Old 07-29-2006, 10:01 AM   #436
With a 19T it will be a handful. R Partee was rnning his with one in prep for the 24hr and was spinning the diff all the way down the straight with it locked up pretty tight.
As for fit it looked pretty good. It was not drilled for the chassis but set on and looked right.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 07-31-2006, 08:19 PM   #437
Afro Puff's Avatar
Hey, I'm trying to put some turnbuckles on my F103GT but I've hit a little snag. Does anyone know where I can get some 5mm ball ends with the little screw threads (other than in the F103 turnbuckle set)? Thanks!
Ghetto Fabulous Racing: Not just ghetto, Ghetto Fabulous.
Team TYCO Jam Car: Independently controlled - acts as a moving obstacle!
Afro Puff is offline   Reply With Quote
Old 08-01-2006, 04:38 AM   #438
pole_position's Avatar
So far, i had been using the 4mm ball end from Team Magic which fits well and work fantastically.
pole_position is offline   Reply With Quote
Old 08-01-2006, 10:14 AM   #439
mtveten's Avatar
Trader Rating: 27 (100%+)
The tamiya hi-torq servo saver & the F103 turnbuckle set both come with the ball studs you need.
mtveten is offline   Reply With Quote
Old 08-09-2006, 06:41 PM   #440
Birky's Avatar
Originally Posted by OSherman
Anyone know when the COURAGE kit will be released?...
-O
Just as a headsup for everyone, the F103GT Courage is available at the online Hong Kong hobby stores now.
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 08-09-2006, 07:39 PM   #441
I've driven it already....And must I say...Get rid of the stock tires..! It sucked on carpet...
Ben.C is offline   Reply With Quote
Old 08-10-2006, 11:56 AM   #442
Send a message via MSN to ammo
I'm getting very good results with the F103GT on foam tires, 35R/26mm front, 30R/30mm rear. GRP.
Slides a bit when pushed hard, but with some paragon, it's on rails!
ammo is offline   Reply With Quote
Old 08-10-2006, 12:21 PM   #443
AWK
AWK's Avatar
All I want is that painted bodyset!!!!
AWK is offline   Reply With Quote
Old 08-10-2006, 06:37 PM   #444
Birky's Avatar
Same, I just ordered mine now.
Old 08-10-2006, 09:03 PM   #445
The painted body shell is sweet....Don't crash it...!!
Old 08-10-2006, 09:39 PM   #446
rayman's Avatar
What brand of foams set were you using? I tried fitting a elegy 26mm foam set and the wheels were hitting the suspension arms, etc.
rayman is offline   Reply With Quote
Old 08-11-2006, 11:59 AM   #447
Does anyone have a list of the parts needed to convert an F103RX/RS to the F103GT? I have an extra F1 car that I would like to change.
Thanks in advance!
ptjoe is offline   Reply With Quote
Old 08-11-2006, 01:08 PM   #448
I'm using the foams from GRP as mentioned.
As for hitting the sus arms, are your turning angles too much?
Old 08-11-2006, 02:47 PM   #449
Cool inside wheel lifts when pushing car hard on carpet
Hi, I was testing my 103gt at trackside yesterday (an indoor carpet track in milwaukee wisconsin) and the inside wheel lifts when cornering when pushing the car hard. With the advice of the guys there I got the lifting better by using trinity purple grease on dampner disks,tighting t plate up a bunch and going to associated 22 hard springs on the front suspension.I was running a stratus body and cs 27 tires with jack the gripper tire sauce.I got traction rolls at first but I fixed that by putting losy tire glue on sidewalls .If I just sauce 1/4 of front tire not much tire lifting but also does not turn as much as I would like, as I sauce more of the tire 1/2 to 3/4 of tires wheel lifting comes back. any ideas guys there must be a way to tame this trate of this other wise very cool car.thanks in advance.
Philip Henzog is offline   Reply With Quote
Old 08-11-2006, 03:03 PM   #450
larrio's Avatar
Thanks in advance!
The list is quite extensive and some of the parts aren't in stock either.
Here is the general list of parts, although you may need some miscellaneous bearings/screws and such here and there
1. C-parts and S-parts (Gearbox) - (51243)
2. F-parts (Suspension arms) - (51244)
3. R-parts (wheel adapter) - (51227)
4. Rear Wheel Mount (L) - (51232)
5. Rear Wheel Mount (R) - (51231)
6. T-parts (Uprights) - (51229)
7. Front Wheel Axle - (9805502)
8. 37mm shafts - no pricing yet (9808053)
9. 35mm shafts - no pricing yet (9808052)
10. 5mm disk spring - (9805489)
11. 8x16mm axle spacer - no pricing yet (3455376)
larrio is offline   Reply With Quote
WTB Old direct drive car or sprint car mopar70 R/C Items: Wanted to Buy 2 04-23-2008 10:30 AM
Direct Drive Diff Help/Question Rockin Johny Electric On-Road 0 04-17-2008 10:53 AM
200mm direct drive touring car Tomoyuki Electric On-Road 13 06-26-2007 12:40 PM
Direct Drive Touring Cars scoobydo Electric On-Road 35 04-25-2005 03:46 PM
1/12 direct drive cars TFR Electric On-Road 13 08-31-2001 11:34 AM
