NEW XRAY T2
Old 01-11-2006, 10:24 AM
  #1606
Use locktite. The good thing about the new car is you dont have to take the bulkheads off to change setup.
mtc3od is offline
  #1607
imprsme's Avatar
Trader Rating: 76 (99%+)
Originally Posted by HRCRACER123
Just curious. When you guys built your kits is anyone using a little dab of loc-tite on the screws that go into the aluminum pieces?
Because with my FK'05 I had a slight problem with screws coming loose. Like the one's underneath the chassis that screwed into the bulkheads.
It is always a good idea to use Blue Loc-tite on any screw that is going into metal.
imprsme is offline
Old 01-11-2006, 01:26 PM
  #1608
Twin-Kyle's Avatar
NO....DON"T DO THAT!!!!
Will not be able to get the screws out IF you need to.Trust me.
Do what you want but ....I don't recommend it.
I use a dab of oil on my screws on my 05 just to get them out when I want.
Twin-Kyle is offline
Old 01-11-2006, 01:30 PM
  #1609
imprsme's Avatar
I don't know what kind of Loc-tite you are using, but BLUE loc-tite will come loose when you need it too. I have been using it at work and on all of my RC cars for over 5 yrs. Never had a screw or bolt that I couldn't get loose when I needed it.....
Now if you use RED loc-tite...you are not getting it loose NEVER EVER... LOL
imprsme is offline
Old 01-11-2006, 01:33 PM
  #1610
If you heat the screw it will come out.
Chris Reilly is offline
Old 01-11-2006, 01:36 PM
  #1611
Twin-Kyle's Avatar
I don't use any loc-tite of any kind.I told him to do what he wants.
Old 01-11-2006, 01:43 PM
  #1612
John Fontaine's Avatar
You dont even lock tight your wheel screws? I bet you have wheels flying off all the time, mostly if you run a solid spool.
John Fontaine is offline
Old 01-11-2006, 01:46 PM
  #1613
Twin-Kyle's Avatar
NO
and NEVER
Old 01-11-2006, 01:59 PM
  #1614
Trader Rating: 40 (100%+)
I agree, no loc-tite on my car, everything stays very tight... the LF wheel is the only thing that starts to back off when running a spool... but never enough to lose a wheel
brians11 is offline
Old 01-11-2006, 02:05 PM
  #1615
teamgp's Avatar
Some drivers experience loose screws, and others do not. The ones that do not, and have tried loctite, have had to drill screws out of the bulkheads at times.
I would suggest you put it together without the loctite first and put it through an entire race day. Then check the screws and use the loctite if you need it.
The various opinions may just be a matter of differing hand/arm strengths (torque).
teamgp is offline
Old 01-11-2006, 02:27 PM
  #1616
c-lyon's Avatar
I use a dab on the wheel screws but let it dry first. It then seems to last forever.
c-lyon is offline
Old 01-11-2006, 02:34 PM
  #1617
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
dont loctite anything on an xray in my opinion. I had a wheel fall off the first time I ever drove an xray and that was it but you wont have that problem with the T2. The screws grab the aluminum really good. Just check your screws every couple of races.
Working on my T2 now.
Also to fix the spur problem. Cant you just countersink the spur gear and use countersunk screws to fix it? I haven't got that far and am just guessing.
L.Fairtrace is offline
Old 01-11-2006, 02:38 PM
  #1618
RobertV's Avatar
I don't think loctite is needed either. For the screws coming loose on the wheels, just make sure the coned washers are in good condition and haven't gone flat.
RobertV is offline
Old 01-11-2006, 02:44 PM
  #1619
teamgp's Avatar
Good idea. I hadn't thought of that. The screws mounting my 64p PRS spur gear were contacting the composite bearing holder at first and causing it to bind. I sanded the heads down about .5mm with a dremel and all is well since then. Less rotating mass may be an added benefit. J/K
teamgp is offline
Old 01-11-2006, 03:11 PM
  #1620
Ok my preorder got messed up. Anywhere in the UK have any kits in stock?
John_Stones is offline
