Old 01-10-2007, 07:16 AM   #736
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Originally Posted by SeaKayCarthik
So the chassis can only support pinions 20-26t? I will be running silver can. I checked tamiya's site, I cant find +2 offset 26mm rims.
Carthik
Here is a link to the manual on the japanese website.
http://www.tamiya.com/japan/rc/rcmanual/58367.pdf
it shows 53473 as the wheel that comes in the kit. it is a 2 offset.
as for pinions I have used 12 - 20 the chassis can support probably to about a 35 but for starters I would say have maybe 14 - 24 in your pit box. How tight of a track do you normally run on?
tamiyarcracer is offline   Reply With Quote
Old 01-10-2007, 07:56 AM   #737
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I just ordered a Courage kit, I skimmed through this thread, but really could not see if there was any "NEEDED" parts or upgrades.
Can we us any spur gear ? What are the best diff upgrades....
Any thoughts ?
Thanks in Advance
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-10-2007, 08:34 AM   #738
Any thoughts ?
Thanks in Advance
look over the last 2 pages, there has been some discusion with another racer.
Old 01-10-2007, 09:23 AM   #739
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Any thoughts ?
Thanks in Advance
tim i think some stated about using the HPI spurs on the car, I got mine on order too
Old 01-10-2007, 09:34 AM   #740
nagatahawk's Avatar
I have the f103 courage
I don't think the hpi spurs will work.
you have to use tamiya spurs. I hope someone else makes spurs for this car.
nagatahawk is offline   Reply With Quote
Old 01-10-2007, 09:36 AM   #741
Super Moderator
Marcos.J's Avatar
im pretty sure if you go back and read the thread some one did use a different spur , I know ill get another spur to work ,
Old 01-10-2007, 09:42 AM   #742
nagatahawk's Avatar
you'l probably have to change the axle and diff assembly
tamiya does offer an optional metric 64 pitch pinion/spur gears.
good luck on the hpi gears.
Old 01-10-2007, 09:45 AM   #743
the problem is that there is a bearing in the middle of the Tamiya spur. Hpi used to make spurs for the F103 F1 cars, if you find them they will work.
Old 01-10-2007, 10:26 AM   #744
Super Moderator
Marcos.J's Avatar
i guess im in luck
Old 01-10-2007, 12:24 PM   #745
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
http://www2.towerhobbies.com/cgi-bin...?&I=LXN137&P=7
I think it is these.... i ordered some for mine a while back, but dont remember the exact # i got back then...
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-10-2007, 12:56 PM   #746
Thanks for the wheel part number. But does anyone know if tamiyamakes 26mm +2 dish wheels? I would prefer those.
How tight of a track?, I really dont know what to compare it to, perhaps someone can post pictures and I could compare the tcs set up track sizes to those. I should be able to find some pics of the local indoor tracks, I will post them later.
Anyone have any reccomendations on inserts? Most of my races will be run outside on parking lot surfaces.
Carthik
SeaKayCarthik is offline   Reply With Quote
Old 01-10-2007, 02:02 PM   #747
MrBlack's Avatar
FYI I have gotten confirmation that our Li-Po's will be officially legal for the F103-GT class for TCS!
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 01-10-2007, 02:19 PM   #748
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
open the flood gates...
madjack is offline   Reply With Quote
Old 01-10-2007, 02:50 PM   #749
Are you in the states? I dont see how this can be as the Canadian rules specify we must use spec peak 2400 packs. How would the North American Finals work then?
see link
http://www.tamiya.ca/2007tcsrules.htm
Old 01-10-2007, 02:52 PM   #750
madjack's Avatar
see link
US and Canada have different rules...race organizers
WTB Old direct drive car or sprint car mopar70 R/C Items: Wanted to Buy 2 04-23-2008 10:30 AM
Direct Drive Diff Help/Question Rockin Johny Electric On-Road 0 04-17-2008 10:53 AM
200mm direct drive touring car Tomoyuki Electric On-Road 13 06-26-2007 12:40 PM
Direct Drive Touring Cars scoobydo Electric On-Road 35 04-25-2005 03:46 PM
1/12 direct drive cars TFR Electric On-Road 13 08-31-2001 11:34 AM
