Old 05-17-2007, 09:20 PM   #1081
Alfie's Avatar
Trader Rating: 17 (100%+)
Send a message via ICQ to Alfie
I run my F103GT ourdoor on Asphalt with Sorex 40Rs, Brushless 7.5R and 48 Pitch Gears. I never tried the stock or Tamiya 0.4 module gears at all because I know they don't last.
The choice of my body is Stratus 3.0. Will be changing over to Nemesis soon to see how it performs. Have used Stratus 3.0 for about 6 months (because I bought like 4 pieces at a go) and no problems in handling. The only thing I worry all the time is the overheating of my rubber tires.
Foams are easy to drive, but it's sluggish, to my feel. And it's hard to determine the ride height.
Alfie
Originally Posted by Solara
For mod outdoor(8T-10T)....what FDR to be use in F103GT with TC body..? Also, for rubber tires....RP30 good enough? Or harder...? Thanks......
F103KŠ • F104PRO • Universe • Spektrum • GTB • GTX • Trakpower • Orion
Retired Fleet: DDM • F103GT-R™ • F103LM TRF • F103LM • RC10L3 Team Touring • YR4M2 Type J PRO • YR4M • YR-F2 SP • Boomerang • Mountaineer • JPS • Clod • Bullhead • TLT-1 • Avante 2001 •
Alfie is offline   Reply With Quote
Old 05-18-2007, 12:42 AM   #1082
Send a message via AIM to minijosh Send a message via Yahoo to minijosh
I'm going to be running my car indoors on carpet. What's a good tire to use? I'll be using a stock motor and we can't use additives to the carpet.
http://rccarparts.biz/
Joshua T
minijosh is offline   Reply With Quote
Old 05-18-2007, 12:45 AM   #1083
Alfie's Avatar
Sorry but we don't run Carpet here. Can't advise what to do.
Basically stock motors are quite forgiving, so I believe soft rubber tires will work well.
Alfie
Old 05-18-2007, 07:12 AM   #1084
bikedoctor's Avatar
Guys I'm in need of the instruction manual for the F103gt. Could someone email a copy or mail me a copy. I dont mind dropping some coin in a Paypal account for the help.
Alfie .... would you post your set up and a picture of you chassis please. I'm running very smooth asphalt but they dont allow traction compound on the track. You are allowed to prep the wheels but the corners are dry.
bikedoctor is offline   Reply With Quote
Old 05-18-2007, 07:17 AM   #1085
bikedoctor's Avatar
Im not new to rc and understand 48 vs 64 pitch gears but what do you mean by .4 gears???
Old 05-18-2007, 07:33 AM   #1086
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
I have the manual in pdf format for this car.... Send me an email if you want it....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 05-18-2007, 08:03 AM   #1087
NiMo's Avatar
Tamiya have this wierd pitch thing, .6 & .4
I have been told that the .4 is the same as 64P, I have just set my car up with a .4 spur and 64p pinion and it feels really smooth, just doing the finishing touches now, and putting a BL 13.5 in the Courage F103GT is not as straight forward as you think.
NiMo is offline   Reply With Quote
Old 05-18-2007, 08:08 AM   #1088
NiMo's Avatar
Tamiya Manuals here
Old 05-18-2007, 11:19 AM   #1089
peejay's Avatar
Tamiya use metric measurements so .4 is .4mm pitch, which is very close to 64dp. Tamiya also use .6mm pitch which not close to 48dp.
peejay is offline   Reply With Quote
Old 05-18-2007, 03:18 PM   #1090
Trader Rating: 16 (100%+)
What was the problem...? Do you mind to share...? I am not planning to go brushless on the GT (used all the brushless on 4WD TC and 12th scale)...but want to get some headup for future reference....thanks
Old 05-18-2007, 03:18 PM   #1091
I used Tamiya BLUE insert along with Tamiya Type A tires...front/rear the same. I used Tamiya tires cause I have to enforce with the TCS rule.
If not....just like TC, I will probably try CS27 front/rear....probably even better. (but never tried it cause Carpet season just over...)
Old 05-18-2007, 03:44 PM   #1092
NiMo's Avatar
Problem 1 was the Courage shell, because it is so low at the rear, and the 13.5 BL's motor wires tab will only fit in two positions, and both pushed against the shell, I had to remove the spacers between the t plate and the motor pod, so then had to use the No.2 blocks to lower the rear ride height again.
Problem 2 was the GTB esc, it would not fit within the chassis with the shock mount in place, so I had to reshape the shock mount to clear the esc fan, I actually found it fitted better with the main battery/motor wire to the rear of the car.
Problem 3 was the fitting of the RX, due to the size of the esc it had to fit fairly central which left practically no space for the RX, fortunately I had the minature Spektrum RX which only just fitted between the esc and the servo.
I was hoping to take it to the track today but this expected 1 hour job took nearly 7 hours to fit correctly (without wires rubbing any part of the chassis), unfortunately there is an Electric National at my local track this weekend so I can't test it until I return from my holiday.
Old 05-18-2007, 04:12 PM   #1093
TFR
TFR's Avatar
My F103GT built for a summer series...
Tamiya Direct Drive Touring Car-cimg1832.jpg   Tamiya Direct Drive Touring Car-cimg1834.jpg   Tamiya Direct Drive Touring Car-cimg1835.jpg
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 05-18-2007, 04:58 PM   #1094
Big B's Avatar
Sweet Ride, is everything TCS approved? What is the part # for the turnbuckles
Big B is offline   Reply With Quote
Old 05-18-2007, 06:56 PM   #1095
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
It is not TCS Legal, the Servo mount is not tamiya.
The turn buckles are the DF-03 Hard turnbuckles
tamiyarcracer is offline   Reply With Quote
WTB Old direct drive car or sprint car mopar70 R/C Items: Wanted to Buy 2 04-23-2008 10:30 AM
Direct Drive Diff Help/Question Rockin Johny Electric On-Road 0 04-17-2008 10:53 AM
200mm direct drive touring car Tomoyuki Electric On-Road 13 06-26-2007 12:40 PM
Direct Drive Touring Cars scoobydo Electric On-Road 35 04-25-2005 03:46 PM
1/12 direct drive cars TFR Electric On-Road 13 08-31-2001 11:34 AM
