Yokomo LCG problem >
Yokomo LCG problem
Yokomo LCG problem
Old 11-27-2005, 01:25 PM
Revs's Avatar
Default Yokomo LCG problem
Evening every one,
Im posting this for a freind who is currently building his new yokomo lcg touring car, the problem is one of holes for a counter sunk screw to hold the servo post in place has not been counter sunk, so as you can imagine hes goping to have a problem with the screw sticking out. Now i havent seen the car in person yet we have only spoken over the phone, is this an error on Yokomo's behalf? and does any one have a solution to the problem as he doesnt want to send the chassis back after he took the time to file the chassis and seal the edges, i supose he will have to countersink but hes not keen on that, any other ideas?
Cheers
Tom
Revs is offline
Old 11-27-2005, 01:29 PM
hi,
there all like that, you can just file the sides of the hole at and angle to make it a countersunk shape, the only other way is to countersink it properly, or just leave it,
but there is no need to send it back to yokomo, as they are all made like this and there is no fault with his,
agower is offline
Old 11-27-2005, 01:59 PM
Revs's Avatar
Thanks a lot i will pass that on
Revs is offline
Old 11-28-2005, 08:29 AM
Originally Posted by Revs
Evening every one,
Cheers
Tom
You can pick up a countersink bit at some hardware stores, it's a good tool to own.
pops is offline
Old 11-28-2005, 08:42 AM
Mr. Shookie's Avatar
I second the motion and give it an AMEN....LOL
Glad I got my COuntersink bits handy...Needed them more than once or twice..
-Shookie <><
Mr. Shookie is offline
Old 11-28-2005, 09:53 AM
pheyhoe's Avatar
Do you reckon it was time/money saving not countersinking that hole??? i cant find any reason why it isnt countersunk, its like it on the SD, BD, LCG.
pheyhoe is offline
Old 11-28-2005, 11:41 AM
the reason i THINK it isnt countersunk is because if you look at all the pictures of the team drivers lcg's then you will notice that they mount the servo further fowards and towards the middle more and use the fixed steering arm (not servo saver). they dont use the mount on the servo to mount it, you can see they have been cutoff, i dont know how they mount the servo like this without it moving, it seems quite risky to me. so if there not using the servo mounts then they wont mind about that piece not being countersunk as there is no screw to go through it.
gower
agower is offline
Old 11-28-2005, 11:45 AM
gower
Shoe-goo works great.
pops is offline
