Old 01-16-2006, 12:10 PM   #1816
ottoman's Avatar
R/C Tech Charter Subscriber
Originally Posted by HRCRACER123
Is this all you have to do to get the PRS spur gear to fit is just sand the top graphite brace. I thought I remeber reading somewhere that you have to grind the heads of the screws so it doesn't hit the composit bearing holder..
I want to run the PRS spur gears but I want to know what I have to do to make it work and not bind anywhere..
You can grind out the top plate or you can countersink the spur and use flathead screws. I just spot milled the spur gear a little to give more clearance.
ottoman is offline   Reply With Quote
Old 01-16-2006, 12:13 PM   #1817
drsfly's Avatar
Default prs spurs
Mine fit fine. It is close but does not rub at all.
However I had to replace the 5mm screws with 6mm because the prs are wider in the center than the kit supplied ones.There was just not enough screw in the aluminum of the layshaft to suit me.
Now if I could get the servo screw to slide by the top deck w/o shaving the top deck1/2mm. Already shimmed the mount out 3mm with a JR servo and it touches just a hair. Darn -- it is just going to have to stick out over the chassis another mm.
Other than that and the arms needing some tlc to move freely it was as good or better than the 05 to build.
My .03
Darrald
drsfly is offline   Reply With Quote
Old 01-16-2006, 12:28 PM   #1818
gonzo416's Avatar
Trader Rating: 39 (98%+)
rc knight,
dremel has a bit the same size as a cell.it's only 1/10 of the length but you run it back and forth and you get a very good seat for your cells. or you can do like hugodvb glue some sandpaper to a cell and hope it doesn't tear off in the process, but if it works it should come out perfect
gonzo416 is offline   Reply With Quote
Old 01-16-2006, 01:15 PM   #1819
Why, go thru all the B.S. When you can buy in my opinion the best spurs out on the market. WITH ZERO MODIFICATIONS. Just install it.
www.jwerks.com
Juan Aveytia is offline   Reply With Quote
Old 01-16-2006, 01:18 PM   #1820
STLNLST's Avatar
Trader Rating: 21 (100%+)
www.jwerks.com
Care to try a RW gear????
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-16-2006, 01:26 PM   #1821
dal bains's Avatar
Trader Rating: 35 (100%+)
stlnlst--nice to see you in here...
RCAMERICA-XRAY-HUDY
dal bains is offline   Reply With Quote
Old 01-16-2006, 01:30 PM   #1822
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I think Clint is ready to join us on the good side now
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-16-2006, 01:31 PM   #1823
STLNLST's Avatar
I had to come in here since I can't get you guys off our Schumacher thread....LOL
Old 01-16-2006, 01:34 PM   #1824
STLNLST's Avatar
Schumacher has shown too much love for me to walk away. Carpet has been a learning curve but on asphalt it's an even playing field.
Old 01-16-2006, 02:09 PM   #1825
Hebiki's Avatar
Trader Rating: 26 (100%+)
www.jwerks.com
juan... can you send me one to try out?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-16-2006, 02:45 PM   #1826
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Thanks Guys for the info on the PRS spur gear.
HRCRACER123 is offline   Reply With Quote
Old 01-16-2006, 02:53 PM   #1827
stonedgti's Avatar
Trader Rating: 15 (100%+)
I think you'll still need to drill out the right screw holes in order to fit the RW gears in. JWerks is really the way to go so far, unless PRS comes out with one with a thinner thickness. Both companies use basically the same materials anyway...it's just which fits the best.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 01-16-2006, 03:27 PM   #1828
HarshGuy's Avatar
as in last EVEN on asphalt?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-16-2006, 03:27 PM   #1829
HarshGuy's Avatar
www.jwerks.com
The great Juan Aveytia has spoken
Old 01-16-2006, 03:31 PM   #1830
HarshGuy's Avatar
That's all I had to do ...because I have a boatload of them Juan OK???!!! Geeze!!!
