Drifting gear ratios >
Old 11-25-2005, 08:34 AM
Default Drifting gear ratios
Hi, I just got a new p2k2 motor, can't wait till it arrives. my qution is what would be an apropriate gear ratio (motor pinion) to run for this motor for drifting? MY user guide of the cars (tc3) says 28 teeth ratio = 6.43, towerhobbies says to start at 21 teeth, which is a ratio = 8.57 . but that is for grip, any suggestions on a ratio that is good for drifting and doesn't overload the motor?
milen is offline
Old 11-25-2005, 09:30 AM
anthony390's Avatar
for drifting you want to go around the undergearing part but not to much
that is beacuse of tourqe matters
anthony390 is offline
Old 11-25-2005, 09:31 AM
anthony390's Avatar
so i would say around 24 to 26 tooth for drifting and well stick
with the 72 tooth spur for the tc3
Old 11-25-2005, 09:34 AM
PaZ
PaZ's Avatar
i use a 25 with my TC3 drifting 24-26 is fine
PaZ is offline
Old 11-25-2005, 09:37 AM
anthony390's Avatar
told ya
LOL
Jk
Old 11-25-2005, 09:38 AM
PaZ
PaZ's Avatar
yer and i use a 28 with me 19 high speed slides
PaZ is offline
Old 11-25-2005, 09:43 AM
anthony390's Avatar
well i use a costum 19 turn quad magnet motor gaered at 28tooth with a 69tooth spur
so the 25 is allright for 27T, great, no other gear to buy, 6$ I'll save.
tnx
milen is offline
Old 11-25-2005, 09:50 AM
anthony390's Avatar
your welcome
and glad to be of help
Old 11-25-2005, 06:06 PM
nitrs4rcr2's Avatar
okay.so whats a good gear set up for a 10x2 mod motor in a tc3 for drifting?
it can be either 64pitch set up or 48pitch set up i use both.
nitrs4rcr2 is offline
Old 11-25-2005, 07:47 PM
anthony390's Avatar
23 - 25 tooth pinion
and 72 or 75 tooth spur
those are 48 pitch
