Tamiya Direct Drive Touring Car >
Like Tree92Likes
Old 11-14-2011, 04:48 AM
  #1561
mailboxck's Avatar
Cool body! How'd you get to mount TC tires upfront when you didn't switch to a GT front?
I also run 26mm (Front) and 30mm (Rear) foams for Nitro. I currently switch between 37 to 45 shore HPI's, GRP's and Jaco's. Overall, I think Jaco has the best rear traction while GRP has the most consistent front tires.
mailboxck is offline
Old 11-14-2011, 07:29 AM
  #1562
Hi,i'm using F103GT front suspension, direct fit on the 103LM chassis. Im using Xceed 37shore front and 42shore rear, my lhs only have these shore for black rim so i took them. The car suprisingly handles very well with understeer character. Tyres wear were excellent as the car is light! I'm really happy to have this car running again.
ses414 is offline
Old 11-14-2011, 11:40 AM
  #1563
gtfour93's Avatar
Trader Rating: 22 (100%+)
Does anyone here know how to increase the downforce in the F103GT's Advan Courage body?
There's a small notch in the middle front splitter that can be cut away. Does this have any advantage?
Also, has anyone tried changing the angle of the rear wing to increase rear downforce?
I had the same downforce issue with this body on the first run. Lowering the body as much as possible, without wheel interference helped to increase downforce. The car was more steady on the straights and turned in much sharper in the corners. I also thought about cutting the front middle section, but I wasn't sure if this was a good idea. It might create a ballooning effect, which will make the front unstable. By the way, you can also add a foam on the front bumper, to keep the nose from had impacts. I used a 3Racing M-05 front bumper, with some minor modifications. I haven't tried changing the angle of the rear wing, but maybe adding a piece of clear lexan, as a gurney flap will help increase rear downforce? Something adjustable like this.
gtfour93 is offline
Old 11-14-2011, 04:40 PM
  #1564
mailboxck's Avatar
These cars are indeed amazing. We ran 15 minute mains a month ago, so summing up the 3 mains, my car ran for a total of 45 minutes. With that, my rear tires only lost around 0.6mm in diameter.
I'll post pictures of my car later this week. I'm just cleaning it out first before the race.
Old 11-14-2011, 04:42 PM
  #1565
mailboxck's Avatar
I guess I'll just keep the nose the way it is. But do you have pictures on how you mounted a foam bumper to the GT? I'm thinking of making a custom front mount to move the body posts to a more forward position.
Also, perhaps I can screw on some pieces of lexan to the back end to increase downforce. Problem is, the Courage's wing is not big enough for something to be directly bolted on.
Old 11-15-2011, 12:18 PM
  #1566
gtfour93's Avatar
I found a way to put this 3Racing M-05 front bumper to use, since the original base broke. I basically just reused the foam and carbon brace, with other hardware that I found. Some foam in the back had to be shaved off for better fit. Otherwise, it fits pretty good and doesn't get in the way of the Courage headlight buckets.
gtfour93 is offline
Old 11-15-2011, 05:13 PM
  #1567
mailboxck's Avatar
Nicely done! Now I'm wondering which is a better option:
1. Make a new front plastic bumper that extends all the way out to the front splitter of the Courage body -or-
2. Make a short front plastic bumper so I can mount a foam bumper like you did.
You see, I didn't buy the Courage kit so I dont' have that small bumper like you do. My solution was basically to cut up a TA05 bumper so that I can use the same holes as the Courage's.
Old 11-15-2011, 08:35 PM
  #1568
gtfour93's Avatar
Thanks!
Are you using the GT or the LM chassis with the Courage body? If you're using the GT chassis, then just get the Courage bumper and do what I did with the 3R bumper parts. Here are the item numbers for the bumper parts.
Item #9000030
http://www.tamiyausa.com/product/ite...uct-id=9000030
3Racing #M05-04
http://www.rcmart.com/rc-3racing-m05...r-p-28127.html
With the TA05 bumper, all you probably have to do is trim the sides of the foam. The foam by the way is sold separate.
gtfour93 is offline
Old 11-16-2011, 03:57 PM
  #1569
mailboxck's Avatar
It's actually almost impossible to get the original Courage bumper here in the Philippines so I'll have to hack myself one from scratch. Thanks for the tip!
Old 11-16-2011, 09:45 PM
  #1570
gtfour93's Avatar
Post a WTB message in the Manila racers section. Someone might have a spare available.
gtfour93 is offline
Old 11-16-2011, 09:47 PM
  #1571
gtfour93's Avatar
Is this where you play?
+ YouTube Video
gtfour93 is offline
Old 11-16-2011, 11:19 PM
  #1572
mailboxck's Avatar
We tried ordering through our Tamiya LHS but with no success and whoever has one is holding on to theirs
Yep! That's our indoor playground. Really smooth and sticky asphalt. Grip is moderate in the morning but improves gradually as more racers put down rubber and clean up the track.
Old 11-16-2011, 11:36 PM
  #1573
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Chris... are you running the GT chassis or the usual F1 chassis?
Maybe these will help in your front bumper mod:
TECH Racing
CROSS
I've ordered from them before (a shell and decal sheet) and they're pretty reliable
hths
VooDooPH is offline
Old 11-17-2011, 12:25 AM
  #1574
mailboxck's Avatar
I actually run an F103GT chassis so the one from Tech looks more like the one I use now which is from the TA05. I'll try to put one together using some old discarded engine covers and undertray's that I'll get from a local car shop .
Old 11-25-2011, 01:37 AM
  #1575
mailboxck's Avatar
Raced the F103GT last weekend with mixed results. The track was very slippery which made it a headache to drive the car. I ran gold springs upfront and fluorescent red spring at the back.
During practice, I used my brand new set of Ellegi tires (45 front/37 back). But because they weren't trued, it would take me a couple more practice laps to get them to the right diameter and smoothness.
So for the race, I used GRP 40's for the front Nitro Shoes 38's for the back. The handling was still very twitchy for some portions of the track and needed a lot of driving finesse.
My diff is tighter than normal, thinking that it will let me accelerate out of corners a lot better. But during this race, the back end would just step out if I try to accelerate without the front tires pointing completely straight. Am i doing this right, or should it loosen it up a bit to make it accelerate better?
