Old 02-05-2006, 04:05 AM   #2791
corallyman's Avatar
Trader Rating: 99 (100%+)
Default Stand-offs
DA,
My 30 6511 measured 1.075 inches or 27.32mm and that is the rear.
My 30 6512 measured 1.003 inches or 25.48mm front.
Steve
corallyman is offline   Reply With Quote
Old 02-05-2006, 04:14 AM   #2792
Originally Posted by corallyman
DA,
Steve
Great, thank you
DA_cookie_monst is offline   Reply With Quote
Old 02-05-2006, 06:26 AM   #2793
beyondthepack's Avatar
Send a message via Yahoo to beyondthepack
Probably beating a dead horse here, but I'm Looking for a new diff, for my T2, what is the difference between the Kit Dif 305001 and the spring steel diff 305002 other then the obvious material change, can I use the spring steel diff 305002 for my T2. Didn't mean to pest just didn't wanna blow $60.
AE B5R - SC10.2 - Outdoors
AE TC7.1 USGT - INFINITY IF14 - Indoors
LRP - REEDY - FUTABA - IDEAL HOBBIES - RC404
beyondthepack is offline   Reply With Quote
Old 02-05-2006, 06:26 AM   #2794
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
i raced my T2 last night for the first time man what a ride . yes my car rear toe is off by .05 on leftside . my hpi pro4 was off also and have alot of play around the suspension front and rear. what car i like the best is the new T2. this is my first Xray car and man what a differents i'm hooked on this car my lap times are better and the car handles like a dream
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 02-05-2006, 06:32 AM   #2795
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Pretty much the material change is it with the only other difference being that the Spring Steel version is not factory assembled. That of course can be good or bad depending on if you wanted to build your own diff or not.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 02-05-2006, 06:43 AM   #2796
kewl, so I can use the 305001 spring steel diff for the T2.....so they give specific instructions how to build they're diff right? I know opions vary, just don't want to f___ it up. Thanks for your help. Hopefully Stormer has some left...
Old 02-05-2006, 08:32 AM   #2797
ghoppa's Avatar
Trader Rating: 54 (98%+)
Originally Posted by lbckevin
Brit....what are you doing up so late....staying up for superbowl...?
Some of the problems have come from guys not putting the car together incorrectly....IF we can help, it will make more happy racers...
Hey lbckevin:
what gears (pinion & spurs) are you guys running for stock & 19 turn @ SoCal????
48 or 64 pitch???
What final gear ratio are you guys "around"???
I might make a trip down in the next month or so...
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 02-05-2006, 08:43 AM   #2798
Joep's Avatar
Originally Posted by nmt6789
Hass anyone had a problem with the servo horn rubbing the top deck? I have a s9451 servo and I had to shim it to get it to fit right. I guess the only was around it would be putting diffrent shims in.
I did a little change to the topdeck (took some material away) and do NOT use shims anymore. It did not really change the stiffness of the car.
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
Old 02-05-2006, 09:42 AM   #2799
jaysimpson's Avatar
Yeah if I recall it will come with instructions and the T2 manual covers the full assembly of the diff as well. I recommend you getting some snap ring pliers; makes it a little easier. You pick them up at Lowes or Home Depot.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 02-05-2006, 10:08 AM   #2800
Trader Rating: 45 (100%+)
Default Sway bar on T2
I heard some racers are putting a sway bar up front on the T2's using other manufacturer's parts. Anyone know the part/part numbers being used?
Apex is offline   Reply With Quote
Old 02-05-2006, 10:16 AM   #2801
jaysimpson's Avatar
I know Eric Anderson (EA Motorsports) used the Fk05 front sway bar and used collars to center it and used rear mounts to hold it down. If that helps any.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 02-05-2006, 10:25 AM   #2802
litespeed-dom's Avatar
I used my RDX sway on the front and just used FK04/05 rear sway hardware. Like EA, I have to use collars to center the sway.
You do have to trim the RDX sway down a bit.
RDX 1.3mm bar
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 02-05-2006, 10:52 AM   #2803
dawgmeat's Avatar
Default fan
this is not my car but I think it may be 3racing I'm not sure?
dawgmeat is offline   Reply With Quote
Old 02-05-2006, 11:00 AM   #2804
Crashmaster's Avatar
I beleive that it is a Cool-Can-Fan. The guy who makes them has a thread on here, aswell as a web site:
www.coolcanfan.com
Cheers
Dan Chambers
Crashmaster is offline   Reply With Quote
Old 02-05-2006, 11:13 AM   #2805
Shop Owner
nnick's Avatar
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
Originally Posted by OHBRAD
hi
has any one noticed the pinions don't mesh with the spur correctly
regards
brad
Not really, can you explain what the problem is?
I use PRS, Kimbrough spurs and TIR, Robinson Racing pinions
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
