Old 01-10-2006, 05:40 PM   #1546
Scho's Avatar
Send a message via MSN to Scho
I feel somone got told in here!
anyways quick question.. when putting the shocks onto the car is it the shiney side of the shock mounting part up or down?
Hope that makes sense, im guessing its shiney side out, dull side onto the ball?
Scho is offline   Reply With Quote
Old 01-10-2006, 05:43 PM   #1547
GMartinez's Avatar
Trader Rating: 85 (100%+)
? What is the going price for the T2 my old local hobby shop has for $369 just wanted to see if it was really a sale or is everyone selling it for the same price.
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-10-2006, 05:43 PM   #1548
teamgp's Avatar
Originally Posted by teamgp
I've attached a jpeg image of the T2 setup below and you can find my *final* FK05 setup at the link above.
I've made a correction on the inner camber link position in the setup sheet above. They are supposed to be at the lower outer position for short links.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-10-2006, 05:46 PM   #1549
BritRacer's Avatar
Originally Posted by Jon_R
I've just measured up the shocks bodies from my T2 with some spare bodies I had for my 05. And as far as I can see the only real difference between is the that the thread doesnt go all the way up the body. I used a set of digital calipers to check the sizes of them. I know they are not amazingly accurate but you are only talking of differences of about 0.01 millemeters. And these can be explained with torrances within the manufacture Also the shock cap-nut and the shock adjustment nut from the newer T2 shocks both fit on the older 05 shock bodies. This is just what I have found with my shock bodies, and I may well have the wrong bodies in the kit. But I doubt it as this is xray! Im sorry if I am wrong with this
But all in all this is an amazing car and I have really enjoyed building it and can't wait to race it! Well done Xray and thanks!
Thanks for looking, but I picked up another kit...... that way I know the rear wont be biased because 'slight' differences.....
I may also try the spool setup tomorrow
BritRacer is offline   Reply With Quote
Old 01-10-2006, 05:47 PM   #1550
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Rocco, smuggle a car out of mikes for me! j/k can't wait to get it
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-10-2006, 05:48 PM   #1551
Scho's Avatar
also another question... what Lb are the std springs?
Old 01-10-2006, 05:49 PM   #1552
Scho's Avatar
Old 01-10-2006, 05:55 PM   #1553
teamgp's Avatar
Originally Posted by H8W8IN
I agree...35 springs on the back , antisquat, shocks all the way out on the front...Thats has to be the hardest car to drive....You sure you know what your doing?
With light red springs layed down more for a progressive rate on the rear, the car transitions faster through chicanes, without rolling too much, than when it had violet springs stood up.
1.5 droop(this is not offroad)...front one-way...the car willl just roll over in the corners.....
The maximum track width, firm front end, initially soft rear end and minimum droop (low CG as well) work very well to prevent the car from lifting the inside tires at all.
2mm inboard toe and .5 degree toe out does the car just back into every corner or what?
The in-board front toe-out stabilizes the camber change of the front wheels as the car transitions from off-power to on-power and helps to eliminate the instability normally associated with a one-way. The steering becomes very consistent throughout the corner, even when feathering the throttle.
Guy Hood
Old 01-10-2006, 05:57 PM   #1554
teamgp's Avatar
I'd like to help, but I'm not following what you mean by the shiny side.
Guy Hood
Old 01-10-2006, 05:59 PM   #1555
Scho's Avatar
Ok, right on the shock bottoms and the shock tops (the plastic parts) there is a shiney side on it and a dull side to the plastic part. what side do i push onto the ball? before i locate it all by a screw to the wishbone/shock tower.
Old 01-10-2006, 06:00 PM   #1556
i'm guessing he's talking about the bottom shock end... the shiny side and dull side... could be wrong tho
Old 01-10-2006, 06:00 PM   #1557
Bryan Thng's Avatar
Hi teamgp,
May I ask what is the gold and silver springs equivalent to? White & yellow? Also are the silver/gold springs the same length as the current Xray springs?
Thx!
Bryan Thng is offline   Reply With Quote
Old 01-10-2006, 06:01 PM   #1558
Scho's Avatar
you got it
Old 01-10-2006, 06:03 PM   #1559
BritRacer's Avatar
Its the same as for the ball cup.
There is a small piece of paper added with the kit which addresses this issue.
I *think" its shiny side out, but don't quote me....find the piece of paper!!!!
Old 01-10-2006, 06:03 PM   #1560
teamgp's Avatar
you got it
Aah! Push the ball through from the shiny side. It should be a bit wider in diameter.
Guy Hood
