Old 01-24-2006, 02:54 PM   #2206
Rear end temporary fix. Use the FK05 rear hubs and drive shaft components. No toe end problems, no spare part problems.
PhatPat is offline   Reply With Quote
Old 01-24-2006, 03:35 PM   #2207
xtreameracer's Avatar
Send a message via Yahoo to xtreameracer
i was told associated c hub would work on the t2
xtreameracer is offline   Reply With Quote
Old 01-24-2006, 03:46 PM   #2208
Carbuncle is offline   Reply With Quote
Old 01-24-2006, 03:47 PM   #2209
Originally Posted by HRCRACER123
Also I heard from another racer who was at the Magma race this past weekend in Canada that Mike Blackstock actually split his T2 chassis in a crash and luckily he had another one. But get this I heard the new graphite chassis he replaced it with was a 3mm not a 2.5mm which is crazy. Because this car was supposed to be able to run on asphault and then be able to hit up a carpet track with a couple of changes. Just thought i'd let you all know that. 3mm chassis huh...
I know a team driver and he told me that in addition to the stock 2.4mm chassis the Factory Team has access to a 1.8mm and 3mm chassis.
Old 01-24-2006, 04:34 PM   #2210
kewdawg's Avatar
Did you guys, actually, believe Xray wasn't going to raid your wallets for an aftermarket chassis? That's way too many sales to miss out on.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-24-2006, 05:22 PM   #2211
dawgmeat's Avatar
Default Sway Bars
Got the idea from Mark Smyka, you need the sway bar linkage from the 05, front 1.2mm sway bar for the RDX and set of wire cutters to remove the end tips
dawgmeat is offline   Reply With Quote
Old 01-24-2006, 05:23 PM   #2212
dawgmeat's Avatar
forgot one thing, you will also need the ball ends from the XXX-S front sway bar kit
Old 01-24-2006, 05:29 PM   #2213
ogreasurada's Avatar
The T2 doesnt come with sway bars? Or it doesnt need them....
ogreasurada is online now   Reply With Quote
Old 01-24-2006, 05:53 PM   #2214
Default Backwards Pinion???
I'm trying to attach my motor. It appears that the pinion must be installed "backwards" in order to fit. Has anyone else had this issue? It seems that the motor sits too close to the spur gear, which requires the reverse position to get optimal contact between the spur and pinion. The only other option I see is to shim between the motor and the motor mount. Maybe this is preferable, but it seems difficult to install this way. What do you guys think?
MasterBlaster is offline   Reply With Quote
Old 01-24-2006, 06:01 PM   #2215
i just installed mine backwards, saw no issues with doing it that way, still made good contact with the motor
6g72tt is offline   Reply With Quote
Old 01-24-2006, 06:04 PM   #2216
That's completely normal, just install the pinion backwards and have fun
mguebert69 is offline   Reply With Quote
Old 01-24-2006, 06:58 PM   #2217
TeamButter's Avatar
Send a message via AIM to TeamButter
FYI....The front sway bars from the 05' work on the T2. You can also use the rear sway bar mounts. If you had or have an 05' you don't need to buy more parts.
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 01-24-2006, 07:08 PM   #2218
Rob Phillips's Avatar
Originally Posted by EAMotorsports
DAMN IT...dont touch the walls!! I think I messed in my pants!!
EA
Got me too!
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 01-24-2006, 07:36 PM   #2219
stiltskin's Avatar
Trader Rating: 102 (100%+)
I believe that the front C-hub/knuckle/axle combo from the '05 work also. Of course that adds all of that "unsprung weight" back into the package.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 01-24-2006, 08:30 PM   #2220
I just found out that sheldon hobbies has 5 xrays t2 in stock
ptjonesus is offline   Reply With Quote
