
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-06-2006, 07:07 PM   #2869
jaysimpson's Avatar
Also what diameter will be best? I found the countersinks but not sure on the diameter.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 02-06-2006, 07:43 PM   #2870
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
Originally Posted by jbenthobbies
I seems to me that watching what everybody dislikes is a slight toe issue which I average out what people have complained about to be around ten thousands of a inch. The gap on your spark plugs in your car are more than ten thousands. That is so nominal we need to forget that and move on. In some industries that is within standards unless your NASA. This isn't rocket science. Lets help Xray with their car to stay the best in the world, and dominate this year.
AMEN...
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 02-06-2006, 07:47 PM   #2871
protc3's Avatar
3/8 diameter is all you will need.the countersink is going to be 1/4" diameter when you are done.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-06-2006, 07:48 PM   #2872
jaysimpson's Avatar
Thank you sir.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 02-06-2006, 07:48 PM   #2873
protc3's Avatar
countersunk hole will be 1/4 inch diameter that is.carbon fiber isnt that bad to cut.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-06-2006, 07:51 PM   #2874
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys
been reading alot of people with the "tweak" issues i have a T2 but did not race it yet
but i was checking out the x-ray team drivers set ups on xray.com and many if not all of the team drivers at the novak race were adding 10g up front batt side and 5 g rear batt side and blackstock added 14 g front batt/7g rear batt side . . .
so i guess my question comment is "did everyone that had this "tweak issue" also have weight added to the car??? or was that a make weight thing for the race???
Chris
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 02-06-2006, 09:01 PM   #2875
J@UNE's Avatar
Default Stiffness
Hey guy, I just put my CRC top deck and the car is so stiff!!!! Do you think it can be too much? I removed the post and its still as stiff as my carpet fk05.
BTW It fit strait and nicely on my car
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 02-06-2006, 09:50 PM   #2876
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by andrewdoherty
Mikes Hobby Shop in Dallas
www.mikeshobbyshop.com
I am headed to the track today for practice and will try the shorter T2 shock ends.
I was there today and they had parts on the wall. Call them if you want to try to get something shipped. I will also mention that the aforementioned 4 pack of shock ends worked flawlwessly on the 05. Just make sure to replace them in sets to ensure equal shock length L to R as they are a bit shorter than the original 05 shock ends.
Old 02-06-2006, 11:20 PM   #2877
lbckevin's Avatar
Trader Rating: 91 (99%+)
Chris08527,
Team drivers and any driver entering a big sanctioned race must be at min. weight. Drivers add the weight to be legal and place the weight to balance the car.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 02-06-2006, 11:22 PM   #2878
litespeed-dom's Avatar
Has anyone weigh their 3800's in comparison to servo, esc, receiver, motor???
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 02-06-2006, 11:28 PM   #2879
Chris Adams's Avatar
Litespeed,
the motor side weighs more on my car by at least 100 grams if not more. This is with a low pro servo, gtx and futaba hrs reciever, and stock motor. You have to add weight to the other side because of how it is distributed. The motor will stick out and make the car unevenly balanced left to right. Put it up on the hudy pins and see which way it leans. I have at least five grams right behind my motor...
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 02-06-2006, 11:36 PM   #2880
Ok, reason I asked... and here goes.
My IB's seems to weight a lot more than my electronis (19T or mod motor), I have to put more spring loads on that side to get the chassis to be flat and ride height even on both sides. Before anyone says the word "tweak", the tires are even all the way around, droop the same and chassis flat as a piece of glass on the setup board.
So theory behind putting more weight on the already heavier (batteries) side..... since I'm putting more load on the springs, I put weight on that side so counter the extra springs load.
I just want to check my thinking here with everyone.
Dom
