Old 02-04-2006, 10:40 AM   #2716
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Originally Posted by DennisNyholm
I assume he means the place in my signature.
No I actually couldn't wait for them for the parts. I got them at www.nychobbies.com they got the shipment in yesterday.
HRCRACER123 is offline   Reply With Quote
Old 02-04-2006, 01:34 PM   #2717
DennisNyholm's Avatar
Does anyone actually know if the new shipments of T2's are going to have any changes over the first and second shipment? I'd like to pick one up, but I am concerned about some of the minor issues that seem to be arising. I don't beleive that the issues will really effect me since I am not good enogh to notice, but i'd like to know that it is the driver and not the car!!
DennisNyholm is offline   Reply With Quote
Old 02-04-2006, 02:23 PM   #2718
nmt6789's Avatar
Send a message via AIM to nmt6789
Hass anyone had a problem with the servo horn rubbing the top deck? I have a s9451 servo and I had to shim it to get it to fit right. I guess the only was around it would be putting diffrent shims in.
nmt6789 is offline   Reply With Quote
Old 02-04-2006, 02:34 PM   #2719
lbckevin's Avatar
Trader Rating: 91 (99%+)
most guys had to shim the servo, no big deal , since Xray gives you the shims in the last aid bag.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 02-04-2006, 02:34 PM   #2720
jbenthobbies's Avatar
Default Xray t2
I have one of the first cars that came into this country. The only problem that I see with the car is the top deck needs to be countersunk to make the care more rigid and keep in better tweek. This problem has already been addressed and Xray as we speak is already testing the solution. The other problems that so called exist, don't. People have to find something to complain about. I have been in this industry for over 30 years, and have five national championships to my credit. The Xray cars have been the only car in the industry. That you can build out of the kit and go out and be competitive without spending hundreds in upgrades and hours in triming the flashing and trimming parts to make them fit properly as well as to make the car free, let alone Xray uses the best materials on the market. Like I stated in a earlier post if you look at the Xray from a engineering standpoint Hudy is the only one in this industy that has a clue of what they are doing. Plus they have a team that works as one to make the product better. Not to mention they have some of the best drivers to pull from.
AKA, KO, EAMotorsports, Redsrc. Capricorn
jbenthobbies is offline   Reply With Quote
Old 02-04-2006, 02:37 PM   #2721
lbckevin's Avatar
Well said Jim.
Kevin Smith
Old 02-04-2006, 02:49 PM   #2722
Rob Phillips's Avatar
Ditto
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 02-04-2006, 03:02 PM   #2723
Ill Factor's Avatar
With an attitiude like that I would make sure to NEVER buy anything from your shop!!!! There legitimate issues. I suppose my chassis delamenating after one race day is no big deal, people having to shim there cars just to make them right I suppose is no big deal. Man if this is Luxury then I havent been missing much.
Would it be no big deal if someone wrote you a hot check to buy something.
There is no question the car is fast, but we didnt pay for just fast now did we?
Ill Factor is offline   Reply With Quote
Old 02-04-2006, 03:07 PM   #2724
Default xray t2
There are ways to prevent delamination did you prep the chassis with CA?
Old 02-04-2006, 03:19 PM   #2725
Default xray t2
I would love to know what these shimming issues that people are talking about I have a complete tramel bar set up that I use to set up my RC cars just like I use on my big race cars. I can check bumpsteer, weight transfer, trackwidth, anti dive and squat. I also have a masters in manufacturing. I have set my chassis on cad program to to plot out the chassis to see if it was manufactured wrong, such as holes and chassis not square things of that nature. There was no problem found. Wouldn't you think since I have one of the first batch of cars I would find this problem, espically to the extent that I went to to find a problem. If there was a delamination problem with the chassis and the chassis was preped, something would have to be hit pretty hard.
Old 02-04-2006, 03:36 PM   #2726
ooliganRC's Avatar
Send a message via MSN to ooliganRC
just checked my rear toe in with regard to all your posts.
i see no major flaw i fo have a difference of .25-.5 of a degree on the right side, im using the standard hinge pin holders with 1 washer up front and 2 at the back...
rear toe of 1 on left 1.25ish on right
no real biggy
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 02-04-2006, 03:41 PM   #2727
Default xray t2
Did you check the rear toe with hudy gages? The use an acual metal plate attached to the hub with the car sqaure inside the tramel bars. That is the way that the big cars in racing set the suspension. That is the most flawless method of checking.
Old 02-04-2006, 03:44 PM   #2728
Default xray t2
If that is true that the toe in on the rear hubs are two hundred and fifty thousands off that could just be from bearing tolerances.
Old 02-04-2006, 03:51 PM   #2729
RCknight's Avatar
Default Servo mounting....
The two mounting holes on the chassis need to be connected. I can't get my KO servo mounted solid because the rear servo mounting block is out too far out.
RCknight is offline   Reply With Quote
Old 02-04-2006, 04:13 PM   #2730
nmt6789's Avatar
Just finished
