NEW XRAY T2
#2851
Originally Posted by rcfiend
Hey does anyone know if the thrust balls and diff balls from the Corally RDX will fit the T2?
Aparently the JRX-S thrust race flying saucer style thrust races fits the RDX
Cheers Malc THE CAN MAN
#2853
Originally Posted by Trakside Trucke
Hi
#2855
anyone have a countersink bit size and supplier to do the top deck?
#2856
new xray t2
Originally Posted by James
nice one. I'm on medium to low grip also. I started with kit rubbers setup with medium chassis but have now moved to this setup:
fr:
shocks 3rd hole in on top
30wt, kit spring, 3holes open
5mm, 2.5mm droop (measured by manually raising car and measuring difference off the ride height)
low roll-centre with arms angled upward (0.00fr of arm, -0.75rr of arm) pro-dive? hrmmmm.
1deg neg camber, 0.5deg toe out
rr:
shocks 4th hole in from top
5mm, 4mm droop measured as above (as per setup book describes)
1deg neg camber, 3deg toe in
full soft chassis setup but middle bulkhead brace left in.
one-way multi-diff, med to med-high rr diff, pretty loose main belt
car is still a bit skatey in the back end. (back slides out easily). I'm going to order the front light blue (1.6lb) and rear yellow (1.4lb) springs to see how that changes things. Otherwise all other settings are as per the kit.
This is on CS-32's on a mixed, med grip track. (has a fast straightway, mid-speed mid section and very tight in section. almost all corners/turns are 180deg hairpins, much like you'd see on a poly-pipe carpet track.
I need a setup that I can change quickly for a simular speed carpet track on rubbers. At the moment I run the same setup, but go a stiffer chassis.
this setup changes directions very very fast, even with the kit-setup long wheelbase. impressive but almost overkill!
Is it possible that my 2.5 front droop is causing the back to spin out easily? more droop up front required?
James
fr:
rr:
James
Chassis set in meduim setting. Shocks in stock rubber position front and rear. 25 weight Associated oil all around, blue green spring in front with 3 holes open. In the rear yellow spring with 4 holes open. Keep roll center at lowest position. droop in front at 2mm and 3mm in rear. standard rear toe . use RP 30 tires with sxt traction compound. Mazda body. Use one way not spool. Ackerman in rubber position.
#2857
new xray t2
#2858
#2859
#2861
what is macmasters-car's web site and dace manufacturing
#2862
Originally Posted by zinger77
who has parts in stock,anyone?
My shop owner called RC America today, our shipment was being shipped out today. It's funny how shops in Texas has shipment on Thursday already and our were just shipped today, but at least it's on the way.
Dom
#2863
#2864
Originally Posted by litespeed-dom
You're in NY, I was told www.nychobbies.com has them, but don't quote me on that.
Dom
Dom
#2865
I would'nt be suprised if they sold out. They were the only shop in the area to have parts, on Friday. And with all the people in the area with the T2, they probably got tapped out.
