Old 12-05-2005, 10:37 PM   #31
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Originally Posted by TEAMWAVE
Thank you for all of your inputs and comments. We will try our best to develope a higher current discharge tray + equalizer, a 2 in 1 unit.
Sounds good.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 12-05-2005, 11:03 PM   #32
subman's Avatar
Just orderd one can't wait to try it!
subman is offline   Reply With Quote
Old 12-09-2005, 09:37 PM   #33
BritRacer's Avatar
OK First impressions....
Works OK...BUT it is hard to make all cells connect, i had to basically take off the bent battery bars i use to solder the wire on....
When it made a good connection, you have to make sure it is inserted correctly, it has polarity, and will only work with 1 of the 2 polarity possibilities, which is annoying.
You have to set to voltmeter...look...if its the wrong way round you get some 0.00 and some e.ee, rotate it and works better.
When all cells are connected it works great!!!
Used it, then put on my 030a. lights were all dim and all went out immediately!!!
I like it, but PLEASE get rid of the clips, they are too weak, i am thinking of taking some elastic bands to make it a stronger connection.
BritRacer is offline   Reply With Quote
Old 12-10-2005, 02:21 AM   #34
TEAMWAVE's Avatar
Yes, it has polarity. Lightning use electronic components to discharge the battery, NO single resistor is used! That's why it has polarity, just like your speedo won't work if battery is reversed.
For the battery clip, try to bend it a bit before you plug the battery, it should work great.
Beware that if you use direct solder battery pack instead of banana plug, you should remove the first and the sixth battery clip and move one hole upward to get good connection.
TEAMWAVE is offline   Reply With Quote
Old 12-10-2005, 10:42 PM   #35
Are you saying that you have to remove the endbars (the bent bars that you solder to) of a battery for it to fit?
AE Racer is offline   Reply With Quote
Old 12-10-2005, 10:46 PM   #36
subman's Avatar
If that's the case cancel my order
Old 12-10-2005, 10:54 PM   #37
Team-RTR's Avatar
i received my lightning tray this weekend to use. after cycling the pack and using the lightning the voltage of my battery went up .3v and i squeezed 600more mah into them! highly reccomended product.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 12-10-2005, 11:39 PM   #38
BritRacer's Avatar
i spend about 2 mins playing trying to get it to make proper contact with the cells. I find it easier to remove the end bars, yes.
The spring clips are WAY too weak.
Old 12-10-2005, 11:41 PM   #39
jamescam's Avatar
I saw Brits today and must say it sure looks like a nice piece of equipment. Once the clips are improved I will be ordering my very own.
jamescam is offline   Reply With Quote
Old 12-10-2005, 11:54 PM   #40
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default Ditto
I've been eyeing Brits new TeamWave, it looks quite nice the clips are a ???
but the device seems to work well once everything is connected.
I agree with JamesCam....once the clips are done I'll be ordering 1 or two.
RCtech opinion clause (so no thread police, please ): The above is just my opinion of course.
olhipster1 is offline   Reply With Quote
Old 12-11-2005, 12:20 AM   #41
RCMits's Avatar
Trader Rating: 25 (100%+)
as much as i hate the screw-types from trinity and similar, mybe a screw type connector would be better?
*shrug*
RCMits is offline   Reply With Quote
Old 12-12-2005, 10:58 AM   #42
TEAMWAVE's Avatar
The #1,#4,#6 battery clip can be repositioned. #1,#6 battery clip can change position easily by removing the front panel. Move to a position that best fit your battery. If you found the battery clip can not clamp the battery tight, try bent the clip a bit and it should be okay.
For easier insert of battery, we suggest insert the first (-ve pole) cell first and then rotate/slide down the rest one by one.
Old 12-12-2005, 11:00 AM   #43
TEAMWAVE's Avatar
Sorry forgot the image.
Team Wave - Lightning Discharge / equalizing system-bat_clip_position.jpg
Old 12-12-2005, 12:27 PM   #44
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Works great tried it this weekend...
It worked great on my practice packs was able to get even more mah in and higher voltage...
My race packs are all dead shorted....so until I start racing Mod and more 19T I will continue with Dead shorting but I think all the new packs I use will be used on this devise.
Yes moving the clap in makes it work perfect.
I like the clips...makes for easy removal so it can be moved right to the charger...Heck I hooked up the charger and as I pulled the pack off the lightening I started the charge. No time for voltage to climb.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-12-2005, 01:10 PM   #45
jamescam's Avatar
As I took more of a quick glance then in-depth look question...
Does it display the voltage of each cell as it is discharging or the cut off voltage for each cell?
for sale......two team wave lightning v2 discharge trays Dave Bowser R/C Items: For Sale/Trade 7 10-25-2007 08:25 PM
Team Wave Lightning Discharge Tray TwinKays R/C Items: For Sale/Trade 3 09-03-2007 03:44 PM
Trinity DPD VS. Teamwave Lightning discharge Equalizing System Jochim_18 Electric On-Road 58 07-25-2007 07:54 AM
Lightning battery discharge and equalizing system frank p R/C Items: For Sale/Trade 0 09-11-2006 06:28 PM
Team Wave Lightning Discharge tray FS awtwac R/C Items: For Sale/Trade 7 02-16-2006 07:28 PM
