Old 01-15-2006, 08:16 PM   #1801
I just bought one 2 couldnt resist even though ive only run the 05 for a couple months cause it looks so good.
and just for thought if your drillin plastic i always found it better to run the bit backwards
also the setup stuff is super that comes with it .
i raced at horsham and thier was only 2 heads runnin it but they got 12 and sold 12 so well see
donald wilson is offline   Reply With Quote
Old 01-15-2006, 08:39 PM   #1802
dmayhew25's Avatar
Trader Rating: 14 (89%+)
yeah, just raced my T2 for the first times this weekend. Once on carpet foams, and then outdoor parking lot. Car worked great at both venues. Couldn't be happier with it. Tested it a few times for stregth as well and it passed with flying colors. Every bit as fast as my 05's, and I needed two 05's and only raced one T2 at both places. The best is just how easy it is to work on.
David Mayhew
Team Trinity, RevTech, KSG, BSR Tires, KCR Hobbies, ProtoForm
www.FinishLineSigns.net
www.FinishLineRaceway.com
dmayhew25 is offline   Reply With Quote
Old 01-15-2006, 08:47 PM   #1803
RCknight's Avatar
Default Even Howard Dean would go.......
HAAAHOOHEAAAAHAAA!!!! for this car.
RCknight is offline   Reply With Quote
Old 01-15-2006, 09:10 PM   #1804
I just raced my t2 for the first time to day . I have a o5 and the t2 is faster in the turns than the 05 . I love the car xray did a real good job with it.
ptjonesus is offline   Reply With Quote
Old 01-15-2006, 09:31 PM   #1805
RCknight's Avatar
Default Best way to file the cell slots?
I have seen a few chassis with near perfect cells slots filed down as if it was done by a cnc lathe. Any tips on the very best way to do this? I wish a company would make a jig. I can do it well enough with a file and some time, but wondering if there are any great tips out there.
Old 01-15-2006, 10:07 PM   #1806
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Scho
I run my wires under my top deck, no chance of it hitting the belt that way, and looks neat and tidy.
Futaba low profile servo is what i run, nice and small and the PT fits on the end
Can you post some pics of your car with the Futaba low profile servo. I would like to see how it looks in the car. Thanks.
HRCRACER123 is offline   Reply With Quote
Old 01-15-2006, 10:25 PM   #1807
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Originally Posted by HRCRACER123
-How is everybody running there battery wires over the top deck or through the middle? Which way is less likely to hit the belt.
Under the top deck, very clean and keeps them snug away from the belt.
-Also I was going to buy a new digital servo. Can anybody reccommend a good high speed one. Preferably one that mounts easily on the T2 and does not hang over the edge.. Thanks..
A shallow servo works best. I use the Futaba S9550 and love it. Plenty fast (I run my dual rate at 80% even), and fits the T2 perfect. Even has enough room on the end of the server to mount a AMB PT and still be flush with the chassis. I will get a pic soon of my electronics layout.
Anthony.L is offline   Reply With Quote
Old 01-15-2006, 10:27 PM   #1808
Anthony.L's Avatar
First race day with the T2 and I'm blown away. Was better then even my best expectations. Moving from a TC4 to the T2 is a night and day difference. Before my best finish was 4th in the A-Main. Today first outing, 2nd in the A-Main. This is rubber tires on high grip indoor asphalt.
Old 01-16-2006, 06:02 AM   #1809
Superfly1967's Avatar
What springs and oil weights is everyone running for stock foams on carpet?
Superfly1967 is offline   Reply With Quote
Old 01-16-2006, 06:50 AM   #1810
Get a old sub-c cell and make sanding paper on it all the way arround .. you will get a nice result
hugovdb is offline   Reply With Quote
Old 01-16-2006, 07:22 AM   #1811
teamgp's Avatar
I believe all team drivers use XRAY 30wt with. The preferred setup from the Novak race can be found a couple pages back in this thread and will be on the website for view/download soon. I can't remember the spring setup off the top of my head though.
Of course I'm an oddball and use 35wt/purple springs up front and 30wt/light red springs (layed down) in the rear with a one-way setup.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-16-2006, 08:18 AM   #1812
rmargiotta's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rmargiotta
30 Wt. two holes open front and rear. Second hole in on towers on the outer hole in the rear arm and inner hole in from arm.
30 lbs. fronts (Pepto Color)
22.5 lbs. Rear (Blue)
teamgp: Light Reds are 35 lbs. and the purple springs you're running are 33 lbs.
Sponsors:
- Cold Hard-Earned Cash Money -
rmargiotta is offline   Reply With Quote
Old 01-16-2006, 08:26 AM   #1813
teamgp's Avatar
Yep. I'm an oddball. 33's standing up in the front and 35's layed down (more progressive rate) in the rear. I like the "pepto" color verbiage.
Guy Hood
Old 01-16-2006, 11:16 AM   #1814
Originally Posted by HarshGuy
Here's the area you have to sand the top graphite brace for PRS gears to work, it's really not that much to sand, literally I had a box cutter and shaved a bit off, since I got the gears here at work with no RC tools!! So it's not that much AT ALL
Is this all you have to do to get the PRS spur gear to fit is just sand the top graphite brace. I thought I remeber reading somewhere that you have to grind the heads of the screws so it doesn't hit the composit bearing holder..
I want to run the PRS spur gears but I want to know what I have to do to make it work and not bind anywhere..
Old 01-16-2006, 12:00 PM   #1815
dawgmeat's Avatar
Default My war-paint for Jan. Jams
might as well take the pic before it gets [email protected] up
dawgmeat is offline   Reply With Quote
