Tamiya Direct Drive Touring Car >
Like Tree92Likes
Old 05-20-2007, 12:36 AM
  #1111
Ray Lan's Avatar
Default F103GTR
Hi Guys, I'm from Singapore.
Been viewing this thread for a while and thought that I could post shots of my GT.
Attached Thumbnails Tamiya Direct Drive Touring Car-f103gtr-1.jpg   Tamiya Direct Drive Touring Car-f103gtr-2.jpg   Tamiya Direct Drive Touring Car-f103gtr-3.jpg   Tamiya Direct Drive Touring Car-f103gtr-4.jpg   Tamiya Direct Drive Touring Car-f103gtr-5.jpg
Ray Lan is offline
Old 05-20-2007, 12:41 AM
  #1112
Very nicely done with the F103. I've never watched them before so now I'll be going thru their archives to see all the videos.
minijosh is offline
Old 05-20-2007, 02:19 AM
  #1113
Alfie's Avatar
Trader Rating: 17 (100%+)
What we used to run on (48& 64 Pitch), were known as the Imperial sizes. Tamiya's introduction of 0.6 & 0.4 Module is 48 & 64 Pitch, but only in metric size.
Do NOT attempt to mix these 2 size together as it will cause damage to the gears, either the spur or the pinions.
Originally Posted by bikedoctor
Im not new to rc and understand 48 vs 64 pitch gears but what do you mean by .4 gears???
Alfie is offline
Old 05-20-2007, 10:19 AM
  #1114
NiMo's Avatar
Originally Posted by Alfie
From the picture you'd provided, I can really see if your car has the Tamiya Carbon Chassis.
When you have the Carbon Chassis installed, you can try not to install the upper deck that runs to the servo mount. The Carbon Chassis alone is stiff enough to do the job. Hence you will have more space for the wires. Please refer to my picture.
Hope it helps!
Alfie
Chassis plate is standard F103GT
NiMo is offline
Old 05-20-2007, 10:47 AM
  #1115
wallstreet's Avatar
Trader Rating: 20 (92%+)
On the f103gt cars has anyone had the problem of the car always pulling to the left on excelleration ?
i was running a f103gt with a stock motor and a 4800 lipo pack.
wallstreet is offline
Old 05-20-2007, 10:58 AM
  #1116
heretic's Avatar
try cleaning the two bearings that support the axle.
heretic is offline
Old 05-20-2007, 11:26 AM
  #1117
Talking
Just picked up a NIP Courage shell for $20 shipped on ebay.
minijosh is offline
Old 05-20-2007, 12:49 PM
  #1118
wallstreet's Avatar
the car is new only used at one tcs event and it was doing it then too .
Old 05-20-2007, 01:29 PM
  #1119
NiMo's Avatar
Try loosening and retightening the screws/bolts, just in case it does have a tweak.
NiMo is offline
Old 05-20-2007, 04:53 PM
  #1120
Big B's Avatar
Even though its new, I would still clean and oil the bearings on that side
Big B is offline
Old 05-20-2007, 05:37 PM
  #1121
wallstreet's Avatar
thanks for all the info and help guys
Old 05-20-2007, 05:43 PM
  #1122
Ray Lan's Avatar
If its always happening, it may be due to a warpped T-Bar. Mine warpped pretty bad once and the car kept spinning out on one side. A bit more disc damping will help cushion the effect. But best to try a new T-Bar to confirm.
Ray Lan is offline
Old 05-20-2007, 06:45 PM
  #1123
Alfie's Avatar
Then you will need the upper deck to support.
Alfie
Alfie is offline
Old 05-20-2007, 06:48 PM
  #1124
Alfie's Avatar
Your T-Bar could be warpped.
Also, check your ball diff. Just last Saturday during my run at the track, upon acceleration, my F103GT swirled to the right and the car felt funny on the differential.
I'll be replacing my diff parts soon.
Alfie
Alfie is offline
Old 05-20-2007, 09:17 PM
  #1125
Alfie's Avatar
Talking about that 2 bearings on the motor mount (1060), Do regular checks on them as they take the most abuse from the motor and all that bashings. Was checking on mine and found them to be gritty.
Given the spare cash, I'll buy some better grade bearings to replace them.
Alfie
Alfie is offline
