Old 01-10-2006, 01:32 AM   #91
I doubt the much more will be, they would have mentioned it. I think Mr. Shookie said that he takes his pack off the tray and puts it on the charger as quickly as possible as not to give the voltage time to rise. Since after the set lowest discharge current is reached, it stops discharging a cell, do you discharge normally, then put it on for another few seconds after all the cells have finished to get all the cells back to .9 volts and then pull it off and charge?
AE Racer is offline   Reply With Quote
Old 01-10-2006, 09:28 AM   #92
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Note the graph shows that if you set the XDL to 9 the Team Wave tray will hold every cell at the desired voltage for a very long time so you can walk away or even go get food while it does its magic.
I usally just pull my packs off the Lightening once they all say .9 and then charge.
I don't have to worry about voltage increasing in the cells cause they are all at the same...
Once you try that and then the New ICC from Spintec then all you packs will love you....LOL
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 01-10-2006, 09:41 AM   #93
BritRacer's Avatar
ok, who has been brave enough to try charging them on the tray with the voltmeter active?
BritRacer is offline   Reply With Quote
Old 01-10-2006, 09:44 AM   #94
You must be kidding I have no time for that...I have to keep equalizing mine while one in charging......Maybe if I get borded I might try but I think I will pass....Don;t want to void the warrentee...LOL
-Shookie <><
Old 01-10-2006, 09:50 AM   #95
BritRacer's Avatar
lol, it never even occurred to me, until I read the manual and it said they advise not to do it....since then its been eating me up to try it......
Its like a "DO NOT PUSH" button..... I wonder what would happen if.......
Old 01-10-2006, 09:50 AM   #96
subman's Avatar
I do that all the time! Works awsome I bring them down to.9v and then switch straight to the voltmeter function and charge away
I think the voltmeter function is one of the best features of this tray!
subman is offline   Reply With Quote
Old 01-10-2006, 09:51 AM   #97
subman's Avatar
I'm not much of a manual reader
Old 01-10-2006, 09:52 AM   #98
I might have to try that out....That will tell you if a cell is going bad on ya...
-Shookie <><
Old 01-10-2006, 09:56 AM   #99
subman's Avatar
-Shookie <><
exactly
Old 01-10-2006, 12:46 PM   #100
XrayFK's Avatar
I'm very tempted to get one of these (even though they are out of stock), however as soon as the I.C.C. comes out, there will be no need for these very fancy trays. (Sorry Much More! )
Decisions, decisions...
Still, between this one and the Much More tray, I'd choose the Lightning.
XrayFK is offline   Reply With Quote
Old 01-10-2006, 01:44 PM   #101
BritRacer's Avatar
cool....will try the voltmeter function then!!!
Old 01-10-2006, 05:02 PM   #102
I don't understand why you cant use the same power supply as your use for your charger when using the voltmeter function when charging. If you have a decent power supply I cant see what the problem would be. Can you pull off the cells while they are still discharging with no problems or do have you press the button first? It seems to me like it would be a good idea to set the XDL to a lower value first and take all the cells down until they're finished, because that not only takes out capacity, but makes it so that at whatever the lowest discharge rate is set to (XDL setting) all of the cells are at .9 volts or whatever the is cutoff. If you pull off the cells before they are finished, they are not equalized in the sense that at the same discharge rate they will have the same voltage, and I know its probably not a significant difference, but I dont see why not to use the tray to its full potential.
Old 01-10-2006, 07:25 PM   #103
TEAMWAVE's Avatar
It can't use the same power supply with the charger when you use voltmeter mode and charge your pack on the tray since different charger has different design, the grounding of the charger, battery and discharger may not be equal and causing problem. We suggest you power up your Lightning by another 6cells pack and it should work great. In voltmeter mode, Lightning only use small amount of power (around 0.1A), any 6cells battery pack should do the job. When it is in discharging mode, it will take up around 1.00A current. Another solution is to use a 1.00A 12V transformer to power the Lightning alone.
Thanks for all your support. We have very good sales of our Lightning equalizer and the first batch has almost been sold out. We still have limited stock reserved, welcome to contact us by email if you want to order and we will try our best to help. We are currently increasing our production and hope the second batch can out in Febueary.
For people who particularly need the voltmeter function, please wait for the second batch since we have done some modification such that it will give more accurate reading in voltmeter mode.
TEAMWAVE is offline   Reply With Quote
Old 01-10-2006, 07:52 PM   #104
Trader Rating: 244 (99%+)
When will you have these back in stock?
Fred Perkins is offline   Reply With Quote
Old 01-10-2006, 09:12 PM   #105
ATOMIC's Avatar
Kinetix now has them back in stock. www.kinetixrc.com
ATOMIC is offline   Reply With Quote
for sale......two team wave lightning v2 discharge trays Dave Bowser R/C Items: For Sale/Trade 7 10-25-2007 08:25 PM
Team Wave Lightning Discharge Tray TwinKays R/C Items: For Sale/Trade 3 09-03-2007 03:44 PM
Trinity DPD VS. Teamwave Lightning discharge Equalizing System Jochim_18 Electric On-Road 58 07-25-2007 07:54 AM
Lightning battery discharge and equalizing system frank p R/C Items: For Sale/Trade 0 09-11-2006 06:28 PM
Team Wave Lightning Discharge tray FS awtwac R/C Items: For Sale/Trade 7 02-16-2006 07:28 PM
