Old 04-14-2006, 04:37 AM   #151
Originally Posted by BrainTeased
i was under the impression that the team waves hold their cells down to the selected voltage cut off but in fact it doesnt. its pretty much just another novak smart tray but with a fan.
According to the product profile it is supposed to hold the voltage at the cutoff level.
Hyper1 is offline   Reply With Quote
Old 04-14-2006, 06:01 AM   #152
V12
V12's Avatar
I have to say I didnīt try very much and with low XDL level only.
Maybe you have to use higher XDL for this function to really work.
But anyway Iīm not completely sure how this XDL works. Maybe itīs just a function of time and each of the XDL levels is a fixed amount of time. Maybe itīs dependent on other things also until it finally cut off.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 04-14-2006, 06:28 AM   #153
Send a message via AIM to canto54
With a higer XDL, the discharge current decrease in order to maintain the selected cutoff voltage.
I use a lowvoltage like 0.7/0.8V and and XDL=5/6 with GP cells and high voltage 0.9/0.95V and XDL= 8/9 with IB cells
Robitronic Avid V2
Robitronic - Graupner - GM racing
JP Products
www.mrclongwy.fr
www.petitrc.com
canto54 is offline   Reply With Quote
Old 04-14-2006, 06:40 AM   #154
V12
V12's Avatar
But from what I have heard you shouldnīt use a high XDL value with IB cells. The discharge current may decrease more but I think it also will affect keeping the cells at a voltage which isnīt good for them.
Old 04-14-2006, 06:52 AM   #155
You're right, I use 5/6 with IB and 8/9 with GP, just a brain problem!!
In fact with GP cells, I often use XDL=6/7 during races because with higher value it can take long to discharge the pack!
Robitronic Avid V2
JP Products
www.mrclongwy.fr
www.petitrc.com
Old 04-14-2006, 12:52 PM   #156
Default Problem
Hi
Has any one had this go wrong as i used the tray fine last week and today the 1st and 6th cell do not discharge any more.I looked through the top and the board had burnt out at the cells on the top of the board.Where the cell join together.
zombie is offline   Reply With Quote
Old 04-14-2006, 04:42 PM   #157
Didn't have that problem, but sometimes I try to discharge it, and it doen't discharge 1 cell... when I put in another battery pack.. it does work normal.. After leaving the pack for a few minutes, it's fine again.. strange...
-Hugo
hugovdb is offline   Reply With Quote
Old 04-14-2006, 06:06 PM   #158
Originally Posted by zombie
Hi
its abvious you have shorted the unit. it can happen easily by the outside tabs touching a metal object and shorting out.
look on the board and you will see the lines on the pcb that is where the current flows. you will see areas where the short occured the board coz the lines on the pcb will flake off. just reconnect the flow, by soldering a wire in between.
if you post a pic of your PCB i will explain it better.
XingXing is offline   Reply With Quote
Old 04-15-2006, 06:47 AM   #159
BrainTeased's Avatar
hmmm well i hooked up a volt meter to each ends of my pack and watched it discharge and i noticed every time a cell showed it was "done" (discharged to the choosen voltage) the voltage in the pack would start climbing up again, very slightly.
But as each cell was done the voltage in the pack would start to get higher and higher until all cells were discharged the pack returns to 7.2+ volts within a matter of seconds.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 04-15-2006, 07:18 AM   #160
Thats correct.. What I do is just before Charging the pack, I put it back on the lightning again...
-Hugo
Old 04-15-2006, 07:22 AM   #161
its the people on this forum who used the word "hold" at at desired cut off. well it does do that to a certain extent.
not sure on the exact algorithim, but would go something like this.... (say you set the tray to XDL=9 and 0.9v)
1) discharge to 0.9volts at 5amps
2) when cell reaches 0.9volts decrease to 4.5amps
(NOTE: the drop in the discharge rate will allow the cell to rebound above 0.9v a little)
3) when cell reached 0.9volts again decreas to 4.0amps
4) when cell reached 0.9volts again decreas to 3.5amps
etc
when cell reaches 0.9volts again decrease dishcarge rate to 0.1amps
when cell now reached 0.9volts @ 0.1amp stop discharging the cell.
change the display to DONE.
or put more simply. its like discharging at 5amps, when it reaches cutoff, lower the amperage then re-discharge.
i cant see how it is possible to hold a cell infinitly at 0.9volts like you guys suggest. there is only a certain amount of energy in a cell. there has to be a point at which it has to stop. (otherwise you may aswell take it down to 0 volts and deadshort it) and at 0.1amps discharge is very very slow discharge rate. thats about 0.1mah every minute?
and yes all cells rebounds to their natural levels 1.2v once they are discharged and are allowed to rest.
Old 04-16-2006, 04:32 AM   #162
-Hugo
thats what i did all day today
Xing Xing
i know what you mean i actually set mine at 0.85 volt per cell and a rating of 5 with the XDL setting. it almost gets all the cells holding at 0.85-0.9 volt for a while
Old 04-24-2006, 06:47 AM   #163
Has anyone noticed that there is a calibration menu? Just scroll to "setting" and press both left and right scrolling buttons at once. Mine displays 9<:8<8.
Stevenkoiter is offline   Reply With Quote
Old 04-24-2006, 07:36 AM   #164
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
If anyone is interested in buying my TeamWave Lightening please PM me....
I would take $80.00 shipped. It has only ten uses....
I have been racing Nitro so electric stuff is going to be finding its way so keep an eye out...LOL
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 05-02-2006, 10:03 AM   #165
Kenon Hobby Re-Instock now!
ORDER CLICK HERE
rcKenon.com is offline   Reply With Quote
for sale......two team wave lightning v2 discharge trays Dave Bowser R/C Items: For Sale/Trade 7 10-25-2007 08:25 PM
Team Wave Lightning Discharge Tray TwinKays R/C Items: For Sale/Trade 3 09-03-2007 03:44 PM
Trinity DPD VS. Teamwave Lightning discharge Equalizing System Jochim_18 Electric On-Road 58 07-25-2007 07:54 AM
Lightning battery discharge and equalizing system frank p R/C Items: For Sale/Trade 0 09-11-2006 06:28 PM
Team Wave Lightning Discharge tray FS awtwac R/C Items: For Sale/Trade 7 02-16-2006 07:28 PM
