Old 01-11-2006, 08:10 PM   #1636
HarshGuy's Avatar
Originally Posted by Little Bahnatka
nope... but i made my p-dub bumper fit
A Corally PDUB bumper is a really good fit, just need to elongate the holes a little bit.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-11-2006, 08:22 PM   #1637
Originally Posted by HarshGuy
I just lightly sanded the one side of that graphite top plate, it was running just on both sides of the indentation (on mine anyways)
Guess that could work. I like the flat look on the spur now tho.
Oh, couldnt resist either...
NEW XRAY T2-dsc00316.jpg   NEW XRAY T2-dsc00317.jpg   NEW XRAY T2-dsc00318.jpg   NEW XRAY T2-dsc00319.jpg
punkboy is offline   Reply With Quote
Old 01-11-2006, 08:29 PM   #1638
Britracer I believe it is measured by starting at ride height. If you lift the car the tires will lift off the ground after travelling 1mm. This is called up travel. Say 4mm ride height + 1MM up travel = 5mm. Put a ride height gauge under both sides at 5mm. Adjust the downstops so the tires just touch the set-up board. Just make sure they are both equal. Hope this helps. Someone might have a better way of doing it.
Chris Reilly is offline   Reply With Quote
Old 01-11-2006, 08:32 PM   #1639
P-DUB's Avatar
Originally Posted by scoobydo
Do Any of these work on the new car?
-P-Dub Bumper for the FK05
We are working on new bumpers now and should have them finished very soon
Larry Pryor
P-DUB is offline   Reply With Quote
Old 01-11-2006, 08:33 PM   #1640
Rob Phillips's Avatar
Originally Posted by BritRacer
referring back to Dumas/Blackstock setup.
How exactly do I measure the 1mm 1.5mm uptravel, sorry I am not familiar with this term.
I think this must be pretty critical as i tried it today to the best of my ability and it seemed to push quite a lot.
andy
Is that refering to droop? Sorry I couldn't find that setup,what page was it on.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 01-11-2006, 08:35 PM   #1641
BritRacer's Avatar
http://www.rctech.net/forum/showthre...&page=52&pp=30
post 1538
BritRacer is offline   Reply With Quote
Old 01-11-2006, 08:45 PM   #1642
HarshGuy's Avatar
Anyone mounted electronics with a battery brace yet? ....Looks like the only way to make it work is the wires are gonna have to run under the brace ....between cells kid of thing.
Old 01-11-2006, 08:54 PM   #1643
Gael L's Avatar
Anyone know where I can order the FK05 battery brace?
Gael L is offline   Reply With Quote
Old 01-11-2006, 09:05 PM   #1644
Yup, as posted by Chris, that is droop measured at 1.5mm above ride height front and 1mm rear above ride height.
Old 01-11-2006, 09:18 PM   #1645
BritRacer's Avatar
ok, so if i run 4.5 ride height, i would set droop to 5.5 and 6 Front/Rear.
Sounds high, but oh well!
Old 01-11-2006, 09:24 PM   #1646
Try it and see what happens. Good luck!
Old 01-11-2006, 09:30 PM   #1647
Andy
When you have your car sitting on its tires, pick up the chassis like you were checking tweak. How far you pick up the chassis before the tires leave your pit board is the amount of uptravel. the uptravel is how far the suspension allows the chassis to rise, like droop but is measured differently.
Chris
mtc3od is offline   Reply With Quote
Old 01-11-2006, 09:34 PM   #1648
The way mentioned is repeatable no matter what your tire size. Altough that is important as well.
Old 01-11-2006, 09:38 PM   #1649
BritRacer's Avatar
ok. looks like i need another gauge
Old 01-11-2006, 09:40 PM   #1650
no other gauge. You just measure with your ride height tool. Your ride height is 4.5mm and you have 1 mm of up travel then you lift the chassis until you can only get the ride height tool to 5.5mm
