Tyre rotation
Old 11-23-2005, 04:17 PM
Default Tyre rotation
What's the general concensus re tyre rotation (rubber on asphalt)
Can you swop any tyre with any other?
Or should you only swop those on the same axle
or only those on the same side?
exint2 is offline
Old 11-23-2005, 06:46 PM
Suspended
Trader Rating: 14 (100%+)
On a full-size 4wd vehicle, tires are swapped in an X. I do this on my XXXS, and it seems to work.
Phatkat is offline
Old 11-23-2005, 06:52 PM
Sometimes if you don't rotate the tires, you won't get the full life span out of it. I race on carpet with rubber tires and the are more right turns and it cause the left tires wear out way faster than the right tires.
trf_racer is offline
Old 11-23-2005, 07:39 PM
Mark G's Avatar
it doesnt realy madder if you rotate them they will still wear down
Mark G is offline
Old 11-23-2005, 07:42 PM
PitCrew's Avatar
I found that sometimes the wear in the tires "wears in" to the track.
I found this out a couple weeks ago. Rotated tires before the main, and the car SUCKED. It was dialed in the last heat. Shouldn't have rotated the tires...
But, its OK to do it at the start of your day. Like put them on in a different pattern than last race day. Then by the second or so qualifier, they will have worn in again.
PitCrew is offline
Old 11-23-2005, 08:00 PM
Suspended
Wow, really?
Phatkat is offline
Old 11-23-2005, 08:01 PM
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Never rotate before the main it will likely change the car usually not in a good way
RKeasler is offline
Old 11-23-2005, 08:02 PM
Suspended
Right; you'll have one or two that wear funny.
Phatkat is offline
Old 11-23-2005, 09:04 PM
Rod M's Avatar
rotate your tires every run in a set pattern (e.g clockwise) and they will all wear evenly
Rod M is offline
Old 11-23-2005, 09:14 PM
I have never been happy with rotating rubbers front to rear, everyime i have the car turns into a forklift. I only ever rotate left to right after every run.
Besercoe is offline
Old 11-23-2005, 10:51 PM
Could'nt have said it better.
pops is offline
Old 11-24-2005, 12:07 AM
Piyo Piyo's Avatar
If your track has High Speed and Long sweepers before and after the straight line, rotate left to right vice versa. Better don't rotate forward to rear vice versa, it often change the car's driving characteristic.
Note : if you race on asphalt...
Piyo Piyo is offline
Old 11-24-2005, 12:18 AM
acutts's Avatar
I never rotate my tires. I mark them up with a sharpie as Front Left, Front Right, Rear Left, Rear Right and only run them on that specific axle.
I did find when switching tires around it does give a different feel especially as they get older. Another trick is to put a dot or small line every time you use them for a run so you can gauge the amount of runs and life of your tires or help with picking your best set for a final etc.
acutts is offline
Old 11-24-2005, 12:50 AM
Rod M's Avatar
probably explains my driving then
Rod M is offline
Old 11-24-2005, 03:14 AM
F. Alonso's Avatar
I think that rotating your tyres is okay as long as you do it right from when they are new. There is no point in rotating them if you've stuck by them on the same section of the car for too long. I try and rotate every run but only left to right, never front to rear!! If I forget to rotate, I think that its better to just leave it at that for the remainder of their life, depending on how many runs they have been on that one axle, otherwise the "break in" period becomes long and you are running on cruddy, ill performing tyres for too long!
F. Alonso is offline
