Old 01-15-2007, 10:59 AM   #766
mtveten's Avatar
Trader Rating: 27 (100%+)
So what seems to be the hot tire setup for Tamiya tires?
Has any tried stretching Type As or B3s over 26mm?
Mark
mtveten is offline   Reply With Quote
Old 01-15-2007, 11:16 AM   #767
MrBlack's Avatar
Originally Posted by Afro Puff
AAAIIIIEEEE!!! Anyone know where I can get the Courage front bumper?!? I can't find 'em anywhere!
Call Tamiya USA directly if they have the part in stock you can order it through then directly.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 01-15-2007, 11:22 AM   #768
MrBlack's Avatar
Mark
No one has really run Tamiya tires much for this car but many are specualating it will be Type A 24 mm in the front with Type A 26mm in the rear Tamiya makes both a dish and BBS rim that is in both 24 and 2mm.
B3 may work but it has been a bit cold for them recently.
Old 01-15-2007, 12:21 PM   #769
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Mark
you must be joking RIGHT
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-15-2007, 01:59 PM   #770
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Good luck, I am in the same spot. I am so eager to run my Courage body that I am fabbing a mount from fiberglass. The Courage B parts is what is needed and they have been out of stock @ Tamiya America for well over a month.
I'll hit the brakes he'll go right by
http://f1rclab.com
http://f1rclab.mybigcommerce.com
BP SHADOW is offline   Reply With Quote
Old 01-15-2007, 02:00 PM   #771
mtveten's Avatar
So does tamiya make a typ a A 26mm tire or you talking about putting the 24mm tire on a 26mm rim?
I know the tamiya tires are not the best choice but since many of us will be doing TCS this year I thought it might be a good idea to start looking for a good TCS tire setup.
Mark
Old 01-15-2007, 02:02 PM   #772
mtveten's Avatar
No joke Franko, I am planning on doing TCS so I will be working with tamiya tires only till after nats.
Mark
Old 01-15-2007, 06:26 PM   #773
414MPH's Avatar
Mark, You are aware the 24mm and 26mm refers to the width of the rim & tire and not the diameter. Therefore, no "stretching" required.
I doubt Fred will allow mixing 24mm and 26mm rims and tires to build a tire... But I could be wrong. FRED?
MPH
414MPH is offline   Reply With Quote
Old 01-15-2007, 07:06 PM   #774
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Mark
Mark give Kevin a call he liked the 24mm on the 26mm wheel.
Marty, the F103 comes with 24mm wheels, and 26mm tires.
tamiyarcracer is offline   Reply With Quote
Old 01-17-2007, 06:33 PM   #775
streetracer745's Avatar
Send a message via AIM to streetracer745
how does the F103gt do in mid grip areas and tracks? slean and smooth parking lot style stuff.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-17-2007, 10:23 PM   #776
Runin Ronin's Avatar
I bought a F103GT awhile back from mtveten (actually it was his dad's) and I am just now getting to installing all my electronics... I want to run a Courage body but, not sure if I need anything special to mount the body. Is there a special bumper that I need???
Runin Ronin is offline   Reply With Quote
Old 01-18-2007, 02:51 AM   #777
It really depends on what kinda tires you're looking at.
Foams will generally give more grip than rubber.
I do run mine in a small technical track with mid grip asphalt using Sorex 36Rs all round, I can say its still got to be a lot gentler on the finger compared to touring.
Ben.C is offline   Reply With Quote
Old 01-18-2007, 10:57 AM   #778
mtveten's Avatar
I am not sure on all the differences between the 103gt chassis kit and the new courage version but I am fairly certain the bumper and body mounts have changes.
Mark
Old 01-18-2007, 11:11 AM   #779
OSherman's Avatar
Anyone have/know where i can find detailed pics of the pillow-ball rear suspension for the F102/103GT?..
-O
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 01-18-2007, 11:25 AM   #780
BP SHADOW's Avatar
Mark
Bumpers and body mounts are different
You need the Courage B parts to run the Courage body.
Tamiya has been out of stock for over a month
http://f1rclab.com
WTB Old direct drive car or sprint car mopar70 R/C Items: Wanted to Buy 2 04-23-2008 10:30 AM
Direct Drive Diff Help/Question Rockin Johny Electric On-Road 0 04-17-2008 10:53 AM
200mm direct drive touring car Tomoyuki Electric On-Road 13 06-26-2007 12:40 PM
Direct Drive Touring Cars scoobydo Electric On-Road 35 04-25-2005 03:46 PM
1/12 direct drive cars TFR Electric On-Road 13 08-31-2001 11:34 AM
