Old 01-17-2006, 07:35 AM   #1876
Originally Posted by Juan Aveytia
Point being, If you race with foam tires, you can use the wider tamiya wheel hexes instead of using annoying spacers so the front wheels don't rub on the steering knuckles.
Do you have a part number for these or where I can get them and what size would work best?
*Topher* is offline   Reply With Quote
Old 01-17-2006, 07:39 AM   #1877
Rob Phillips's Avatar
Originally Posted by kp-61
Hi guys,
Just finished building my first X-ray luckily it was a T2 ... im currently in a situation where i didnt get a front bumper on the kit. I have a race on the weekend and need to do some modification to make some other cars bumper work for the T2. Any suggestions? i looking for a foam that would fit the car, i dont mind cutting to make it fit for now.. Id rather run the car with a bumper rather than breaking parts
I really liked the car and am happy with the quality. Cant wait to see my time improvements over my old car :
I fount a 112 on my tool box and was wondering what pinion should i start with. I have from 30 to 40 but i think i need to get some for this car for it might need the 20 - 29 range... the track is 92 x 48 to be exact. Im running a stock 19t (nothing special just regular motor) if i get a 116 or 118 spur what gear do u recommend to start with?
thanks in advance,
Ryan
I read that one of the guys used a corrally rdx bumper and modded it a little to fit. I think the 05 would work with two new holes drilled in it too.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 01-17-2006, 07:58 AM   #1878
kp-61's Avatar
Thanks for the advice.. my bad i forgot to mention that i will be running rubber.. cs-22 is the spec tire for this comming race...
Im currently using the stock rubber setup from the manual... and try to read more setup for rubber from this forum... and a checkout the Xray forum for setup ideas. Im not thats good of a driver so i will try and play around with the setup.. if it doesnt work maybe copy some ideas from here.
Time to look for RDX bumper....
thanks
Ryan
kp-61 is offline   Reply With Quote
Old 01-17-2006, 08:04 AM   #1879
teamgp's Avatar
I'm not sure on the gearing for rubber tires. You might also want to post the question on the XRAY T1|T2 forum.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-17-2006, 08:14 AM   #1880
I'll get all the part #'s later and post them. I know the 6mm part # is tam53569.
Juan Aveytia is offline   Reply With Quote
Old 01-17-2006, 08:18 AM   #1881
James's Avatar
Originally Posted by teamgp
You might want to post the question on the XRAY T1|T2 forum. Tonyv and a lot of the team drivers have tested the car with rubbers on carpet.
thanks for the advice, I signed up to the forum when i bought my T2, but the forum never sent me an activation email. I've emailed the webmaster twice and had no reply... My account is still sitting on the system, inactive, I just cant get in until I'm verified with the activation email. if your chummy with any of the admin/mods, perhaps you could mention this for me?
my username on the xray forum is "James Mandy"
cheers.
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 01-17-2006, 08:26 AM   #1882
teamgp's Avatar
cheers.
James, YGPM.
Guy Hood
Old 01-17-2006, 08:39 AM   #1883
BritRacer's Avatar
Steve, you should set up a comission based referral system
6mm hubs
http://www.speedtechrc.com/store/ebp...nid=269&id=823
5mm Hubs
http://www.speedtechrc.com/store/ebp...id=269&id=5106
4mm Hubs
http://www.speedtechrc.com/store/ebp...nid=269&id=824
You can get the part number by removing TAM from the speedtech part no.
BritRacer is offline   Reply With Quote
Old 01-17-2006, 08:44 AM   #1884
Default Wheel spacer
I've found these in Jason's eBay store:
http://cgi.ebay.com/53646-Tamiya-Whe...QQcmdZViewItem
Wondering if those are aluminium or plastic spacers?
cvt01 is offline   Reply With Quote
Old 01-17-2006, 08:59 AM   #1885
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
I got this pic from P-Dubs websight its from the novak race. You can see the blue wheel spacers. I wonder what size and what company made these..http://www.pdubracing.com/Novak%20Race%20045.jpg
HRCRACER123 is offline   Reply With Quote
Old 01-17-2006, 09:00 AM   #1886
Scho's Avatar
Send a message via MSN to Scho
There aluminium...
Scho is offline   Reply With Quote
Old 01-17-2006, 09:02 AM   #1887
BritRacer's Avatar
tamiya, with tamiya 4mm hard lock nuts.
Old 01-17-2006, 09:35 AM   #1888
Gael L's Avatar
Harold have you had a chance to run your T2 down at SSH yet?
Gael L is offline   Reply With Quote
Old 01-17-2006, 09:48 AM   #1889
The car is put together and I was so excited to run it this past Sunday at SSH but with that snowstorm we had there was no way my beemer was going to make it to the track. The car absolutly is the worst in the snow. Rear wheel drive and Michelin pilot sport tires dont mix.
I will be racing it this Sunday though. I just better run clean lines and stay away from troube as I have NO spare parts. And from what I hear we will not see any for about another 3 weeks..
Old 01-17-2006, 10:02 AM   #1890
Mr. McGoo's Avatar
just an FYI - Larry from www.teamtamale.com is already in the works of producing some front and rear c-hubs as well as some steering blocks....
he just started, so I am not sure if he has enough to sell as of today....but be watching his website....they should be out soon....
i will run nothing but his aluminum - same stuff he uses for building Boeing planes.....very nice stuff
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
