Tamiya Direct Drive Touring Car >
Like Tree92Likes
Old 11-28-2006, 12:39 AM
  #661
Originally Posted by MrBlack
I have often wondered about using a Brushless 380 motor for these cars as it would provide enough power and would provide a lower over profile.
Are the mounting holes to same as 540 motors??
Ben.C is offline
Old 11-28-2006, 12:56 AM
  #662
flying G.E.O.'s Avatar
Can I run my platinum lipo with a 380 brushless or have to go with 4 cells? The lighter weight might make the car have less traction on the rear even more.
flying G.E.O. is offline
Old 11-28-2006, 01:11 AM
  #663
NiMo's Avatar
no
already looked at this.
even in the old days when kits were sold with 380's you had to buy a motor mount to fit the 540's, and the F series (F101/102/103) was always supplied with 540's.
NiMo is offline
Old 11-28-2006, 12:55 PM
  #664
tallyrc's Avatar
to run a mamba you need this, unless you have a mill and lathe..
http://www.bk-electronics.com/catalo...oducts_id=1247 finedesignrc is the dealer stateside...
tallyrc is offline
Old 11-28-2006, 05:19 PM
  #665
forum fodder's Avatar
How many F103GT's ran in this years TCS? I had a look at the results from the finals, and i couldn't see an F103GT class.
forum fodder is offline
Old 11-29-2006, 08:50 AM
  #666
larrio's Avatar
It was not offered as a class at the nationals.
larrio is offline
Old 11-30-2006, 10:52 AM
  #667
MrBlack's Avatar
If you run a 380 motor you will need to run a specialized motor mount to convert the holes over as they are different then a 540 motor whic the F-103 is made for.
At Tamiya we all run the 4800 Platinum Li-Po and it provides the best balance of lightweight without being too light.
MrBlack is offline
Old 11-30-2006, 03:36 PM
  #668
I see. Thanks. I'm just looking for a brushless that would fit the f103gt without overpowering it and breaking the budget. Thought a 380 motor would do the trick.
Old 12-01-2006, 12:24 PM
  #669
MrBlack's Avatar
You can try runing the Novak 4300 motor and turn doen your max throttle adjustment on your transmitter?
This could also work and give you the maintenance freedom you want plus as you get a handle on the car you can turn up the wick.
MrBlack is offline
Old 12-04-2006, 05:48 AM
  #670
Rogier's Avatar
If any of you drivers is looking for a NEW F103GT with servo and body.... Look at: http://www.rctech.net/forum/showthread.php?t=138462
I bought it 3 weeks ago, but decided not to race it because the class is cancelled at our track.... LMK
Rogier is offline
Old 12-05-2006, 03:27 PM
  #671
MrBlack's Avatar
That is sad to here as it is the fastest growing class at Tamiya USA. I do not think I have seen such growth with one kit in several years.
MrBlack is offline
Old 12-06-2006, 09:39 AM
  #672
B3x
Hello
I have a couple of questions regarding the selection of a spur gear.
I have two spur for my F103GT (silver can). I have several pinions that let me achieve the same ratio with each spur.
I do not know which spur to use and why.
At the Tamiya track what would make one choose a 104 spur rather than a smaller one?
Do you select a larger or smaller spur based on track lengh ? motor type ? track design ? I am a bit lost.
B3x is offline
Old 12-06-2006, 10:51 AM
  #673
MrBlack's Avatar
Originally Posted by B3x
Hello
Using the smaller Spur will give a different powerband then the larger remember having the same ratio is not necessarily providing the same curve.
I personally use the smaller one but may go to the larger as we are running a weaker motor I would go with the smaller spur in genral over the larger in say a TC where the motors are over powering the car.
At the Tamiya track what would make one choose a 104 spur rather than a smaller one? Do you select a larger or smaller spur based on track lengh ? motor type ? track design ? I am a bit lost.
Yes.
I am thinking of trying the larger spur this weekend as I am noticing some power loss of the corners and this may help my situation as everything else has been used.
MrBlack is offline
Old 12-06-2006, 02:06 PM
  #674
B3x
Mr Black Thanks for the information !
B3x is offline
Old 12-06-2006, 03:38 PM
  #675
slcf1's Avatar
"If you like racing then worry about having people and attracting people to race with rather then a personal quest to make a class that you can win at."
Nice. Speaking of... we are going to run 3 endurance races in '07. Any chance of Mr. Black coming out with a teammate? 3 possible F103GT classes... Hours of racing in one day for the ever-reliable GT. Perhaps you could set something up in Cali and we'll come out for a similar event...
I think Bruce Hickman is coming again for endurance racing in May. I'm looking for anyone with an interest to come and join us. PM me if anyone is interested.
slcf1 is offline
