Tamiya Direct Drive Touring Car >
Like Tree92Likes
Old 05-27-2007, 03:58 PM
  #1156
bikedoctor's Avatar
Would the veteran F103 drivers please post a list of commonly broken parts we should stock.
And for asphalt (Open track) What pinion spur is most practical. I'm converting to the .4 module as opposed to the kits .6 module because their seems to be more ratios with the .4 .... or at least that I can find on tower hobbies.
Thanks for all your help.
bikedoctor is offline
Old 05-27-2007, 04:31 PM
  #1157
svt-racer's Avatar
These cars are really tough and hard to break. The weakest part is the Lexan Courage body. Other than that....you may want to stock spur gears and pinions. I would suggest converting to 64 pitch. Many of those gears are readily available.
I would suggest a good aftermarket servo saver...which will be a lot better than the stock one that comes with the kit. I like the turnbukle kit and the adjustable caster kit from 3Racing.
As far as setup for outdoor asphalt...I can post mine once I get back to my house and see my car. I run mine with soft rear spring. I have been running CS 27 with red HPI insert in the front and RP 24 on the rear with the yellow HPI inserts. This is the tire combination I was running when the temperature was around 65 to 70 deg F (ambient temp). On a sunny day with track temp around 100F, I switch the rear tires to use CS27 but with the stock blue CS medium insert. It seem to work fine once the tires heat up with a couple of laps into the race. I also used traction compound all theway around. I remember using the front stock springs.
More to come....
svt-racer is offline
Old 05-27-2007, 05:57 PM
  #1158
Thanks Alfie, thought my dif was a little loose!
croz is offline
Old 05-27-2007, 08:52 PM
  #1159
Alfie's Avatar
Trader Rating: 17 (100%+)
No worries.
The arrangement is wideest on bottom (smallest on top), then 2nd washer is smallest to widest, then finally widest to smallest.
Upon installation, you will need to test your diff out to make sure that the slippage is minimal. If it's too loose (listen to the rpm of your motor; going high rpm then drops to low rpm) or too tight (tight being that flooring the throttle give the immediate spin-outs). Either isn't good for the machine and motor. So do check carefully.
Hope it helps!
Alfie
Alfie is offline
Old 05-27-2007, 08:59 PM
  #1160
Alfie's Avatar
Front arms. It doesn't break, it bents. The rear hubs, left and right. Do keep a piece or two of the rear drive shaft.
Tamiya T-Bars. They warp too easily. Unless you are running in the TCS, I suggest that you use a better T-bar for practice.
I would suggest using the 48 pitch gears for durability. NOT the Tamiya 0.6 modules, but the common "inches" 48 pitch gears.
Hope it helps!
Alfie
Alfie is offline
Old 05-28-2007, 11:18 AM
  #1161
TFR
TFR's Avatar
My F103GT-MS.
Too bad my car is not TCS friendly as I would love to race at a TCS event.
Attached Thumbnails Tamiya Direct Drive Touring Car-cimg1847.jpg   Tamiya Direct Drive Touring Car-cimg1849.jpg   Tamiya Direct Drive Touring Car-cimg1852.jpg
TFR is offline
Old 05-28-2007, 02:01 PM
  #1162
bikedoctor's Avatar
Hope it helps!
Alfie
Which Spur gear works with the F103GT. I thought it was Tamiya specific?
And What T bar for Asphalt do you suggest??
Kevin.
Old 05-28-2007, 02:56 PM
  #1163
Registered User
Originally Posted by Solara
the GT is very new to me...and I have never own any previous form of the F103....so I am sure there are THINGS that I don't know about the Courage body and F103GT.........may be the rubber tires, may be I am so used to driving the car like TC....must be something that I can change to make that body work.
Meanwhile, I have to keep using the Courage body cause for the upcoming TCS race...
Howard,
What TCS race will you be attending? I is there one in the Chicago area soon? I watched you at at the Trackside race the day after you built your car. I thought it got better as the weekend went on. I forget his name, but who was that guy that won the trackside race? He looked real fast. Why didn't you set your car like his was?
If the're is a race comimg to the Chicago area I think I will by one of those f103gt cars and give it a try. Plz let me know.
radar... ping...
radar is offline
Old 05-28-2007, 03:04 PM
  #1164
Big B's Avatar
Kevin.
You can use damn near any spur gear out there, they are not Tamiya specific, only if you plan to race in a TCS race do you need tamiya parts. A few guys on here have said the Kawada, I think (NOT SURE) that the Associated, and CRC will work as well
Big B is offline
Old 05-28-2007, 10:39 PM
  #1165
Alfie's Avatar
Nice.
I like my cars to be simple like yours.
Alfie
Originally Posted by TFR
My F103GT-MS.
Alfie is offline
Old 05-28-2007, 10:42 PM
  #1166
Alfie's Avatar
Hey Kevin,
You got to have the spur gear adaptor to make the Spur Gear work for your F103GT.
The reason for me to change it to Non-Tamiya gear is because I have 48 pitch pinions, no Tamiya ones.
You can use the Kawada T-Bars for Asphalt.
Hope it helps!
Alfie
Kevin.
Alfie is offline
Old 05-29-2007, 06:32 AM
  #1167
tamiyarcracer's Avatar
Brian, do you own one of these cars??
They are not a generic spur. On these cars the spur supports a bearing. I believe there was only a few companies that made spurs back in the day.
HPI, Kawada, and Tamiya.
tamiyarcracer is offline
Old 06-05-2007, 05:53 PM
  #1168
bikedoctor's Avatar
Alfie ............ YGPM. Kev.
Old 06-05-2007, 06:10 PM
  #1169
Big B's Avatar
No not yet Troy, I thought it was like a 1/12th style spur, guess I was wrong, my bad, thanks for setting me straight
Big B is offline
Old 06-05-2007, 11:45 PM
  #1170
Alfie's Avatar
You got PM and Email, Kev!
But response from you.
Alfie
Alfie is offline
