Old 01-18-2006, 10:19 PM   #1951
stonedgti's Avatar
Trader Rating: 15 (100%+)
If anyone is looking for 6mm hexes, www.allspeedhobbies.com has them. They are made by 3Racing to fit on Tamiya cars. If you don't see them on their site, just email or call them. I was there today, and they DO have them.
I know the Tamiya ones are very hard to find, so I'm just giving everyone a FYI.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 01-18-2006, 10:28 PM   #1952
HarshGuy's Avatar
I got the 6 mm hexes from Tower today, they work perfectly -- http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXDLV1 ...man it really is tight in here to fit electronics!! Got all the electronics in, I thought the Corally was a tight fit!! I'll finish her up in the morning and snap some pics
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-18-2006, 10:47 PM   #1953
STLNLST's Avatar
Trader Rating: 21 (100%+)
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-18-2006, 10:52 PM   #1954
mike ivy's Avatar
Trader Rating: 50 (100%+)
Does anyone know if you cant fit a 116 64p spur on the T2 would that be to big?
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 01-18-2006, 11:01 PM   #1955
rc-zombies's Avatar
Integy also sells various width clamping hex hubs.
available in 4.5mm, 5.2mm and 6.2mm widths.
Old 01-18-2006, 11:03 PM   #1956
James's Avatar
Originally Posted by Ill Factor
If u relocate the antenna mount to the top deck or just forward of the servo it can create just enough room depending on the electronics. Check mine out.
Can anyone give me an Idea of what gear ratios I should start with for 116 64 p spur, rubber on asphalt.
I setup my GTX much like the xray team drivers from pics of the novak race? or some race. the gtx is on it's long back edge, with the cap behind the esc, works out real nice, wiring is trick too. pic of what im talking about attached (if you can see)
as for gearing, it really does depend on your track.
I run a 7.5 FDR on our track, asphalt/rubbers. it's not a very big track, and is mixed with a fast/medium and technical section.
eye your fastest and most skilled opponents cars and try gear to match that (if your completely unsure). or ask someone what their rollout/FDR is on that track.
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 01-18-2006, 11:07 PM   #1957
Roger's Avatar
MIke: It'll fit. I have a PRS 116 tooth spur on my car.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 01-19-2006, 02:06 AM   #1958
RCknight's Avatar
Default Wow...giuseppe...
Originally Posted by Giuseppe d.
Here's my T2 with brushless sistem on it..
that's scary having the receiver hanging out in the open. I'm nervous enough having my personal transponder mounted on the end of the servo. I'm also not crazy about mounting my P.T. in the bumper. Team GP theres not much between the P.T. and the wall. To his, his own.
You GTX guys have it easy, try mounting the GTB!
I'm kind of disappointed that there is only one roll center adjustment on the shock tower. Jared you own me a soda! That's the easiest and fastest way to change roll center. We were thinking that the four holes surrounding the main screw that holds the tierods was some sort of quick tune roll center thingy. It's quicker than shims or blocks or am I missing something?
RCknight is offline   Reply With Quote
Old 01-19-2006, 08:23 AM   #1959
Originally Posted by James
I setup my GTX much like the xray team drivers from pics of the novak race? or some race. the gtx is on it's long back edge, with the cap behind the esc, works out real nice, wiring is trick too. pic of what im talking about attached (if you can see)....
James,
It looks really great, but how do you reach the setup button?
cvt01 is offline   Reply With Quote
Old 01-19-2006, 08:43 AM   #1960
HarshGuy's Avatar
Here's pics of my completed T2 ...couple of closeups of the countersunk screw in a PRS gear, and the clearance on Jaco foams with the tamiya 6 mm nuts (clooossse), I actually had to run the lower shock mount in the inside hole, the rim rubs if mounted on the outside hole, first the shock eyelet, dremelled it a bit, then it rubbed on the shock perch, so I moved the lower mount in one hole.
http://www.arroyoc.com/rcracing/harsht2_1.jpg
http://www.arroyoc.com/rcracing/harsht2_2.jpg
http://www.arroyoc.com/rcracing/harsht2_3.jpg
http://www.arroyoc.com/rcracing/harsht2_4.jpg
http://www.arroyoc.com/rcracing/harsht2_5.jpg
Old 01-19-2006, 08:52 AM   #1961
[QUOTE=HarshGuy]Here's pics of my completed T2 ...couple of closeups of the countersunk screw in a PRS gear, and the clearance on Jaco foams with the tamiya 6 mm nuts (clooossse), I actually had to run the lower shock mount in the inside hole, the rim rubs if mounted on the outside hole, first the shock eyelet, dremelled it a bit, then it rubbed on the shock perch, so I moved the lower mount in one hole.
Harsh thats what it says in the manual. To mount the shocks on the inside hole all the way around. DAHHHHHHHHHHHHHHHH(LOL) See ya at the track.
Juan Aveytia is offline   Reply With Quote
Old 01-19-2006, 08:52 AM   #1962
teamgp's Avatar
I've already hit a few boards hard head on, but the bumper material flexes enough for the PT to slide in between the bulkheads and then back out again after impact.
The quick roll center mount is off center. So with the screw mounted through the center, if you place the tab in the top outer notch the inner camber link will be higher and to the outside. Placing the tab in the top inner hole will make the inner camber link be higher and to the inside. Of course the lower tab holes will make the inner camber link be lower and to the inside or outside, depending on which lower hole you use.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-19-2006, 08:54 AM   #1963
teamgp's Avatar
118t is the largest that will fit without it sticking out of the bottom.
Guy Hood
Old 01-19-2006, 08:55 AM   #1964
HarshGuy's Avatar
[QUOTE=Juan Aveytia]
Mine says to mount it on the outside ..oh wait, I was reading it upside down
Old 01-19-2006, 08:55 AM   #1965
Harsh, why didn't you counter sink everyhole, including the aluminun. I gotcha beat. Looks real good.
