Old 01-19-2006, 11:33 AM   #1981
Send a message via AIM to munrath
Carl - Give me a call buddy.
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 01-19-2006, 12:48 PM   #1982
We received a couple of calls regarding the availability of 116t spur gears. We are currtently sold out on them and are waiting to see if JWerks japan will be making more.
Honestly, most of the factory drivers here are using either 112 and 114. If you use the Atlas, Orion, Reedy 19t motors or mod motors, you'll find that you might not be able to fit the bigger pinion on, depending on your foam tire size with a 116 or 118 spur. With the same tire size, pinion and motor, we calculated that you will only need to gear it up half a tooth on the pinion to get the same rollout as a 116 spur with a 114t. On foam, we believe the 114t spur would be the happy medium for stock or 19t, if you want to run mod, 112 would be the better selection.
On rubber tires, we've found that the 112t is a happy medium for pinion range if you run both stock and 19t.
JWerks is offline   Reply With Quote
Old 01-19-2006, 12:57 PM   #1983
HarshGuy's Avatar
Originally Posted by HRCRACER123
Oh so Harshguy just quoted the wrong person. I got ya. Thank You..
I was so confused.
No I quoted the right person ...with you I was talking about the 6 mm hexes, I put the on the car and the Jaco Foams *barely cleared* the knuckles as per the picture.
With Juan was a whole different conversation, I was talking to him about how he went about countersinking the top deck, and based on his information I countersunk mine, but was afraid to do the thin part of the piece that goes over the spur gear.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-19-2006, 12:57 PM   #1984
HarshGuy's Avatar
Originally Posted by STLNLST
Did that rookie quote RDX info on the T2 thread again....LOL See ya on the 28th.
I think you should wear a dress with the mullet.
Old 01-19-2006, 01:09 PM   #1985
smyka's Avatar
Send a message via AIM to smyka
just to let everyone know a 120 prs spur is the biggest you can fit woithout it hanging under the chassie the other thing i noticed is i shimmed my arms out 3mm instead of the 1.5 to make the track width 190 mm (i run foam tires)
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 01-19-2006, 01:51 PM   #1986
RCknight's Avatar
Default James buddy...
Originally Posted by James
I setup my GTX much like the xray team drivers from pics of the novak race? or some race. the gtx is on it's long back edge, with the cap behind the esc, works out real nice, wiring is trick too. pic of what im talking about attached (if you can see)
as for gearing, it really does depend on your track.
I run a 7.5 FDR on our track, asphalt/rubbers. it's not a very big track, and is mixed with a fast/medium and technical section.
eye your fastest and most skilled opponents cars and try gear to match that (if your completely unsure). or ask someone what their rollout/FDR is on that track.
where did you get the heatsink? Is it a 3Racing fan? I thought the 3Racing one was different.
Team GP....haaaaa....I see. I guess it looked centered to me regarding the camber link thingy.
RCknight is offline   Reply With Quote
Old 01-19-2006, 01:55 PM   #1987
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Originally Posted by ralph m
Hi Carl,
The 1.5mm spacers are considered "track width" spacers and used on the front and rear of every suspension holder. The extra 1.5mm spacer in the rear holder of the rear arm hinge pin provides too much toe (for carpet) and it's replaced with the .75 mm spacer. If you left that .75 mm spacer out, you would have only the 1 degree of toe provided by the hub.
Ralph
Understood...thanks Ralph...good luck at the winter nats
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 01-19-2006, 02:59 PM   #1988
What brand foams are you running to still be able to bolt them on with that much shimming and not stripp the wheel?
Juan Aveytia is offline   Reply With Quote
Old 01-19-2006, 03:02 PM   #1989
Tornado_Racing's Avatar
Just to let you guys know, PRS offers 112, 114, 116, 118, and 120 TC spurs. All of these spurs will now include the countersunk holes so they will be a direct fit for the T2.
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 01-19-2006, 05:04 PM   #1990
heys guys , what should my downstop be with 60mm tires?
zinger77 is offline   Reply With Quote
Old 01-19-2006, 05:05 PM   #1991
hpipro321's Avatar
...wow that was quick....i didnt know that the t2 could support a 120 spur
d[-.-]b d[-.-]b
d[-.-]b d[-.-]b can you feel the bass? d[-.-]b d[-.-]b
d[-.-]b d[-.-]b
hpipro321 is offline   Reply With Quote
Old 01-19-2006, 05:26 PM   #1992
stonedgti's Avatar
Trader Rating: 15 (100%+)
Using anthing larger than a 116 is pretty dangerous, because the gear will sit almost flat with the bottom of the chassis. I wouldn't do it, unless you couldn't get the right gear ratio without it. It is definitely pushing it if you run asphalt. Just stick with a spur that fits and will provided enough gearing options. I personally don't see a reason to go up that high. I run 112 and 114 spurs mostly, and they've been doing the job for both 19t and stock.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 01-19-2006, 06:02 PM   #1993
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
I was just getting my car dialed for this weekend. It will be my first time racing with.
Something is driving me nuts..I checked everything but somehow when I sit the car up and the car leaning on its rear body stands to check the rear toe in. I am getting 2 degree on the rear right and 3 degree on the rear left. I am stumped. Each side has the same shimming and everything is the same on each side.
Anybody have any idea what might be causing this?
HRCRACER123 is offline   Reply With Quote
Old 01-19-2006, 06:15 PM   #1994
I have 2.5 on the left and 3 on the right
cvt01 is offline   Reply With Quote
Old 01-19-2006, 06:19 PM   #1995
Twin-Kyle's Avatar
Make sure you don't have a broken arm or upright.Also make sure that the pivot arm pin isn't bent.
Did you hit anything with it??
Also...make sure that the shims are the right sizes.
That all I've got....
Twin-Kyle is offline   Reply With Quote
