Tamiya Direct Drive Touring Car >
Like Tree92Likes
Old 09-10-2008, 07:57 AM
  #1456
drbelleville's Avatar
Default Anyone see all the new option parts tamiya has for the F103
http://www.tamiyausa.com/product/rcp...chassis_id=A33
drbelleville is offline
Old 09-10-2008, 10:12 AM
  #1457
edhchoe's Avatar
Trader Rating: 41 (100%+)
What does shore mean in foam tires? Do foam tires grip better than the rubber tires on concrete driveway? What width should I use for front and rear?
edhchoe is offline
Old 09-13-2008, 02:53 AM
  #1458
NiMo's Avatar
Originally Posted by Besercoe View Post
those mega wide tires look awesome, where do they come from? And what body?
Tyres are Kawahara (ZW range), and I have only found this place to get them
Body is the Active Hobby Porsche 956 - 190mm, but as the speeds we now run do not need such high downforce I am looking at the Blade Jaguar XJR14
NiMo is offline
Old 09-15-2008, 10:32 PM
  #1459
edhchoe's Avatar
Default front suspension tapping screw popped loose...
One of the 4x30mm tapping screws that hold down the front suspension to the main board came loose and caught the ground and got bent out of shape. Will I find with metric tapping screw at a hardware store?
edhchoe is offline
Old 09-16-2008, 10:13 PM
  #1460
edhchoe's Avatar
Default Got a new body for F103GT.
It's a Tamiya Ferrari 360 Challenge body and I Painted it Gold. I love it. The prev body was the same one in silver but it is all thrashed and I bought another one.
edhchoe is offline
Old 09-16-2008, 10:42 PM
  #1461
gtypecanare's Avatar
Flashback from a few years ago
gtypecanare is offline
Old 09-16-2008, 11:20 PM
  #1462
edhchoe's Avatar
I love those bodies, especially the Ferrari! Very creative.
edhchoe is offline
Old 09-29-2008, 07:34 AM
  #1463
Birky's Avatar
Hi all,
Could someone give me an idea of a final drive ratio for a 27T stock motor. The track I'm running on is about 250m long with a 60m main straight. I've never raced my F103GT before and we have a chance to run on the local nitro track but I have absolutely no idea what ratios to be running.
Cheers
Ben
Birky is offline
Old 10-17-2008, 11:24 AM
  #1464
NiMo's Avatar
The lower powered FGT2 rules (HPI Saturn 20T motor) appears to be attracting some ex pan car GT racers back to the class.
During the summer we only had 3 or 4 cars at some of the club meetings, but last weekend was the first time the FGT2 group official ran, and we got 9 entries.
Winter Championship starts this Sunday, and it looks like we may have 14 FGT2 runners, but as of yet, no news on any FGT1 entries (any motor and up to 235mm).
NiMo is offline
Old 10-27-2008, 10:11 AM
  #1465
Hi everyone
I'm running a F103 GT, with a LRP A.I. Brushless Pro Reverse Digital ESC, an Eraser 9.5 motor, with ATS foam tires. I bought a high torque servo saver, turnbuckle tie-rods and TRF Special Damper.
This week end, as I was running on a very unclean track, I tried to set a high rear height. The point is that, when I use my "0" spacer (for rear axle), I can only use my 14T pinion, no way to use a 16T (I'm using stock 70T spur gear). I can't use my "2" spacer upside down, pinion ad spur gear are like glued the one with the other. Does it come from the rear pod or from my motor? Should I go with a 63T F1 spur gear?
How do you set your damper? I'm using 2 holes piston, 30 WT oil and I find my damper a bit loose. Should I go with 1 hole piston? Or 40 WT oil?
And which grease should I use for my pads? I used ball diff grease provided with the kit, as suggested in the manual, but I think that it's really like I had no sway bar.
DaTaz is offline
Old 12-12-2008, 11:01 PM
  #1466
CCH1978's Avatar
Trader Rating: 27 (100%+)
just bought one...cant wait till race season to run it
CCH1978 is offline
Old 12-17-2008, 10:20 PM
  #1467
CCH1978's Avatar
can anyone tell me whats a good set up for parking lot racing
CCH1978 is offline
Old 12-19-2008, 07:59 PM
  #1468
CCH1978's Avatar
anyone?
CCH1978 is offline
Old 02-02-2009, 12:30 AM
  #1469
gramm's Avatar
Well, I'll try to field this one:
Best setup tip is to sugarwater the asphalt if at all possible. Then try foam and rubber. If the track can't be cleaned, rubber is the way to go; I've had much luck with CS27s all-round (at night) and 32s for daytime racing. Build the car with the T-Bar screws set to the manual's setting (2mm I think) and go from there (back them off to cure spinning out problems).
This information is more useful for an initial run. I can give more detailed info if required. Read back a few pages for the best diff setup. Good luck.
Daniel
gramm is offline
Old 02-17-2009, 11:33 AM
  #1470
lightfoot's Avatar
Default F1 Series
For anyone in the Los Angeles area interested... BCR will be having a F1 series starting Saturday Feb 21st
http://www.charleslightfoot.com/BCR/f1.html
lightfoot is offline
