Old 01-19-2006, 06:19 PM   #1996
Originally Posted by zinger77
heys guys , what should my downstop be with 60mm tires?
anyone with help?
zinger77 is offline   Reply With Quote
Old 01-19-2006, 06:29 PM   #1997
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Twin-Kyle
Make sure you don't have a broken arm or upright.Also make sure that the pivot arm pin isn't bent.
Did you hit anything with it??
Also...make sure that the shims are the right sizes.
That all I've got....
I have not even driven the car yet. I suggest everybody check there rear toe in. This might be with all T2's.
HRCRACER123 is offline   Reply With Quote
Old 01-19-2006, 06:30 PM   #1998
Roger's Avatar
Originally Posted by Juan Aveytia
Harsh, why didn't you counter sink everyhole, including the aluminun. I gotcha beat. Looks real good.
Harsh and Juan: I went to Gilroy today for some practice with the T2 using a 19T motor. Guess what ? My average time was a 12.7 with the majority of my times being under 12.9 seconds. Fastest lap time..................12.4 seconds. Looks like we'll be dipping into mod times at Gilroy with our T2's !!!!
See you at the races.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 01-19-2006, 06:48 PM   #1999
Hebiki's Avatar
Trader Rating: 26 (100%+)
Roger..what happened to the RDX?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-19-2006, 07:57 PM   #2000
anyone with help?
Droop should be like 2mm above ride height on average.
Old 01-19-2006, 07:57 PM   #2001
Trader Rating: 4 (83%+)
Send a message via AIM to letitroll
My left rear toe is 1 deg and right is 1.5 deg. My plan was to use .5mm shims on each side to achieve 1.5 deg of toe. I'm actually using .75mm on the left and .5mm on the right in order to ballence it out. Must be a poor mold or something...
letitroll is offline   Reply With Quote
Old 01-19-2006, 10:05 PM   #2002
HarshGuy's Avatar
Were you using David's setup?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-20-2006, 12:10 AM   #2003
Roger's Avatar
Almost the same, just made afew changes to the rear. Dave's set-up is pretty easy to drive at Gilroy. But, a stockton set-up wil be totally different than Gilroy's track.
Old 01-20-2006, 01:14 AM   #2004
About the rear toe in...
imho it is a manufacturing tolerances problem of the chassis and/or the bulkheads. Ive tried to twist the rear bulkhead assy and this will have an impact on the rear toe, but I cant get it symmetric. At the x-ray site there are reports as well and at my local track we have seen this issue also. So far there are no official statements from xray regarding this.
fulcrum2 is offline   Reply With Quote
Old 01-20-2006, 04:49 AM   #2005
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Tornado_Racing
Just to let you guys know, PRS offers 112, 114, 116, 118, and 120 TC spurs. All of these spurs will now include the countersunk holes so they will be a direct fit for the T2.
Just went on their website. How do you specifiy or know which ones have the countersinking in them?
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 01-20-2006, 05:51 AM   #2006
Send a message via Yahoo to CoryCraig
look at them you will seee the counter sunk holes.
CoryCraig is offline   Reply With Quote
Old 01-20-2006, 06:44 AM   #2007
Tornado_Racing's Avatar
All inventory was updated with the countersink holes. So if you were to purchase any Touring spur they will include the countersink holes. We have not had a chance to update the pics on the web site yet but new pics will come.
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 01-20-2006, 07:26 AM   #2008
I tried that too and a bunch of other stuff too but nothing worked.
This is crazy! I cant believe X-Ray would send these kits out, So far me,You and a bunch of other people are having the same problem. I mean I know I can shim it out to even it but this is weird because the rear king pins will be on diffrent angles. also one cvd would be in the outdrive more than the other.
The whole thing just pisses me off.
The rear toe is off a whole degree from left to right and everything is shimmed the same on both sides.
I am sure there are alot of drivers out there that have this same problem but just did not check it. I dont know this just sucks..
Old 01-20-2006, 07:27 AM   #2009
Originally Posted by stonedgti
Using anthing larger than a 116 is pretty dangerous, because the gear will sit almost flat with the bottom of the chassis. I wouldn't do it, unless you couldn't get the right gear ratio without it. It is definitely pushing it if you run asphalt. Just stick with a spur that fits and will provided enough gearing options. I personally don't see a reason to go up that high. I run 112 and 114 spurs mostly, and they've been doing the job for both 19t and stock.
Have there been any problems with getting pinions and spurs to mesh with the T2? I know on my FK 05 there are certain combonations that will not allow the two to mesh up. Basically the motor needs to be able to slide towards the back of the car and it cant due to the way the motor plate is designed (cut out). Thanks for any information as I am looking to get the T2.
xxxdave is offline   Reply With Quote
Old 01-20-2006, 09:05 AM   #2010
teamgp's Avatar
Originally Posted by RCknight
Team GP....haaaaa....I see. I guess it looked centered to me regarding the camber link thingy.
I had to actually mount the tab in several positions before I clearly understood it myself.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
