NEW XRAY T2
Old 01-12-2006, 09:06 AM
  #1666
BritRacer's Avatar
Originally Posted by ttso
To see how many shim I need to put on bulkhead if I wanna put T2 suspension on T1FK04. Or, if I put no shim, what the wheelbase would be.
err..ok.
BritRacer is offline
  #1667
theisgroup's Avatar
now to put the fk arms and chubs on the t2 would be worth it. at least until parts are more readily available.
theisgroup is offline
Old 01-12-2006, 09:08 AM
  #1668
you better just buy the kit ..
hugovdb is offline
Old 01-12-2006, 09:10 AM
  #1669
Frank McKinney's Avatar
Would someone measure the width of front and real bulkhead, outside-to-outside.
T1FK04 is about 42mm outside-to-outside, both front and rear bulkhead.
I measure 24.5mm with a ruler, I don't have my calipers at work with me.
I have to agree with the others so far - I'm generally not in the mindset of "must have the newest car" but if you've got an FK'04, just get the T2 when it's available to you, it'll just be simpler! Hybrid cars (the ones I've seen) so rarely work for people. But if that's what you want to do, knock yourself out
Frank McKinney is offline
Old 01-12-2006, 09:22 AM
  #1670
ttso's Avatar
I guess it's 42.5mm? looks like a typo..
Anyway, thanks Frank.
ttso is offline
Old 01-12-2006, 09:23 AM
  #1671
Ill Factor's Avatar
I bought one of the RW racing spurs but it was not a direct fit as none of the wholes lined up. It did have blue numbering instead of red. Are there two different types?
Ill Factor is offline
Old 01-12-2006, 09:24 AM
  #1672
no, 24.5, could be 25mm, I'll confirm when I get home with digital calipers.
Old 01-12-2006, 09:45 AM
  #1673
I drive with Robitronic spurs, they look the same (the white ones) and they have a direct fit.
-Hugo
hugovdb is offline
Old 01-12-2006, 10:08 AM
  #1674
teamgp's Avatar
Per digital calipers...
Front: 35.35mm
Rear: 35.0mm
teamgp is offline
Old 01-12-2006, 10:14 AM
  #1675
ttso's Avatar
Front: 35.35mm
Rear: 35.0mm
So.. If I put T2 suspension on T1.. wheelbase would be 7mm wider than original T1?
I guess that means there is no way to make T2 suspension on T1 now...
ttso is offline
Old 01-12-2006, 10:29 AM
  #1676
Ill Factor's Avatar
-Hugo
Where can I find these? Will Robinson Racong Spurs work?
Old 01-12-2006, 10:37 AM
  #1677
HarshGuy's Avatar
Here's the area you have to sand the top graphite brace for PRS gears to work, it's really not that much to sand, literally I had a box cutter and shaved a bit off, since I got the gears here at work with no RC tools!! So it's not that much AT ALL
HarshGuy is offline
Old 01-12-2006, 10:51 AM
  #1678
Ill Factor's Avatar
Harshguy u still have that FK05. I got a buddy who is supposed to come take a look at your pics tonight?
Old 01-12-2006, 11:03 AM
  #1679
HarshGuy's Avatar
Yea ..just "upped the antee" to, including some spare parts and took some closeups of the chassis, look at the trhread it's all on there.
HarshGuy is offline
Old 01-12-2006, 11:48 AM
  #1680
J@UNE's Avatar
Here's mine
T2 01
T2 02
T2 03
J@UNE is offline
