Tamiya Direct Drive Touring Car
#826
Originally Posted by Sydewynder
The pivot ball setup flops from side to side too easily. No steering. You can drill and put in "tweak" screws and screw them down to stiffen the roll. It'll be like 12th scale T-bar cars.
#827
Originally Posted by madjack
looked good! (glad I did not scratch that thing)
had a good time running at TA Saturday...pretty close
either way.. no harm done.. Me locking the brakes at the end of the straight and twisting the wheel too early didn't help much. (must remember, brake in straight lines ONLY)
Good thing the stickers helped mask some of the minor road rash
And yeah, good close racing on saturday.. TCS F103GT will be very interesting..
Thinking about getting another kit to go FULL TILT with mods/customization.. Lyman's ride is just rediculous!!..
-O
#828
Originally Posted by OSherman
Hmmmm... are you 'the teacher', the 'SilverArrow', my old 'buddy' or one of the many other cool peeps at Tamiya??
-O
-O
I'm on the same page with you. The cars a cheap, think I might build one for TCS & one for trying to keep up with Lyman!
#829
A bit off topic, but I wanted to bring up an old Radio Control Car Action article from when the Toyota GT-1 and Porsche 911 GT-1 came out on the F103RS chassis. At the time, the Le Mans series had gotten a lot bigger with the super expensive cars coming in and the likes of Mercedes, Toyota, BMW, Porsche, etc trying to win it with $100 million cars. The article said that the cars by Tamiya received so much fanfare that they sold out of the kits, and bodies often. They also said that at the time Tamiya had plans for another 2-3 different cars like the Toyota and Porsche. Well as we know, we only got an Audi and that was it. Shortly there after the series of cars were killed off.
My point is that we are hearing the same thing for the F103GT from Tamiya now. They are saying there are going to be more kits, and different bodies offered soon. My question is how long do you think they will continue, and how many more cars could we expect?
I have heard more about definate plans for TT-01 based cars(Mazda RX-7, BMW BTCC 3 series, etc) than I have for the F103GT.
#830
Hi Guys...Was wondering whether you've guys have this problem.
My pal & me were practicing last sunday and both of us have this problem of too much steering on left and spins out easily.
Then later we've realised that the cause of the problem would that the differential side is too heavy. Much heavier than the other side.
Do you guys have this problem and anyway to remedy this?
Thanks in advance...
#831
Originally Posted by racenut123
We figured you could add tweak screws out this last Friday night.Works ok.Just looking for someone who can give me a real world experience answer on why one is better then the other.Also what tires have people found that work.
#832
Originally Posted by BP SHADOW
I started out running pivot ball with no tweak screws as this worked for me in the F1 days. The car picked up and carried the front wheel coming out of the corners ala sprint car. I put tweak screws in and that problem went away. I have since gone back to the stock oring setup for carpet and the car is much better. As far as tires go, I have been running RP30 premounts and they work well. I ran Type A's last friday with firm inserts up front and softs in the rear. The car was OK, but this was also older rubber, so the combo may change when I mount up fresh rubber.
#833
Problem here is that many remember the tyre supply problems, both in those terrible rubbers and the foam donuts, that they are not even looking at the class again, and this is not helped by a lack of a National sereis for the F103 cars (not even the UK Tamiya series, well apart from some daft flying lap contest on practice day).
#834
Originally Posted by Solara
Would you mind to share what brand of the insert..? Planning to get the Type A ready for some pre-TCS practice on carpet...thanks.
#835
Got the bug to buy one of these cars. Can someone post all the hop-ups that are important to make it good. Thanks in advance
#837
#838
The majority of hop-ups add weight and no performance advantage.
I would only recommend the Motor heat sink and wheel shims as all other chassis hop-ups so far have note proven to make the car any faster.
#840
Originally Posted by MrBlack
My car is dialed and do not use any hop-upssans shims behind the wheels.
