Team Wave - Lightning Discharge / equalizing system
#166
Dear All,
I would like to announce that "Lightning-Discharge/Equalizer" is now available online through RCmodel (http://shopping.rcmodel.hk) online shop.
Other distributor:
Hong Kong – RCMODEL (shopping.rcmodel.com.hk)
Australia – LLC racing (www.llt-racing.com)
Switzerland – SAD (www.sadeurope.com)
Belgium – RC-Connect (www.rc-connect.com)
Netherlands – RC–Connect (www.rc-connect.com)
USA –Team Scream Racing, Kenon Hobby (www.kenonhobby.com)
UK – Team Scream Racing (www.teamscreamcellmatching.com)
Singapore – Tai Sing Corporation (PTE) LTD (www.taising.com)
Malaysia – Tai Sing Corporation (PTE) LTD (www.taising.com)
Philippines – Tai Sing Corporation (PTE) LTD (www.taising.com)
TEAMWAVE
Other distributor:
TEAMWAVE
#167
got a qn...
tried charging wif the voltmeter function and it works fine... qn is can i use it for discharging on a full charge(cycling batts) batt using charger at 20/30amp, with cutoff at 6.0v... then use the tray discharge function?
anyone tried it
anyone tried it
#168
charging ????
i have a question how do i charge my batterys through the lightning i have just got 1 but had to send it back due to a bad fan but when i get it how do i charge to i connect it to the aligator plugs and run charge ???
i have a lrp pular charger if any 1 can help it would be greatly appreciated
cheers
chris
cheers
chris
#169
cheers
chris
cheers
chris
now i wonder if its ok to use the same for discharging....
#170
since no reponse i decided to take the risk...
but rather than using a charger to discharge... i used spintec cos it doesn use any power supply unlike the charger... and so far so good... now i can monitor if any cell drops below 0.9...
#172
that's no problem
#173
I've been using my "wave" for a couple of months now, still works a treat.
Ive noticed cell 6 on all my packs goes out first... anyone experiencing the same or know the reason behind this phenomia?
#174
The Wave works great. We just found one little problem with most units. The screws which fix the clips to the PCB are not tight enough. After fixing this the Wave works much more accurate. In my opinion the clips also could be improved for a better contact but beside this I think the Wave is much better than the other units available.
#175
#176
The Wave you got pm
#177
Originally Posted by cvt01
Just a guess: If that 6th cell is the one which you solder the negative connector on then it may be that your soldering technique heats up the cell a little bit too much. Normally it happens on the negative connector because the negative side of the cell has a lot of surface to heat up and it takes longer time... Build up heat can lower the capacity of a cell...
#178
Could be a possibility, I use a 100watt iron (too hot?) maximum contact time is about 6 seconds, the 6th cell happens to be the positive lead. Could it be that the 6cell takes the initial drain from the esc, causing that cell to over heat?
some packs are the end one, some are the middle. there is no real pattern. but you may notice the end one more if they are the first or last to go off.
#180
Trader Rating: 23 (96%+)
