Old 09-01-2006, 03:07 AM   #181
You can monitor cells while charging, but you have to use two powersupplies. One for your charger and one for the lightning. I thought this was clearly stated in the manual.
Stevenkoiter is offline   Reply With Quote
Old 09-01-2006, 07:03 AM   #182
edwintklee's Avatar
Trader Rating: 23 (96%+)
why have to use two power supply? use battery to power team wave discharger ok??
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 09-01-2006, 07:22 AM   #183
has team wave fixed the faulty button issues with the lightning? my mates unit has a button that does not work at first press. (the middle button)
this is the best discharger on the market in my opinion at the moment but the button not working on first press is annoying.
TomB is offline   Reply With Quote
Old 09-02-2006, 03:32 AM   #184
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
It says in the instruction book that the central button has to be pressed twice, I presume this is to stop any accidental fiddling as the buttons are very sensitive.
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 09-02-2006, 08:32 AM   #185
??it soemtimes takes 3 or 4 presses, it definately feels like a faulty type connection as oposed to a "safety feature"
Old 09-02-2006, 01:33 PM   #186
Ali Graham's Avatar
Hmmm, doesn't sound good. You could try loostening the main cover/lid, just wiggling it about a bit in case the button isn't seated square but that could void your warranty.
Old 09-04-2006, 01:17 AM   #187
it seems like alot of the units in australia (well syndey from what i know anyway ) have this problem.
it's disapointing because it is a very good discharger, and my favourite, but this is a nagging issue with them it seems.
Old 09-04-2006, 04:51 AM   #188
[[john]]'s Avatar
Trader Rating: 24 (100%+)
yep, Button troubles here too Its Frustrating when trying to get in the menu and the button dont work so you press again, Then it says complete or whatever before you change anything
[[john]] is offline   Reply With Quote
Old 09-05-2006, 07:43 AM   #189
Just had mine today from Team Scream UK via Ebay and I dont think it works.
I have a dismantled 6 cell pack (charged) which I put on the tray, position 1 shows the voltage and battery graph all the other positions show done, if I move a cell from another position to position one the same thing happens?
I have tried contacting the UK and just get an answering machine, hopefully they are still is business, I noticed that there is no mention of the tray on their website, yet there are pictures? Possibly 89 down the drain - hope not!
Can anyone recommend a charger, good enough for racing, hopefully mains and DC in?
HixX is offline   Reply With Quote
Old 09-05-2006, 08:20 AM   #190
Send a message via ICQ to rcnewb2004
I thought the advantage of this discharger was that u didn't have to disassemble ur batteries to discharge?
rcnewb2004 is offline   Reply With Quote
Old 09-05-2006, 08:27 AM   #191
radio_car_racer's Avatar
hope this helps
UK home page Team Scream UK There's a forum on there to
radio_car_racer is offline   Reply With Quote
Old 09-05-2006, 08:45 AM   #192
No, you dont have to dismantle, I just had one dismantled already so I used it for test. I'm sure it doesnt work.
Cheers for the link, thats the website I had found, tried joining the forum which an administrator has to OK before you can log on, still waiting for that after 4 days. Seems a bit suspect to me that you cannot even view posts without getting Okayed first.
Old 09-05-2006, 09:43 AM   #193
mmm.....Teamscream's site in the US doesnt mention the tray either !!?
Old 09-06-2006, 04:14 AM   #194
Ali Graham's Avatar
That's becasue its Team Scream UK distributing this discharger
HiXX, mine does that too, but on different cell locations. However on mine it often shows my cutoff voltage (for example 0.90) whilst the other cells display done. I also presumed a problem but then I noticed the figure flickering on the 3rd digit, and this means that the cell voltage is just above 0.90, i.e. the display is not large enough to display the exact voltage. After a few seconds though the cells reaches its cutoff voltage, and is ready for charge.
HTH and gives you some insight, if you still can't get in touch, try the Team Scream forum, many of us use that on a daily basis
Old 09-06-2006, 07:16 AM   #195
Cheers for that Ali. Though both Team Scream UK and US are distributing the tray .
I found the problem in the end...stupid really...didnt read the manual properly. Trouble was I was using single cells to test it. You cant. You can charge A single cell or 2-6 SERIALLY connected cells. DUH! I am embarrassed that sometimes I can be so thick.
It seems to work fine, thought the voltmeter is out when compared to a calibrated DVM measuring across the cells.
for sale......two team wave lightning v2 discharge trays Dave Bowser R/C Items: For Sale/Trade 7 10-25-2007 08:25 PM
Team Wave Lightning Discharge Tray TwinKays R/C Items: For Sale/Trade 3 09-03-2007 03:44 PM
Trinity DPD VS. Teamwave Lightning discharge Equalizing System Jochim_18 Electric On-Road 58 07-25-2007 07:54 AM
Lightning battery discharge and equalizing system frank p R/C Items: For Sale/Trade 0 09-11-2006 06:28 PM
Team Wave Lightning Discharge tray FS awtwac R/C Items: For Sale/Trade 7 02-16-2006 07:28 PM
