Tamiya Direct Drive Touring Car >
Like Tree92Likes
Old 04-13-2006, 07:48 AM
  #331
izzyracer's Avatar
Trader Rating: 27 (100%+)
Question to F103 experts. I notice on the hop up image of the car in the manual. The area where the battery holder is suppose to be is not there and as you can see the battery is taped up to the upper deck. Is there another plastic part that does not come with the battery holders or did they cut this parts off?
I already ask people at Tamiya and they could not give me a satisfactory answer.
Thanks for anyones help in advance!
Attached Thumbnails Tamiya Direct Drive Touring Car-f103gtmnl.jpg   Tamiya Direct Drive Touring Car-f103gtmnl2.jpg
izzyracer is offline
Old 04-13-2006, 08:11 AM
  #332
Turbonium's Avatar
well, im no expert by any measure, but looks like it is taped to the little wings on the upper deck.
dont remember in my GT has those, but my old 103 did... ill look this eve and get some pix, if no one else has by then!
Wes
Turbonium is offline
Old 04-13-2006, 08:45 AM
  #333
It might just be that it was a pre-production shot Izzy. Notice that the whole upperdeck is not on the car either. They might have taken the pics before final spec was decided on the car, including the upper deck which is very necessary.
Difuser is offline
Old 04-13-2006, 02:19 PM
  #334
Difuser, I think the foam c class cars if thats what there called, are alot more fun. That would be sweet 23turn on foams at tamiya.
Juan Aveytia is offline
Old 04-13-2006, 02:28 PM
  #335
Kevin CBR's Avatar
Izzy - looks like on the hop-up picture that they just have the regular F103 top plate (the type on the regular that goeas all the way up to the servo is from the F103-LM kits). Either they left the regualr battery brackets off to be lighter, or if one of the hop ups is a different carbon lower chassis, it might not be drilled for the battery brackets.
Kevin CBR is offline
Old 04-13-2006, 02:42 PM
  #336
izzyracer's Avatar
Guys - The hop up top plate is CF and it does not extend to the servo like the stock...the new CG bottom is very stiff. But that is not what I am confuse with.
It is the plastic parts that keeps the battery. On the hop up one, it looks like these parts does not extend all the way out where you insert the pins to hold down the battery.
Old 04-14-2006, 02:55 AM
  #337
BrainTeased's Avatar
any guys using side by side packs instead of stick packs? someone has told me they can fit but has anyone tried 3700 or 3800 packs?
BrainTeased is offline
Old 04-14-2006, 09:14 AM
  #338
Hebiki's Avatar
Trader Rating: 26 (100%+)
yes 3800 side by side packs will fit. but you need to use direct solder tabs.. or strategically place your plugs.
Hebiki is offline
Old 04-16-2006, 03:20 AM
  #339
thanks Hebiki!
one more question if ya dont mind
on rcmushrooms it shows some spare parts and hop ups.
I was wondering out of those spares, it shows that they have 0.4 pitch spurs for the car. I was wondering if the 0.4 pitch is still a tamiya pitch or is that 64 pitch?
Old 04-16-2006, 03:23 AM
  #340
Burlap's Avatar
thanks Hebiki!
Tamiya 0.4 = 64 pitch, or really close.
Burlap is offline
Old 04-16-2006, 03:35 AM
  #341
cheers Mr Burlap
Old 04-16-2006, 08:44 AM
  #342
diha's Avatar
Hi Hebiki,
Can you post some pics.
Any modification done to the battery holder?
diha is offline
Old 04-16-2006, 05:26 PM
  #343
I'm going to pick up one of these chassis kits next week. Can someone tell me what other parts that I need to convert it to use an F1 body and wheels ?
Thanks.
Phenochilus is offline
Old 04-16-2006, 08:09 PM
  #344
mtveten's Avatar
Trader Rating: 29 (100%+)
Well if you wanted to convert it to an F1 using f201 wheels and tires you would need:
1. F103 body w/ front & rear wings
2. F103 (F1 style) chassis
3. F201 wheels & tires
4. F103 (f1 style ) upper deck
5. shave about 2mm off the bottom of your front spindles to make about a 4.5 - 5mm ride height with the smaller diameter wheels.
mtveten is offline
Old 04-17-2006, 10:31 AM
  #345
B3x
Well I just got one F103GT, and built it this week end.
Of course the first thing I did was to try the F201 wheels on it.
The rear ones fit good providing you shave just a little bit of plastic on the diff covert. The front ones will UNFORTUNATELY not fit with the actual setup.
I have an F103 F1 also and I would like to use it with the F201 wheels on asphalt.
B3x is offline
