Old 04-05-2006, 11:14 AM   #316
izzyracer's Avatar
Trader Rating: 27 (100%+)
Originally Posted by mtveten
The HPI spurs with the adapter ring do not fit, I picked up the 100T version from my LHS only to find out it would not fit. The 103GT gears all have a lip on them to hold the bearing in place that missing from the HPI gear and the kit bearing does not fit in the spur. Myabe the lip is not needed and with a different size bearing it would work but is certainly not a drop in replacement.
I would suggest that those looking for gearing options order the .4 pitch spur set TAM53104 (white 93 & 104T) or TAM53900 (black 93 & 104T)
If anyone has gotten the HPI gears to work maybe they could post exactly what has to be done to make them fit.
I beg to differ! I put them in with no problem, I ran the car 20 minutes at a time with my new Lipo's and it works really well. It might not look the same as the spurs but it fits well and it comes with it's own balls.
Izzy
izzyracer is offline   Reply With Quote
Old 04-05-2006, 11:35 AM   #317
mtveten's Avatar
What bearing did you use the kit bearing is to big to fit in the spur?
Mark
mtveten is offline   Reply With Quote
Old 04-05-2006, 06:33 PM   #318
porsche boy's Avatar
Trader Rating: 18 (100%+)
Default box stock f103gt
Hi I have just built my completely box stock tamiya f103gt last night and I ran it today in front of my house at low speed it runs fine then when I ran it at full speed the car would spin in circles! Any help would be appreciated thanks in advance
porsche boy is offline   Reply With Quote
Old 04-05-2006, 06:42 PM   #319
Hebiki's Avatar
Trader Rating: 26 (100%+)
i assume you mean the car would spin in circles when you are trying to turn?
you need to be very smooth on the throttle for this car. if you are grabbing too much throttle when you are exiting a turn, the car will spin out.
also, id suggest you take it to your local track. the front of your house is probably fairly dusty and doesnt have a lot of grip.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-05-2006, 06:55 PM   #320
Burlap's Avatar
Send a message via MSN to Burlap
Hop upped my beastie last night, got the F1 pivoting rear end, turn buckle steering arms, some 0.1/0.2/0.3mm shims to get rid of the slop in the front axles, aluminium heat sink and some gears. The car is looking great.
Has anyone brought the TRF oil shock that is an option for this car? I am using a standard TRF shock off an old kit, and wonder what the actual differences are, whether it be the number of holes in the piston plate or something like that.
Burlap is offline   Reply With Quote
Old 04-05-2006, 07:00 PM   #321
izzyracer's Avatar
You can get this car really smooth. I had my best run last weekend. Tires has a lot to do with it as well.
Izzy
Old 04-05-2006, 09:28 PM   #322
crunchracer's Avatar
Talking
Dan and Ritche had thier 103GT's hooked up pretty well at TCS at SIR, I am pretty sure Ritchie is useing the Pivot Ball rear, Dan was using the Stock O-Ring set up.
Dan helped me out with a set up that made all the diff in the world for me. I tightened the t-bar pivot screw 1 full turn from stock setting, AW grease on the slider, B3 tires, with Yoke med-hard thin inserts on +2 Tamiya wheels, Asc 22 front springs, 3 hole piston Silver shock with 40 w Assoc oil Tamiya yellow spring, 2002 NSX body.
Have fun, good luck
www.FusionMotorsports.com
Team S.I.R
John's BSR Racing Tires
crunchracer is offline   Reply With Quote
Old 04-08-2006, 10:11 AM   #323
SpeedTech's Avatar
Hi Guys,
We got a few more new hop-ups for the F103GT series cars:
Alum. motor mount height adjustable
Carbon 3.0mm lower chassis
The TRF Special Dampers are back in stock as well and also Spare parts are now available
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-09-2006, 06:26 AM   #324
rayman's Avatar
Ey, dont sell your kit right away. Mine is also box stock except for the 18T pinion and the tires. Dont use the kit tires for the rear. I suggest you use the front stock tires in combination with sorex 32r or tamiya b3. This will give you a lot of understeer but better than spinning in circles. Its like driving a spool. Heavy breaking before corners.
If you want to use 24mm tires all the way, try 24r,32r front with 40r rear. The car is very picky with tires and I usually change tires depending on the weather.
rayman is offline   Reply With Quote
Old 04-13-2006, 01:56 AM   #325
izzyracer's Avatar
Default hopped!
Finally installed my hopups!
Izzy
Old 04-13-2006, 07:06 AM   #326
Turbonium's Avatar
Send a message via Yahoo to Turbonium
hey Izzy... is that a std white spring, or one of the white springs with the color dot? im trying to figure out where to start....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-13-2006, 07:33 AM   #327
ICEMAN's Avatar
Just wanted to let everyone know that the TCS race in MEMPHIS, TN is coming up in two weeks, APRIL 30, Sat. we have a Club race any car brand can run and Sun. is the TCS race, we have 48 entries so far, i think like 9 or so in F103GT, you can check out more at www.tamiyausa.com or our club site at www.msra-racing.com , CYA
Blizzard Concepts / Team Losi / Team ProMatch / Team MuchMore / The SPEED Shop / Ko Propo USA / AVID RC / BigDog Graphics / Nitro R/C Chop Shop /
The ONE that DIES with the Most Toys WINS!!!
ICEMAN is offline   Reply With Quote
Old 04-13-2006, 07:39 AM   #328
Burlap's Avatar
No turnbuckle steering arms?
Old 04-13-2006, 08:26 AM   #329
izzyracer's Avatar
It' still in the package. I'm going for lightweight!
Izzy
Old 04-13-2006, 08:29 AM   #330
izzyracer's Avatar
The spring has a red dot which is the one that came with the shocks. Frankly, this is probably not what I will end up up as far as set-up. I suggest you start with your middle spring rate. That way you can adjust up or down.
Izzy
WTB Old direct drive car or sprint car mopar70 R/C Items: Wanted to Buy 2 04-23-2008 10:30 AM
Direct Drive Diff Help/Question Rockin Johny Electric On-Road 0 04-17-2008 10:53 AM
200mm direct drive touring car Tomoyuki Electric On-Road 13 06-26-2007 12:40 PM
Direct Drive Touring Cars scoobydo Electric On-Road 35 04-25-2005 03:46 PM
1/12 direct drive cars TFR Electric On-Road 13 08-31-2001 11:34 AM
